Iron Warriors v3.2 (playtest) vs. MInervans (3000pts)
 Post subject: Iron Warriors v3.2 (playtest) vs. MInervans (3000pts)
PostPosted: Thu Jan 09, 2020 4:02 pm
Bringing this writeup over from my blog now that Taccoms is back up. This is the first of several battle reports aimed at exploring potential tweaks to the Iron Warriors v3.1 approved list. The playtest changes can be found here:
http://www.taccmd.tacticalwargames.net/viewtopic.php?f=82&t=34161
ARMY LISTS
Iron Warriors (NetEA v3.2 *PLAYTEST*), 3000 POINTS
DEFILER ASSAULT PACK [400]
- 6 Defilers
ARMOURED ASSAULT COMPANY [225]
- 6 Chaos Vindicators
IRON WARRIOR TERMINATORS [275]
- Iron Warriors Lord, 4 Iron Warrior Terminator
DREADNOUGHT ASSAULT PACK [250]
- 5 Chaos Dreadnoughts, 5 Dreadclaw Drop Pod
SIEGEHAMMER COMPANY [265]
- 8 Iron Warrior Assault Marines, Iron Warriors Lord, 8 Dreadclaw Drop Pod
OBLITERATOR CULT [350]
- 4 Obliterators
HAVOC COMPANY [375]
- 4 Havocs and 2 Land Raiders, Iron Warriors Lord, Stalker
ARTILLERY BATTERY [375]
- 4 Chaos Basilisks, Stalker
HELLBLADE FLIGHT [200]
- 3 Fighters
DEVASTATION CLASS CRUISER [150]
Minervan Tank Legion (NetEA Tournament Pack 2014), 2900 POINTS
ARTILLERY COMPANY [600]
- 9 Basilisk
TANK COMPANY [650]
- Vanquisher, 9 Leman Russ
TANK COMPANY [425]
- 10 Thunderer
SALAMANDER SCOUT PLATOON [100]
- 3 Salamanders
STORM TROOPER PLATOON [350]
- 8 Storm Troopers, Valkyrie Transport
MECHANIZED PLATOON [300]
- 10 Infantry, 5 Chimera
WARHOUND [275]
- 1 Warhound Class Titan
ORBITAL SUPPORT [200]
- Emperor Class
PREGAME
Since my opponent took a Battleship, I knew he wasn’t coming in with Orbital Support until Turn 3, which was good insofar as it let me get my drop in Turn 1. I placed my objectives toward midfield on either side of a large crater so that my dropping infantry would have some cover to fall back into, while my opponent spread his out on either side of a mesa so I wouldn’t be able to effectively cover both with midfield forces. I plotted my orbital barrage to land behind the mesa on his side of the table, assuming something would be hiding there to avoid first-turn direct fire, and plotted both of my drops (IW Siege Hammer Company, Dreadnought Assault Pack) to land on top of each other, midway between my central T&H objective and his back line, with plenty of room to shift behind the mesa or into the crater to threaten formations in their starting positions.
After setup, it was apparent that I was going to glance his Warhound, at best, with the orbital barrage from my Devastation (which is about par for the course for me in pre-plotting barrages), and my drop forces were going to have a good line of engagement to his BTS, the Leman Russ company. Yeah, pretty much have to go all or nothing with an immediate drop there.
TURN ONE
Imperial Guard won the initiative.
The Minervans’ Basilisk company immediately sustained fire on the Defilers, scoring 4 hits, all of which were saved. With no retain, the momentum passed to the Iron Warriors. The Iron Warriors’ cruiser in orbit came through overhead, dropping its orbital barrage and missing its pinpoint attack on the Warhound, ablating one shield(!) and putting a blast marker n the Salamander scouts. Also par for the course for me and orbital barrages. Dreadclaws rained down from above, course-correcting into the crater in front of the Leman Russ company and unloading their cargo of Siegehammer assault infantry and Dreadnoughts.
The Siegehammer company retained, pulling the Dreadnoughts along with them into an assault on the Leman Russes. Three tanks went down to the initial assault, another 4 fell to hack-downs, and because my attack line had spread out so widely, the remaining tanks couldn’t retain coherency and still move more than 30cm away from the attackers, wiping out the company and netting the Iron Warriors BTS.
The Minervans reacted by doubling the Thunderer company over and firing on the Dreadnoughts, to no result. The Iron Warriors responded with a Hellblade ground attack against the Valkyries, inflicting 1 blast marker. The Iron Warriors’ Basilisk battery then retained, sustaining fire and placing their barrage on the intermingled Stormtrooper Valkyries and Mechanized Company’s Chimaeras, but all hits were saved and each formation took a blast marker. Since both formations’ infantry started in their transports, a couple of vehicle kills here could have had much more significant consequences. The Chimeras then advanced, disgorging their troops and firing on the Siege Hammer Company and killing two.
The Iron Warriors then took and held the initiative. The Defilers doubled and fired on the Basilisk company with their battle cannon, knocking out two from 4 shots (after suppression). Then the Havoc Company doubled up, firing on the Mechanized Company and knocking out 3 guard squads.
In response, the Valkyries advanced and deployed their Stormtroopers, dropping half of their rocket pod barrage on the Havocs and wiping out three Havoc squads to break the formation (BTS). After this, the left flank Iron Warriors Vindicator formation marched up to support the Dreadnoughts and Siege Hammer Company, while the Minervan Salamanders failed to activate and took their move. The second Vindicator formation doubled up and fired on the Salamanders from extreme range, inflicting one blast marker and breaking them. After that, the Warhound finally ground to life, engaging the Dreadnoughts in the crater, only to be broken after two rounds of assault, losing two damage capacity and taking down all but one Dreadnought (who promptly broke and fled in the direction of the Minervans’ Blitz).
