Codex Astartes(NetEA2014)Vs Tau Vior'la (1.5 Developmental).
 Post subject: Codex Astartes(NetEA2014)Vs Tau Vior'la (1.5 Developmental).
PostPosted: Sat Nov 19, 2016 3:19 am
Hi All,
Well we manage another game of epic. It was 3000 point per side and it was between Codex Astartes (NetEA Tournament Pack 2014) and Tau Vior'la (1.5 Developmental)
I played the Codex Astartes (NetEA Tournament Pack 2014) and Mathew played the Tau Vior'la (1.5 Developmental)..
Link to AAR..
http://pfe100.blogspot.com.au/2016/11/c ... -pack.html
Regards
Greg
 Post subject: Re: Codex Astartes(NetEA2014)Vs Tau Vior'la (1.5 Development
PostPosted: Sat Nov 19, 2016 4:18 am
Interesting lists and battle.
Could you explain the thinking behind them, the marine list is certainly not what is played in the UK, and the Tau list has some unusual points.
PostPosted: Sat Nov 19, 2016 6:49 am
Tau: Mathew tends to like having the Recon in mass, so that he can make sure that he gets the marker lights and crossfire. It also means you have hard time breaking all that recon at once..
The cadre fire blade upgrade means the FW fight at 4+ in FF...so he sees it as good thing since FF is increased for chance to hit..
Spaceship was to give him some TK hits although the Tiger shark AX-10, maybe the better option, but you cant shoot down a Spaceship...
I believe also he's using version 1.8
Space-marines..
I notice that with the UK..The SM was really done to push FF side. I took the Devastators&Chaplain to mainly do FF, so that was basically 2 dice at 4+ , 8 dice at 3+ and +2 for inspiring and once they had done engagement could then be a fire base as such or get the thunder-hawks to do the traveling circus thing.. :)
When using vassal, sometimes you forget about the stuff off board, so gave away 400 points, when the spaceship fired..The two thunder-hawks should have just done log range shot with their battle cannons on a Hammer head formation..Then came on turn two and did a engage actions, no spaceship..then could have been use to do the traveling circus thing..didn't happen.. :) ;) ;D
Regards
Greg
PostPosted: Sat Nov 19, 2016 5:54 pm
technically you used the 2015 codex list, not 2014.
PostPosted: Sun Nov 20, 2016 2:38 am
Yes that's correct, it still states 2014 in the army-forge program...
Regards
Greg
PostPosted: Sun Nov 20, 2016 12:39 pm
wow that's a lot of chaplains. I've fancied taking chaplain scouts myself, but don't think i've ever seen a chaplain land raider before.
PostPosted: Sun Nov 20, 2016 11:59 pm
True..We have had Trent pop chaplains in whirlwinds before.....
Regards
Greg
