World Eaters vs Iyanden
 Post subject: World Eaters vs Iyanden
PostPosted: Sun Nov 08, 2009 3:43 am
Army Lists
World Eaters: World Eaters v1.3
Discussion thread: http://www.tacticalwargames.net/forums/ ... 82;t=16291
Iyanden V3.3
         Discussion thread: http://www.tacticalwargames.net/forums/ ... 24;t=14224
World Eaters 3000 points (8-9 Activations)
- Berzerkers(1) + Drop Pods
- Berzerkers(2) + Drop Pods
- Terminators(1)x6 +Teleport+ Daemon Prince (BTS)
- Terminators(2)x5 +Teleport
- World Eater Bikes(1)
- World Eater Bikes(2)
- Hellblades(1)
- Hellblades(2)
- Devastation Cruiser
Iyanden  3000 Points (8 Activations)
- Wraithgate  (used to replace Blitz objective)
- Spirit Warrior Warhost(1) + Warseer+ 3 Wraithlords (BTS)
- Spirit Warrior Warhost(2)
- Spirit Warrior Troupe
- Rangers
- Nightwings(1)
- Nightwings(2)
- Vampire
- Swords of Vaul – 2xFirestorm, Fireprism, 2xFalcon
- Storm Serpent
Note: All directions in battle report will be given from the standing point of the Iyanden Player
WoE = World Eaters
EoV = Engines of Vaul
Table
PostPosted: Sun Nov 08, 2009 3:44 am
WoE = World Eaters
Table
Garrisons:
Iyanden
- Rangers Garrison LHS centre craters (in ork building) - Overwatch
World Eaters: None
Setr Up
- Warpspiders LHS table
- World Eater Bikes(1) RHS behind Ork building
- Swords of Vaul centre table
- World Eater Bikes(2) far RHS table
- Storm Serpent set up on the LHS of the Swords of Vaul
Teleports: None
Turn 1
Iyanden win Initiative & elect WoE go first
- Hellblades(1) CAP
- Nightwings(1) fail and Stand Down
- Hellblades(2) fail and Stand Down
- Nightwings(2) CAP
- WoE Bikes(2) March down LHS table
- EoV fail to activate and decide to move towards WoE Bikes(2)
- WoE Bikes(1) remain in position
- Scouts remain on Overwatch
- Storm Serpent Doubles to middle table in front of scouts.
Rally Phase
- EoV remove BM
PostPosted: Sun Nov 08, 2009 3:45 am
Teleports:
- Terminators(2) behind Scouts – 1 BM
Turn 2
- Storm Serpent Advances on Terminators(2) for no hits
- Spirit Warhost(1) sustains and Charges Terminators(2) out of Storm Serpent for a FF combat. Combat sees Terminators reduced to one model after losing the combat by 6 and Skull Lord failing his Stubborn save.
Terminators woeful attack dice needing a 3+ to hit (yellow are Macro)
- WoE Bikes(2) March to centre of the table
- Scouts decide to go on Overwatch again (to use an activation)
- Devastation Cruiser activates.
- Barrage has no effect
- Pin Point Attack causes 2 wounds to the Storm Serpent (breaking it)
- Drop pods land in front of Spirit Warhost(1)
- Berserkers(1) charge Spirit Warhost(1). Scouts enact Overwatch for no hits. Berserkers cause 8 HtH hits with Iyanden player making 7 saves and then an extra reinforced for no deaths. 2 die however due to FF. 3 Berserkers are killed in the engagement  with Iyanden player winning the eventual combat by 2. Berserkers make their Stubborn saves and retreat.
- EoV Advance on Berserkers(2) killing 1
- Warp Spiders retain and Charge Berserkers(1) for a clipping FF engagement. 3 Hits see 3 Berserker deaths (this is not the WoE’s day to roll dice). The retaliation sees 1 Warp Spider death. WoE lose combat by 3, and 2 more die due to failing the Stubborn rolls.
- Bikes(1) Advance behind an Ork building
- Vampire Raider come in to land. Hellblades(1) enact CAP. Firestorms AA killing 1 Hellblade on the approach. Hellblades continue CAP causing 2 hits on the Vampire Raider which are both saved.
- Spirit Warhost(2) retain out of Vampire Raider and charge Berserkers(1) for a FF engagement. Berserkers kill 1 warithguard before being totally wiped out.
- Hellblades(2) GA Spirit Warhost(1). Firestorn fires AA for no hits. Nightwings(2) enact CAP killing 1 Hellblade. Surviving Hellblades continue with GA for no hits yet their fire was enough to break Spirit Warhost(1).
- Nightwings(1) fail to activate and Stand Down
Rally Phase
- All units rally other than Warp Spiders who fail to remove BM
Teleports
- Avatar appears in front of Spirit Warhost(2)
- Terminators(1) appear in front of Spirit Warhost(1)
Turn 3
WoE win the Initiative
- Terminators(1) Charge Spirit Warhost(1). A most disappointing roll of the dice produce only 2 MW hits from a total of 7 MW attacks. To add insult to injury, both the MW save. Normal hits however see 3 dead Wraithguard. Terminators lose the combat however (at this point I – as the WoE player – was getting tired of all these woeful dice rolls)
- WoE Bikes(1) retain and fail, therby gaining a BM. Using the Blood Rage rule, they charge the Avatar throwing caution to the wind. They cause 6 hits for 2 wounds and no critical. Avatar responds with 3 hits + 1 MW. Skull Lord takes the MW hit ands dies
At this point I decided that there was no way that the WoE could offer any more resitence and called it end game at this point.
Game Over
Iyanden: 3 (TSNP, BTS, DTF)
WoE: 0
Post Game Thoughts
Not winning the Initiative really did hurt the assault results for the WoE in this game. Follow this with 2 hours of woeful dice rolling, and facing Wraithguard with all their shots and reinforced saves, and the game was over by the end of turn 2.
The list I feel plays fine. I made some mistakes in regards to the Storm Serpent and next time I will know to concentrate on that in the future.
I also have to remember that Skull Lords have Fearless and should not take on any extra hits from Assaults or fired on when broken.
On a final note, I personally believe that the Wraithguard are underpriced for their abilities. MW at FF range is more powerful than MW at CC range as you effectively add another 15cm to the charge range for such attacks. I will however take such observations/discussions to the Iyanden forum.
PostPosted: Sun Nov 08, 2009 3:56 am
And you shouldn't use pink Slaanesh dice when playing a Khorne army  :grin:
PostPosted: Sun Nov 08, 2009 4:09 am
You are correct there.
I will rectify that by looking for more dice colours.....   :)
PostPosted: Sun Nov 08, 2009 10:22 am
Game Thoughts
Frogbear does seem to have a fair bit of bad luck for his games with the WE.
Take at least 2 Storm Serpents (although I feel they are expensive)
Winning Initiative 2 helped for sure, could have been stuffed if I had not.
I like the Iyanden list even though it is  army pts wise to play, and more often then not find myself with very little units on the board.
PostPosted: Sun Nov 08, 2009 10:37 am
My question is why a Chaos Legion and Eldar were fighting in the middle of a Ork city? And where are the orks?  :grin:
My NetEA Lists:
Fir Iolarion Titan Clan List
Dark Angels List
Always looking to Trade!
Angel's Trade Thread
PostPosted: Sun Nov 08, 2009 10:40 am
Frogbear thought I was turning up with a Feral ork army, like I have done for the last few months.
:cool:
PostPosted: Sun Nov 08, 2009 11:10 am
What better place to have a fight than in the slums!
"Black Hawk down! Black Hawk down!"
Users browsing this forum: No registered users and 62 guests