At the end of the turn, all formations rallied on both sides, and the Obliterators and Terminators came down intermingled behind the Minervan Mechanized Company (Terminators took 2 blast markers from the teleport).
TURN TWO
Iron Warriors won the initiative.
The turn began with the Obliterators sustaining fire on the Mechanized Company, catching them in a crossfire with the Siege Hammer Company across the way. This wiped out all remaining guard squads, leaving the Chimeras bereft and broken. With that force eliminated, the Terminators retained and engaged the Basilisks, wiping them out at the cost of one Terminator squad (breaking them).
In response, the Warhound advanced, firing with its plasma blastgun on the midfield Vindicators and killing 2. The midfield Vindicators repositioned and fired on the Stormtroopers, killing two. Then the Defilers retained for a double, bracketing the Stormtrooper company, wiping out two more squads and downing 3 Valkyries, breaking the formation.
The Minervans’ Thunderers then failed their activation, firing on the Siege Hammers as well, killing two more and breaking them.In turn, the Iron Warriors’ Basilisks sustained and took direct-fire shots at the Salamander Scouts, killing two. With that, the Minervans were out of unbroken formations.
The midfield Vindicators marshalled and fired on the Warhound, inflicting 1 blast marker and clearing their own blast markers. The Hellblades made a ground attack on the broken Stormtroopers, killing one more with the blast marker. The rallied Dreadnought moved onto the Minervans’ Blitz. The Havocs doubled and fired on the Warhound, knocking off a void shield and piling on another blast marker.
At the end of the turn, the Minervans’ Mechanized Company and Warhound rallied, while the Thunderers, Stormtroopers, and Salamanders failed their rolls.
TURN THREE
The Mechanized Company’s Chimaeras started off the turn by failing their activation and repositioning across the midline. In response, the Defilers repositioned, fired on the Chimaeras, killing 3 and breaking them.
The midfield Vindicators then retained and sustained fire on the Warhound, scoring the final necessary hit, critting it, and it staggered to the ground dead. The Thunderers retaliated by advancing and firing on the Dreadnought holding the Blitz, taking it down in a hail of high explosive shells.
The Obliterators moved to occupy the Iron Warriors’ lefthand T&H objective. Finally, the Battleship in orbit came past overhead, pouring fire onto the battlefield and overlapping both T&H objectives. 2 Defilers and 2 Vindicators go down to the orbital bombardment, breaking both formations and ending the Minervans’ activations.
The Hellblades make a ground attack against the Salamander formation, knocking it out. The Siegehammer company moves to occupy the T&H objective vacated by the Defilers. The Basilisks sustain fire, but only manage to kill 1 broken Chimaera. Finally, the Havocs march and stretch out to occupy the third DTF objective.
In the end phase, the Chimaeras rally, denying TSNP.
ENDGAME
At the game’s end, the Iron Warriors came out ahead 3-0 with BTS, DTF, T&H.
So it wasn’t until I went to write up this battle report that I realized my opponent had shorted himself 100 points when building his list, which could have bulked up his Thunderers with a few Leman Russes, Salamander Command vehicles, or maybe taken another Salamander Company entirely. Oops. I’m not entirely convinced it would have made too much of a difference though, as the units I dropped on were pretty handily wiped out when I hit them.
I don't think the points reductions to Defilers or Vindicators are really that significant for their formations (strips out some of the points tax that was initially built into them), but unlocking ~75 points' worth in the Core section does unlock an extra activation for Iron Warriors. Typically I find myself around 8-9 activations with spare points, but not enough list flexibility or enough points to take another. Reducing overpriced core formations' cost and reorganizing the force org chart (Havocs and Obliterators to Siege Support where they probably belong) definitely unlocks more options and more potential list variety.
These two combinations (Obliterators in Support, room in the list for an additional activation due to points costs), are what I'll probably want the most testing from the community on - have I unintentionally turned the Siege Assault Chaos list into an extremely hard-hitting and durable ground-holding drop assault list? If so, is that ok?
Honestly, Minervans are particularly vulnerable to a heavy drop assault list like this. I got pretty lucky in my targets, and the Stormtroopers might have been able to do more damage if they'd been given freer reign, or if he'd taken a second formation instead of the Mechanized Platoon (and used up the last 100 points). Chances are I could have won 2-0, after getting most of the forces I'd sent over the midline mulched and maneuvering to claim objectives with Vindicators. Would have been a different game, but possibly not that much.
Instagram: https://www.instagram.com/armiger84/?hl=en
My General Modelling Blog: http://armiger84.blogspot.com/
 Post subject: Re: Iron Warriors v3.2 (playtest) vs. MInervans (3000pts)
PostPosted: Fri Jan 10, 2020 4:53 pm
Great batrep!
But I don’t understand this bit: ‘the remaining tanks couldn’t retain coherency and still move more than 30cm away from the attackers, wiping out the company and netting the Iron Warriors BTS’.
The Wargaming Trader
PostPosted: Fri Jan 10, 2020 5:40 pm
I'm guessing here, but the tanks were broken and needed to get outside of 15cm of the enemy. There was no place they could do that after their withdrawal moves and still be in coherency. So they moved as best they could and now they're broken and no longer coherent. So they remove a few tanks, which cause BMs, which cause hack downs and all the tanks are destroyed.
It might have been prevented if better tanks were chosen for casualties and assault hack downs, rather than all the tanks in the middle, leaving some on the left and some on the right.
PostPosted: Fri Jan 10, 2020 7:36 pm
It’s also prevented by not bothering to move the tanks that won’t be able to reach coherency, which means that they die due to being too close, and no extra BM ‘hits’ occur.
EDIT - and I’m assuming the Commissar already died.
