Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
BL "Daemons" Vs Orks
 Post subject: BL "Daemons" Vs Orks
PostPosted: Sat Sep 06, 2008 4:08 pm
Quote: (dptdexys @ 06 Sep. 2008, 06:30 )
I agree it could do with an FAQ or a comformation from NealHunt.As if it is played with the attackers still get -1 for cover they could technically claim cover from being in base contact with enemy vehicles they are assaulting,though that would be a very mature Brie situation not just cheesy  :vD
The rules used to deal with this situation. They don't now :-)
Part of the reason was that it added a level of abstraction and complexity to the game that wasn't deemed to be appropriate.
I think that perhaps we might want an FAQ entry that says that in the case of OW fire against a charging unit that the unit can't claim cover due to its movement as per the rules for Assaults.
The implication there is that the assaulting formation can't benefit from the cover due to moving and I think we can extend that for a OW fire at assaulting formations as well.
PostPosted: Sun Sep 07, 2008 1:25 am
Some observations from the BL perspective
Supreme Commander
On more than one occasion during the game I remarked to Alansa near the start of each turn that I was going to attempt something slightly risky, knowing that I had a Supreme Commander reroll to bail me out. As some know, I tend to have poor luck with my dice, and yet often play Eldar without an Autarch (Eldar SC) because I can never decide whether to use the reroll or not. In the BL games to-date, I do not think I have missed an activation at all, and only rarely needed the Re-roll. I tend to be a little 'reckless' in my games and having the Reroll certainly encouraged this tendency.
As the BL have such good initiative and Strategy ratings, I suggest that they can easily do without it. Consequently, IMO the SC ought to be optional in line with the Marines, though possible costed at 50 points rather than 100 points.
Strategy and initiative
This is one area that is key to the success of the BL, allowing them to pre-empt the opponents strategy. In this game, I was able to do this in both turn #1 and #2 by using pre-emptive strikes on key formations in my first activiation (which I successfully retained). In this game, one Chosen formation got stopped by OW, but had it succeeded, the game would have essentially been ended much sooner. Alansa and I did discuss this briefly after the game and felt it was an advantage that the ability to summon Daemons only compounded.
IMO (and I think Alansa agrees here), finding a way to reduce this initiative would be helpfull in redressing the balance issues. While it would probably be unacceptable to do so accross the board, a suggestion would be that the loss (or absence) of the warlord reduces the initiative to +2.
Daemons
As they stand I am begininning to think they are just too good. With the initiative advantage, BL formations can mount crippling attacks with fairly mundane formations. The lack of mobility that ought to be a problem does not seem to be as big a draw back as was felt to be the case.
Daemon Prince
And why would you not want to take as many as you can??? They act as a form of shield absorbing hits, provide additional attacks and add inspiring to the formation (apart from being Fearless as well). In this game I mistakenly declared two Khorne DPs, but in practice one was assasinated so actually this caused no issues at all. Otherwise they performed 'as advertised', killing stuff in assault, and saving hits in return.
The "Flappy" DP also had an unexpected use in Retinue #2 by providing a spare slot in a Rhino. This allowed the formation to march to a strategically usefull position by dropping a single unit - I would have been much more reluctant to drop two units
Raptors and Bikes
6-8 Raptors seem to work well, but smaller formations are too fragile. In this game they were able both to make use of their speed to take a good position, and also win the subsequent assault.
Both formations are good for harrasing and with 4+ FF, they are good for supporting assaults as well. Bikes seem less usefull, maily because they have to drive round terrain rather than flying over it.
I have not put pact on either formation yet, but have a horrible suspicion that an extra 4x Lesser Daemons would make them both big-time killers, especially if the daemons had long distance assault capabilities.
Factions
The "Hated" rule has no effect, or at least it is easily overlooked in the heat of battle. The 'Factions' only really force you to decide on what type of Daemon you want to employ for given formations, and can this be a little confusing. In this game, I tried to use "CC" daemons for the Chosen and "FF" daemons for the Retinues both to give them more tactical flexibility and reach.
In practice, Retinue #1 really shone because the "FF" daemons virtually doubled its firepower and reach, while I did get a little lucky with the armour saves shrugging off the few hits in reply. As such it really dominated the centre-right of the battlefield.
Conversley, Chosen #1 with the "CC" daemons did less well after their initial success, so arguably did not earn their points other than to provide the Stompa mob with a little target practice.
In summary, while I really like the 'chrome' provided by Factions, it does add a level of complexity that can be confusing. I can't help feeling there ought to be better ways to achieve this, though I cannot think of any at present.
