Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
Epic Splinter Fleet Churoninx
 Post subject: Epic Splinter Fleet Churoninx
PostPosted: Thu Jan 08, 2009 11:52 am
1) Removing different common brood units from the front of a swarm will probably change the makeup of the swarm, which can significantly affect the way the swarm works. (This is also true for Orks and any other race where there are several different unit types within a single formation).
Enemies shooting at the formation will be detrimental to it's health and ability to fight- what's new here?
Every other weapon shots are front to back, yet formations manage to continue fighting in the game.
2) Taking off units that can shoot off the front of the formation obviously reduces the effective shooting range of the formation, while removing units from the centre does not.
There are good points and bad points to such a change in template rules, simply different one's. The aim is for an easier barrage rule, not to give one side or other an advantage.
So yeah, your shooting range is reduced- just like when every other weapon shoots at the formation. The plus side is your 'front' is usually your bullet shield Grots, etc for that very reason.
3) Blasting away units from the edge of the swarm usually has much less impact on the swarm than removing units from the interior because of the rules around coherency and control.
Good and bad points.
Also there is no real problem with multiple weapons, providing you remember to allocate all the hits before resolving them, allocating the hits under the template first and then all remaining hits as per the rules. In the UK tournaments we quite often use small dice to indicate the units affected when allocating hits, which both speeds up and clarifies the process.
Oh don't get me wrong, the current system works- it's just clunky and convoluted.
I have to place template, argue over what's the largest number of targets, trying to snipe important units, roll for each unit under, allocate it a hit individually, do this for each template- very fiddly, time consuming and snipish. Then I need to do other shooting separately, following different (the normal) allocation rules.
It works, it's just takes much longer for no real gain in effect.
Under the change, I place template, count up the number of infantry/AV hit under it, then add those dice to my other shooting. Roll all and give the opponent the hits to distribute. Same number of targets hit, so much easier and intuitive with the normal allocation rules.
PostPosted: Fri Jan 09, 2009 3:01 am
Edit:- just reread your reply, And I think I can see where you may be mistaken about the 'book' method.
You place the template (possibly with some discussion etc), and then you determine the number of infantry, vehicles and titans there are under the template and throw the relevant number of dice for them. No distinction is made for the types of infantry or character while dicing for hits or allocating them front-to-back under either approach.
The only difference is where the hits are allocated front-to-back; under the template or not. It is this aspect that can cause significant differences. In the case of the 'Nids this raises the possibility of killing a Warrior in the middle of the formation, which would not occur if the hits are allocated to the edge of the swarm. For Orks it potentially 'misses' Grots placed to protect warbands from the effects of shooting and assault, potentially changing the way the formation behaves later in the game.
However, I agree that for the vast majority of Races and formations the difference between the two approaches is negligible.
PostPosted: Fri Jan 09, 2009 6:04 pm
Agreed.
With the changed method being quicker and easier.
Also Grots and Expendable troops are factored into an army as their 'trait', something to make them more durable instead of just better Armour Saves- so why do Barrage weapons get to ignore this intentional 'meatshield' effect, where every other weapon must go through it?
It just seems unnecessarily fiddled, just for the added hassle of sniping important units.
PostPosted: Fri Jan 09, 2009 7:28 pm
Agreed.
We will have to agree to disagree on the relative speed of the two approaches as it boils down to where the hits are allocated and testiing armour saves accordingly.
However, IMO the different mechanic for barrage weapons more closely reflects the way such weapons work while Orks and Nids etc need to adopt different strategies, tactics formations etc to counter or mitigate artillery, all of which provide a little more colour to the game.
However, I must disagree with you on 'sniping', because the barrage rules are specifically designed to allow the opponent to avoid or mitigate the effects
1.9.8 Barrages (last section)
Using Barrage Templates: Deciding which enemy units have been caught underneath a circular Barrage template is another one of the things that can cause endless arguments during a game. The method we use (and the default you should use unless you have a different convention that you prefer) is that a unit is affected if any part of the model falls under the template, or at least one model on a stand. In addition, templates must be placed in such a way as to get as many enemy units from the target formation under them as possible within the restrictions for lines of fire and range. This stops players ‘sniping’ at important units with artillery.
(my emphasis)
PostPosted: Sat Jan 10, 2009 3:04 am
As the Eldar player in question, perhaps i could provide a little more information on the game being described.
Terrain:  Looking at Chroma's bat-rep, i'd say that we had as much terrain, it would certainly have been a challenge to lay any more down.
The centre of the board was dominated by a moderately large cityscape and 2 big hills, one of which was craggy and provided a 5+ sv forming a narrow series of valleys.
I deployed my objectives, just in Jeridian's half of the table, just over 30 cm from the board corners (Alternately with my opponent of course).  This meant that my objectives were deeper into my half and there would likely be a central one to be replaced with the webway gate and also that my opponent's garrison's would be split up and very far from any support from each other and the bulk of his army.
During the first turn i picked apart the isolated garrison units - concentrating on supressing and subsequently destroying the biovore thingy unit with artillery and air units.
Using my first 2 activations on aircraft and the void spinner meant that as well as pouring fire into the isolated garrison unit i could wait a little to see how the Nids would move the bulk of their forces.  The objective set up kind of forced both our hands really.  The nids pushed en-masse down the centre into the narrow valleys whilst i spread out into a crescent fm (My tactic of choice tbh).  Making the most of the speed advantage i clustered my forces close to the main nid line of advance.
