Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Black Legion V/S Steel legion. 4k points.
 Post subject: Re: Black Legion V/S Steel legion. 4k points.
PostPosted: Mon May 30, 2011 11:55 am
Tim_nz wrote:
Great report with some excellent pictures, down with chaos !!! haha
just on a side note i see the imperial mech company has 2 hydras ? thought you could only add one to the company as a upgrade ?
Tim NZ
Thanks Tim! I've added two idra in the mech infrantry company, for defend the left side from aerial attack that is never arrived, because in the chaos army wasn't flyer.
The Imperial army list, deployed against the Chaos Horde, used by me, is the following:
1trd point on war engine and flyers.
1 warlord titan
1 warhound titan
1 infantry company
upgrade:
3 x 2 ogryn.
Support:
1 shadowsword
1 shadowsword
1 mechanized company
upgrade
- 2 x hydra
Support:
1 leviathan
1 horseman
1 tank company
upgrade:
- 2 x ogryn mounted on 2 chimera
Support:
- sentienl platoon
- veterans on valkyrie
I've splitted my army as following, the valkyrie and the mechanized company outside the city,
for use thier high speed for flank the enemy, and all the rest 15cm based division, to procede
and create a line in front of the main force of chaos. But, my strategy to hold the imperial line
with the sentinel had failed, because the chaos army had arrived more near my line... at the end
of the 3rd turn was a draw, 1 to 1... I was very luck! The chaos player had failed to regroup his 3
company of chaos (2 terminator and 1 legion)... without this luck, is sure that I was condamend to
the extiction... I've loose the 70% of my army... was a terrible carnage!
Orkonia: http://goo.gl/j6Q3v
PostPosted: Mon May 30, 2011 4:41 pm
CRONOmoment.
PostPosted: Wed Jun 08, 2011 3:25 pm
now i know why you had two hydra's. if it is your groups option to use multiple upgrades of the same kind then go for it, but in the rules it says for guard.. each upgrade can be taken only once. So no x3 ogryn's. Heck, i would do it but my opponents here would get rather mad at me for not following the rules. To each their own. great terrain again. I need to turn my unpainted Commisar Yarrick into a statue. i like they way they look.
PostPosted: Fri Jun 10, 2011 7:38 pm
ehhehe... it's true, but all this match are not exactly tournament.
In play, we have see that this kind of difference in SL army list don't create some strange things.
Now I'm creating a rule set, published in the section EA strategy and tactics, for create a campaign like RISK. ...and I think, that should be great!
Not only battles... but a war.
here: http://www.taccmd.tacticalwargames.net/viewtopic.php?f=95&t=20786