PostPosted: Sun Sep 07, 2008 1:53 am
There remains the problem that the list has been tested for more than two years with the SC as is and every game has used him. If you remove it as a free option and then add it at a cost then we've effectively removed 50 to 100 points from the army and that needs to be addressed if you want to remove the option and reprice it.
You also basically just said that it wasn't of any use to you so why is it then an issue?
So you want people to pay for something that you didn't find of much use?
How is this any different than the Marines or Eldar? Its only one better than the Feral Orks.
And winning the strategy roll and smacking your opponents most threatening formation is a core part of the game so how is this some problem unique to the CSM list?
Is this based on the game where you ignored the crit to the GD that sucked away a pile of daemons?
The "initiative advantage" is also not an "advantage" it is a part of the army list and is shared by several lists. So if it is an "advantage" for the CSM then it is an advantage that needs to be addressed across the entire game.
And since the Eldar can effectively win initiative and then move with three formations, including a free Avatar, I can't see how this instance is a problem that is unique.
Probably needs to be addressed but we have a list of changes that we need tested right now and this could probably be fixed rather easily with a cap on them.
I have to say that it is a bit perplexing why you and Chris chose to test a series of things that weren't in the suggested changes list and instead focused on daemons and DPs.
Its nice that you want to test but perhaps you could do us all a favour and test the changes we have on the plate instead of adding more issues.
Not sure how you are taking a "spare" Rhino since the DP can't be transported in it and therefore you shouldn't be allowed to purchase it. I also think that you're stretching to make a point here. Does the CSM list now have a "March advantage"?
PostPosted: Sun Sep 07, 2008 8:06 am
Because the flappy DP moves 30 it doesn't need to use it's rhino slot that it would normally take up alongside a normal unit. When I bombed his retinue the first time I killed one rhino. Normally this would have left 2 units stranded. However since the DP was not using his rhino slot Ginger only needed to drop one stranded unit.
A comment on amazing initiatives. Normally they shouldn't be allowed. 1+ initiative is ridiculous in most cases, unless really needed it. Space Marines *do* need it in most because their formations are small. It is vital that they perform 'duo' maneuvers, otherwise they will fail. These are duo moves are extremely helpful to other armies too, but they can do without from time to time. Marines can't. I would suggest that Chaos marines *can* make do with flat 2+ init and I would suggest to Ginger we try that out sometime?
BL are 1+ init because you'd never be a fool to declare hated factions (unless you wanted lots of demon princes). At the least it makes applying the rules simpler both for you and your opponent. Like Ginger, I feel that the hated factions rules are nice chrome but fussy faff. I'm less than inexperienced with BL though and this is really an inititial reaction - I could change my mind about that in the future. Ginger's suggestion of +1 while the warlord is on the table seems simple enough, but then it turns into a real assisination victim. Want to try that as well mate?
PostPosted: Sun Sep 07, 2008 9:15 am
Quote: (Ginger @ 07 Sep. 2008, 01:25 )
Daemon Prince
Gavin - the Daemon Prince isn't inspiring.
How can you effectively use them without putting them with Chosen?
Put them with Chosen and you run the risk of losing strategy roll and of overwatch - as you yourself have found - paying 115 pts for DP adds to the gamble
On foot with retinue - end up just guarding an objective
With wings and retinue+rhinos - end up walking anyway as rhinos get sniped so never make combat either
Whilst you've talked about DPs and BL tourney results they are largely unconnected - the majority of BL points are from myself and Nathan. Nathan has never used a DP - and has dropped the Chosen too, I used a DP at 2 tourneys - FSA+CC- and in 8 games the DP was involved in 3 assaults - so I have dropped it too - for the London tourney (and have stripped down my chosen to go after soft targets)
www.epic-uk.co.uk
PostPosted: Sun Sep 07, 2008 1:40 pm
Latest proposed changes for the Daemon Prince have dropped TK from the assault stats, but added 'Inspiring' by way of compensation - which is what we were playing. IMO, this actually increases the power rather than decreasing it as I get into more assaults, though PG (and others) prefer the TK ability for going after "hard" targets.
So far I have played Retinues with them mainly on foot to start with - which allows them to garrison off an objective. Even if that is the Blitz with one straggler 15 cms away, this allows the main body to be positioned some 20-30 cms from the table edge, and so able to double to the centre of the table in the first turn. Using other objectives you can get even further.
With a "flappy" DP, as TRC has said, you can get better coutercharge and it also allows the DP to be in the front of any assault irrespective of the original position in the Retinue.
