Imperial Fists V1.2 Versus Death Guard (EpicUK)
 Post subject: Imperial Fists V1.2 Versus Death Guard (EpicUK)
PostPosted: Fri Mar 13, 2015 9:32 pm
Managed a game against Steve54 last night, thought I'd try out the enlarged vindicator formation so took two of em (also, freshly painted they needed a baptism of fire)
IF list
Tacticals + supcom + las razorback
Tacticals + las razorback
whirlwinds + hunter
Scouts
Fellblade
6 vindicators
6 vindicators
Terminators + chaplain
Thunderfire cannons
Storm Talons
DG list
Retinue + rhinos + warlord + pact + vindicator
Retinue + rhinos + pact + vindicator
Terminators + pact
Zombies
4 preds
Chaos marines + pact
Defilers
plaguehound
plaguehound
hellblades
4 lesser daemons (although according to armyforge it should have been 3)
I took lots of pics, but as usual, as the game wore on, I started forgetting.... so it kind of peters out halfway through turn 2 as is normally does... ;)
Setup:
Fists win initiative after 3 drawn rolls!
scouts double
DG BTS retinue doubles
stormtalons go on CAP
second DG retinue doubles
Whirlwinds sustain on them....
...killing a lone vindicator
[DG activation missing]
thunderfires sustain on them...
...killing a few
Fellblade doubles up and kills a single stand(!)
Chaos preds are hit by something... or maybe this was them moving up and shooting the fellblade.... I forget
vindicators double and hit the preds, killing 1
Defilers double up and hit the vindicators
second vindicator formation moves up and hits the retinue AGAIN... all hits are saved.... grrrr
plaguehound knocks out a vindicator
Tacs double to prepare to engage T2, they spread out to avoid the worst of the nearby plaguehound's barrage
IIRC the plaguehound then singled and managed to hit the tacs, killing FOUR stands of marines and a rhino.... grrr
 Post subject: Re: Imperial Fists V1.2 Versus Death Guard (EpicUK)
PostPosted: Fri Mar 13, 2015 9:34 pm
Turn 2
Terminators teleport in and are immediately broken by thunderfire cannon disrupt hits (didnt help that they came in with 2BMs)
IF terminators engage and destroy plaguehound, despite only scoring 4 hits, (3 normal, 1 MW) Steve managed to fail all 4 reinforced armour saves, must come from the same factory as my warhounds...
7 stands of plague zombies scuttle into BTB with the whirlwinds....
....they kill the hunter and another WW dies to hackdowns
something happened here... I forget who shot who or whatnot, but some vindicators ended up dead somehow
mighty fellblade advances and flattens a single defiler after all its lascannon and demolisher hits are saved...
Tacs break the defilers
THIS was when the plaguehound took a massive bite out of my BTS, sorry.... got confused
hey tiny predators, whatcha doin? I can't remember....
....probably breaking your vindicators mate
second vindicator formation carries out a reprisal attack
"Run charlie! run fer yer life!!!" the supreme commander BTS formation comes off badly in an engagement....
"Storm Talons" mow a few zombies down...
Hellblades snipe the chaplain out of the terminators...... :{[]
I now run out of pictures..... the terminators were subsequently engaged and wiped out to hackdowns by chaos marines and plaguebearers, my fellblade died to similar, could not pass a save, only making 3 power armour saves in the entire game, my tactical marines couldn't hit the back of a barn door in their engagements and Steve couldn't fail a save.... game ended 2:0 to DG with BTS and DTF after I stupidly doubled my scouts into his half but didn't nab the T&H objective.... ::)
PostPosted: Fri Mar 13, 2015 9:35 pm
Thoughts:
I quite like the enlarged vindicator formation, it has decent shooting and staying power, the fellblade is pretty lacklustre, it suffers from baneblade disease of needing to double everywhere to get its guns in range, so its shooting ends up being a bit pants.... could probably do with a points drop, although I'm keen to see how they perform in pairs.
I had some really terrible luck in this game, could barely pass a save or hit in an engagement and my formations got quite badly hurt in the end..... I didn't push forwards as a big wall of yellow as much as I should to put some pressure on Steve, I was just concerned about his retinues being better at fighting than my tactical formations!
PostPosted: Sat Mar 14, 2015 7:51 pm
Thank you. I'm always learning sonething reading this stuff
Thousand Sons Army Champion
My pueppchenspieler blog
Building a House Devine Army
