Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
Marines vs Tyranids v9.2.1
 Post subject: Marines vs Tyranids v9.2.1
PostPosted: Mon Jun 08, 2009 7:21 pm
Hypothesis testing, 101.
Only in this case we are looking for a consensus as any 'evidence' is going to be purely subjective opinion, surely? So, there is no 'proof' in a scientific definition of the word.
Though I am open to suggestion of how we can test the warriors while controlling other variables.
PostPosted: Mon Jun 08, 2009 7:45 pm
To a degree, yes... though army design and game design does bear a sharp resemblance to hypothesis testing in a pure form:  all it takes is one 'problem/loophole' to break the game...  and one killer army design to begin to spawn variations.  So far, however, this change doesn't seem to break the game or the armylist, it  just stresses it in a different  set of direction.
As such, you're probably right -- there's a heavy dose of subjectivity involved: some people will like 9.2.1, some will not.  My focus, however, is not so much the like/dislike, but rather the places where the warrior = LV fails to meet its stated aims or -- objectively -- seems to have required further tinkering to rebalance the list.  As you suggest, part of the issue with the change is that other variables were decidedly NOT held constant, and in fact seem to have been tweaked as well, arguably to counterbalance the warrior = LV.
Frankly, my problem with the Warrior = LV change is not necessarily in and of itself, but rather as a part of a complex of changes:
1) As Hena notes, it's not clear what problem the warrior = LV change was intended to solve... To the extent that Chroma states that problem, we move into the realm of testable hypotheses.
2) It's notable that warrior=LV was accomanied by changes to buff gaunts -- this was symptomatic of one underlying issue, which is that an infantry-type synapse node was previously a core component of some 'Nid army lists, and gaunts lose a portion of their function without this component.  FWIW, It's not clear why Inf-type synapses were seen as a problem.
3) One bigger problem, given the 'shoot the big ones' rationale for the change, is that the change fails, objectively, to achieve its goals: one result is likely to be a nid army entirely made up of AVs and LVs -- raveners replacing Gaunts as synapse-shields, with the added benefit that they shield both the 'big ones' and the 'bigger ones.'  NB.  This is a result that is largely 'theoretical,' but this is in part because the new armylist emphasizes raveners: a set of miniatures that do not actually exist except via conversion.
PostPosted: Mon Jun 08, 2009 9:39 pm
This I definatly do agree with.
Though we have not found a 'problem' with LV Warriors (as our player includes AVs in all his swarms), they also do not make much sence in the context of the Tyranid List.
Was there a big problem with the INF only swarm in earlier lists?
PostPosted: Tue Jun 09, 2009 1:35 am
Not that I was aware... and I was following the list development pretty closely, perhaps starting with 7.xx.
Dave was certainly doing well with hordes of teeth and claw, but the 1/2 gaunt rule only made life easier for him.
I have to admit, I'm still not sure I understand the basic rationale for the change -- beyond the effort to be more fluffy in allowing for 'shoot the big ones.'
PostPosted: Tue Jun 09, 2009 1:41 am
That's the rationale.
I was reading through the Anphelion Project and looking at the comparative sizes of Tyranid Warriors to other creatures and opponents and realized they towered over Gaunts... there were *much* bigger than "human infantry" as well; I couldn't imagine them "hiding" or being screened by mere Termagants.
Seeing them "in action", in DoWII also reinforced that perception.
PostPosted: Tue Jun 09, 2009 2:13 am
In the Anphelion Prroject the following stats are given:
Tyranid Warrior Average Height: 2.4m
Gaunt Average Height: 1.3m
PostPosted: Tue Jun 09, 2009 2:56 am
You know that a 7'10" TW is 4" taller than Yao Ming.  And 12-14" taller than Osama Bin Laden.
I'm a little skeptical that four to fourteen inches of height justifies AT targeting -- i.e. targeting with specifically armor-piercing weapons.
PostPosted: Tue Jun 09, 2009 3:35 am
Marines are 2-2.5m... Where is FW pulling that number from?
Comparing TW size to that of guants to justify their LV status isn't an overly compelling argument. I could just as easily argue to compare them to the Zoanthrope and Lictor models. Warriors are much smaller than those, shouldn't they be INF?
In any case, as Cary has pointed out before, this change has felt like a change for changes sake more than anything else. There was no widespread outcry for LV warriors prior to 9.2, no one cried out when I subjected them to all guant and INF warrior swarms.
PostPosted: Tue Jun 09, 2009 10:04 am
Must say given the size of the other big beasts can we abstract out the shoot the big ones thing? Though its neat it affects epic more than 40k with the effect on the swarm.
PostPosted: Tue Jun 09, 2009 11:40 am
I personally will play a few more games with the LV rule than make a decision on whether it is a useless rule for EpicA or not.
I think others should do the same with some examples of how a player or an opponent has taken advantage of such a rule. So far I personally have not seen an example. It just means that I have to hide them better than I otherwise would.
If the price was lowered as Chroma suggested, even better. There have been times where 25 points has changed the structure of a swarm for me at least.