And the high SR with high initiative does mean that you will get to play first at least three times out of five for all opponents except Eldar and Marines, Less of a gamble than it seems IMHO
PostPosted: Sun Sep 07, 2008 3:12 pm
When Gavin played these games the DP was to have Inspiring(from proposed changes) but the Lord I's playtest list doesn't include it for the DP.
PostPosted: Sun Sep 07, 2008 3:29 pm
This is really hardly any sort of big deal though.
I don't see how the initiative rating is "ridiculous" or why it shouldn't be allowed. Your basing a lot of this on your own opinion and preference it seems. You don't think they should have them and don't like them but how do you respond to people that don't have the same objections?
Not a lot of people disagree and they are proposed to be removed in any case specifically since they have so little effect.
PostPosted: Sun Sep 07, 2008 3:33 pm
So? Everyone can do this?
You guys are bringing up points that apply to a lot of, and sometimes all, armies in the game as if they were problematic and I really can't see how this is the case.
Ever seen an Ork player use this same tactic with 'Uge Mobs? Its ugly as hell.
PostPosted: Sun Sep 07, 2008 3:36 pm
It also means that he is then away from a lot of support and sometimes on his own in assaults.
In either case this isn't in and of itself problematic.
And most of those armies are used to not getting initiative in any case. I know I don't expect to win it with my Guard army and I suspect that any Siegemasters force never expects to in initiative.
As you yourself mention, two of the armies in the game have the same or higher SR and there are others that are within a point of the CSM SR so ho is this an "advantage" for the CSM army?
PostPosted: Sun Sep 07, 2008 5:37 pm
Agreed. Neither I nor Gavin said it was.
By default no army should have 1+ init without real justification. Yes this is my opinion.  Perhaps 'ridiculous' is an overly emotive word, 'extreme' would be better - Available to only the most discliplened and tactically superior warriors - such as marines and eldar aspects - and needed too by  forces inferior in numbers but superior in tactical prowess.
In this Chaos Marines are slightly less than their Loyalists. They have certain bad traits (faction hatred being one of them) and a legion mentality.  Indeed in some respects one might argue that Imperial Guard, thought perhaps less brave (read arrogant / foolish) are probably more professional chaos marines. Lastly I wonder if they can get by without it - reason enough to ditch it. Do you think they would be seriously nerfed at fixed 2+ PG?  I do say that I would not be dismissive of your opinion on this matter but perhaps the 'free' Supreme-Commander re-roll makes more sense with that initiative level.
Note, as already stated, I am as yet undecided on these matters. They are merely questions in my mind - things to wonder and think about. No need to bundle me in with the chaos nay sayers. I am far more 'on the fence' than you have assumed.
[QUOTE]Quote:
Like Ginger, I feel that the hated factions rules are nice chrome but fussy faff[QUOTE]
They do seem more hastle than it is worth.
PostPosted: Sun Sep 07, 2008 6:26 pm
I think it has more importance for Lost and Damned, where it means you are limited to choosing daemon engines from a maximum of 2 factions rather than mixing and matching at will.
PostPosted: Sun Sep 07, 2008 7:58 pm
Ini 2+ will lead to BL formations failing engage actions all the time (a BM is granted when you are that close to the enemy, so you have to roll 3+, 4+ on the retain).
Ini 2+ is the reason why I have given up on kitting my LatD armies for assaults, they fail constantly, usually hideously exposed out of cover and close to the enemy.
If you want to ruin the list, that´s the way to do it.
IG can cope much better with failed action tests since they can Hold and the shoot to good effect, BL can´t.
PostPosted: Sun Sep 07, 2008 8:24 pm
Ok good reasoning Irondeath. We can see a general principle here then: Armys that are not very shooty (eg space marines) require 1+ Init because they cannot shoot their way out of command cock-ups.
You forgot about the Warlord though. My suggestion was that the Warlord's free re-roll helps to compensate much as an Ork warlord helps orks in their command failures (especially when doing tactical shooty moves)
Grant me license though, Irondeath, to perhaps have a little test with Gavin sometime to see for myself.
Note also that BL *is* a 2+ Ini army. It is only made 1+ by the slight-of-hand of avoiding hated factions. If the intention is that it should be (by-and-large) 1+ then I think should say so,l with a -1 mod when near hated factions. As it is, it seems to indicates a general design intention of 2+.  Can anyone inform what the intention is? The hated faction rules seem to assume that they would be in use and have some real effect, and did not consider they could or would be easily avoided.