At the start of turn 2 i won the initiative as i gambled (Fairly safely really) i would and after loosing a barrage with the void spinner, retained and initiated an assault on the large fm of nid infantry advancing down the narrow valley, parallell to the one the Dominatrix unit was marching down.  Using the commander ability and my speed i managed to get my aspect unit, a falcon troupe and a powerfist Phantom titan into engagement range whilst avoiding supporting fire from the Dominatrix unit.
Well needless to say it wasn't pretty with nids having little to no FF power.  The 3 units then moved backwards their full movement to avoid engagement based retribution from the Dominatrix fm - which followed the eldar and loosed a really nasty flame template weapon causing many, many blast markers on the aspects and coming horrifyingly close to breaking them.  This however put the Dominatrix unit into the same valley of death as the - now dead gribbly fm had previously occupied.  Using a left hook maneuver with my flanking force i marched a SS to the other end of the valey and deployed guardians from the webway catching the nids in a deadly crossfire. Jetbikes and falcons moved up into supporting fire position with the main nid advance completely surrounded. The Harridan engaged a falcon unit but found itself within supporting fire range of the Phantom and was promptly beaten, although the falcons in turn broke and ran.
Turn 3 and i summoned the Avatar towards the rear of the valley of death.  Again, winning the initiative i opened fire with the void spinner onto the tightly packed nids, retained and sustained fire with the Phantom who was less than 30 cm away from the dominatrix and put 6 wounds on it and then retained a second time, using the avatar's commander ability, sending the guardians and avatar into assault with the nids.  With supporting fire from 3 units (Jetbikes, falcons and SS)set up precisely for this purpose at the end of the last turn and the avatar's awesomeness the nids suffered horrendous casualties and broke and fled to be harried by strafing runs from the Vampire in subsequent activations.
With the bulk of the nid army dead or fleeing Jeridian really had very little left with which to activate and mount an effective comeback.
What won this for me i think was the superior maneuverability of the eldar, crafty objective placement and an almost garaunteed first activation.  The skimmer issue was an amusing (For me anyway, lol - sorry Si!) sideshow but IMO wasn't really a deciding factor, although i would definately have taken more casualties during engagements, i'm pretty confident that i had stacked things very much in my favour.
It's worth noting that i've had quite a bit of experience with Eldar now and am really starting to find my feet, whilst this was the first outing for the nids.  I wish we'd taken pictures of this battle TBH as i do find Epic battles quite hard to describe.
I can definately see why Eldar are such a frustrating army to play against for nids.  The combination of high speed, excellent FF values and almost certain first activation potential makes eldar very well suited to taking on nids, especially an inexperienced Nid player (Although i'd never fought against nids either).
All that being said i did enjoy the game and my opponent was a good sport throughout and using his guard in the next game gave me an extremely tough game that by rights he really should have won (I think his dice hate him, lol).
PostPosted: Mon Jan 12, 2009 12:46 am
Aye, I plan to deploy on my Blitz with these in future.
Not much I could do to prevent this, the whole point of a 2 activation maximum is that your opponent can't be royally screwed before he can do anything...
If I used Nids against Eldar again, I guess I'd sit back and wait for them to come to me. Likely they wouldn't, just sitting back ready to grab objectives. Then it would be a case of turn 3, can I hold my objectives, can the Eldar repel me from them.
The best I can aim for against Eldar is a stalemate, or draw.
The ability to jump into weapon range, shoot, then jump out of my assault range.
The ability to ignore all terrain, even to move to the edge of some terrain, pop-up, shoot, then pop-down behind it without retaliation.
The ability to activate 3 times, with portals.
The free Avatar.
Superior mobility.
Guaranteed first activation (first 3, even 5 if you count Commander, activations to be precise).
I agree that you would have won those engagements without the Skimmer immunity, I call rubbish on the Skimmer immunity being a non-factor in the game. It was huge.
Imagine me telling you your Falcon Troupes cannot hurt any of my formations, ever. That's Genestealers/Lictors.
Then telling you instead of the 3+ and Macro Weapons you paid pts for, you can only use a few 5+ rolls instead.
It's a frikkin huge deal when half my army literally can't hurt you, and the other half is severely weakened more than normal when it can.
The Skimmer rule is the reason I stopped playing Eldar in 40k, it sucks any tactics out of the opponent's plans, he simply is outclassed by better units that are immune to his.
It would have been even more confusing, I was using SM models to proxy Nids.
I think the Skimmer immunity cannot be understated, essentially I'm fighting with half a weakened army. Eldar are frustrating to play regardless of army used, there is no rock to Eldar scissors.
Play defensive, and play for a draw is all I can find.
I was outplayed, as I've said before, even if all the special rules and Skimmer immunity was removed, I was encircled, and you managed some elaborate combined Engagements. The difference would be I could put up a fight.
'Should have won' is my epitaph, I appreciate the vote of confidence. I'm planning to use my opponent's dice, just for a change.
If I've not mentioned it here, my IG. My Shadowswords moved through cover, rolled a 1, rolled a Critical. The 2nd one is clipped by a single Falcon shot, another Critical. Not fired a shot yet...
That sums up that game.
