Tau VS IG 12.5K Tank battle
 Post subject: Tau VS IG 12.5K Tank battle
PostPosted: Sun Nov 10, 2013 2:09 pm
I wanted to play a tank battle with limited Inf. Airforce and Titans/Mantas.
So I go for the Tau and IG.
I restricted me to at least 6K of tanks each side and not more than 1K airforce
Inf. should be mechanized.
Tau army:
8x Hammerhead Cadre
2x Hunter Cadre
1x Swordfish Carde
1x Battlesuit Cadre
4x Skyray det.
2x Hammerhead det.
2x Stingray Gunship det.
3x Scorpionfish SH gunship
2x Pathfinder sniper det.
2x Staelthsuit det.
1x Pathfinder det.
1x Ethereal
1x Shas´o commander
1x Tigershark drone carrier
1x Tigershark AX-1-0 strike craft
1x Barracuda det.
1x Remora drone carrier
IG
2x LR COy
2x LR assault Coy
2x Mech Inf. COy
1x Artillery COy
1x Shadowsword COy
1x Macharius COy(Vanquisher cannon)
6x different Malcador det.
2x Demolisher det.
1x Thunderer det.
2x Valdor det.
1x Tank hunter det.
3x Hydra det.
1x heavy AA det.( earthshaker based)
1x Warhound
2x Heavy mech inf. det.
1x Major+Bodyguards and Chimera variant
1x IG Physic
1x Ordinatus Mars?
1x Maraudeur destroyer det.
1x Lightning Strike fighter
1x Lightning attack fighter
Setup and Turn 1
Objektives
Fortress
Hills
Bunker
Governor`s palaceImage
Big bridge
Administration building
Small bridge
Big hill
Deployment Tau and snapshots
Deployment IG and snapshots
Movement
The Ig right wing rush forward and try to crush the Tau left flank with the help of the IG´s airforce
The rest of the 1st Bat. move to the administration building
The 2nd Bat. start to cross the bridge to secure the Governor´s palace
it´s LR Coy scurde the bunke and now attack the hills
supported by heavy Inf. and more tank dets.
Artillery and heavy Macharius tabks move into fireing positions
Tau:
Tau Tank Bat. secured the hills and now tries to attack the bunker
Fortress secured, the Tau forces mostly mechanized Inf. and Hammerheads rush for the Governors palace
heavy units(Scorpionfish and Swordfish) giving fire support
Tau center Battlesuits, mechanized Inf. and Hammerheads move into the suburbs and attack administrations building and big bridge
Tau left flank consisting out of Battlesuit cadre and Hammerheads
they just should stop the IG´s attack
After First fire and advanced...not much casualities all over
Points
IG 20= 2x Objektives (bunker, Hill)+2x Hammerheadcadre
Tau 15= 3x Objektives(small bridge, fortress, hills)
 Post subject: Re: Tau VS IG 12.5K Tank battle
PostPosted: Sun Nov 10, 2013 2:59 pm
Turn 2 Movement
both sides try to secure the place between the big bridge and the governors palace
now Tau fire warriors jumped out of their Devilfishes and move next to the administration buliding
IG airforce attack Tau forces at the side and rear
return fire from Skyrays(very bad AA unit BTW) caused avarage casualities
Tau and IG tanks get into short ranged fire fights
Administration building in IG´s hands?
2nd Bat. troops swarm out to get control over the place between Gov palace and big bridge
IG troops use the good position and firecover to attack the hills
Tau aircadre support the outnumberd tank bat.
Enemy strikefighter sighted
Warhound leading the charge
Boardsides move into fireingposition
Marauderdestroyer attacking at low altitude
the administration building so close
Fire warriors getting in tuch
another detachment holde the big bridge
First fire
the best example for markerlights and guided missiles.
The 2 pathfindersniper stands(in bunker) lighted up the warhound
Scorpionfish No1 uses its small missiles to strip the shields, while being safe and in cover
Scorpionfish No2 uses it´s heavy penetrating missiles
and hit the right weapon which caused a flashback to the reactor and destroyed the mighty machine instantly
Bulls eye ......markerlights are great ;D
in return the Ordinatus uses it´s sonoic weapon to destroy one of the Scorpionfishes...ouch
Tau forces move trough the suburbs
the place is gettig hot clos tank battle
Earthshakers
Macharius and Hydras well dug in and in cover
After first fire
Maraudeur taking altitude after strafing run
Lightning strike fighters at low altitude
Crisis suits move into better positions
Thunderes in front
Imperial armour move around the admin building
After advanced
first units fell back
Snapshots
Points
IG 60= 3x Objektives(Hill, Gov Palace, Bunker)+45
Tau 51=3x Objektives(Hills, Fortress, Bridge)+ 36
PostPosted: Sun Nov 10, 2013 7:29 pm
Turn 3 after movement
the last advance, both sides throw the last tanks in battle now even the APCs had to fight...and die.
Will the Tau conquer the admin building?
Imperial airforce focused on the Tau flank
The Tau airforce attack the imperial units on the hill
Hydras bring down the Tigershark AX-10
After combat phase
Tank forces destroyed each other in the center place
and another tie on the flank
Maraudeurs fell prey to pathfinders and Skyrays
thinned out lines
target on sight
firefights at short distance
brave Lightning fighters
Battlesuits on the march covered by fire warriors
The last Scorpionfish
Boardsides support the tanks
Barracuda and prey
The Tau airforce caused heavy casualities on the IG ranks
Hydras out of range
Big Bridge and Admin building are still neutral
PostPosted: Sun Nov 10, 2013 7:41 pm
Turn 4
Pics from and after combat phase.
No side managed to pull off a clear victory
Tau are ahead but it´s a very close game
Objektives :
Hill IG
Admin building Neutral
Bridge Neutral
Gov palace IG
Bunker IG
Hills Tau
Fortress Tau
small bridge Tau
Snapshots
Overview
Points
IG 98
Tau 117
PostPosted: Mon Nov 11, 2013 2:01 am
Phew close game.
Great photos Ulric, the board and models look terrific.
PostPosted: Mon Nov 11, 2013 4:11 am
Fabulous Ulric!
I really got to get my Tau army done. :)
PostPosted: Mon Nov 11, 2013 6:37 pm
Nice report, thanks for sharing! Good to see you playing and posting again Ulric! Your reports have been sorely missed!
PostPosted: Mon Nov 11, 2013 6:48 pm
Thanks for sharing Ulric, always enjoy seeing you battle reports.
PostPosted: Tue Nov 12, 2013 6:58 pm
Glad that you liked it.
It was a funny battle due to many tanks and not too much cover.
I will try to use the markerlights more it could be a big deal keep your vulnerable units in safty while blowing swarms of missiles on your enemy ;D
Although tried out the miniature modus on my camera for the snapshots
and it worked everything looks like a miniature on this pics ;) :D ;D
