Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
Biel-Tan sv Adeptus Astartes
 Post subject: Re: Biel-Tan sv Adeptus Astartes
PostPosted: Sun Apr 02, 2017 10:36 am
That mix is very solid against eldar - especially if you make them play corners as you can then use the deployment of the warhounds to drive the eldar player under the barrage - similar to how eldar can use void spinners to push players into deploying under an orbital barrage. Orbital bombardments doing that level of damage is slightly above par but not unusual - especially if you're deploying a lot of formations on the table. When I play as Eldar I tend to try to limit my number of on-board formations so I can more easily bunch up and hide in very small spaces!
PostPosted: Sun Apr 02, 2017 10:38 am
Kyrt wrote:
Sounds slightly lucky to get so much of the BTS under and also 2 EoVs but only slightly. Remember that the pie plates can cover a window of 36cm so the chance of avoiding depends very heavily on how much you have to deploy. Against a 100% ground pounding biel tan army with no less than four infantry formations, including 2 bike formations that take up quite a bit of space, you are going to hit something. Bikes also cannot use buildings as cover (and risk dangerous terrain tests for being in it), whereas guardians desperately need to be in cover. If you want everything in cover then it has to be bunched up together intermingled. If you want to spread out then you have to take your chances in the open, simple as that. I would have put them behind a hill if i could, to try to stop them being macro'd by the warhounds, but it would be unavoidable that something is exposed, and fairly predictable that something was behind that hill.
Sent from my SM-G920F using Tapatalk
Kyrt has the right of it I think. The BTS was hidden behind ruins to make sure the warhounds wouldn't have a clear shot at them even on a double move but where unfortunately nailed by the second template from the strike cruiser. The two scorpions where setup close to each other so the first template got both of them. This BT list takes a lot of space in setup so you are mostly guaranteed to hit something and hitting the non warengines is generally preferable then the other way around.
I'll try to get the (few) pics today so you can get a better view of the setup and answer any questions you guys have.
PostPosted: Sun Apr 02, 2017 2:52 pm
Not Lego's game, but think where you'd place your bombardment if facing Eldar. In this game the Eldar were forced to the top right corner deployment.
