Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
Another of Gavins Chaos battles!
 Post subject: Another of Gavins Chaos battles!
PostPosted: Thu Sep 04, 2008 4:57 pm
Quote: (Irondeath @ 04 Sep. 2008, 14:26 )
Side note, were there any daemons left in the pool to deduct when BL rolled a "1" for initiative in Turn 3?
Nope - they had all been summoned and died in turns #1 & #2, which is why I would probably add up to three more LD given the number of formations with pact (and/or reduce the pact).
However, this is a good reminder that this additional summoning bit needs to be watched
:D
PostPosted: Thu Sep 04, 2008 8:22 pm
Yes its a hard rule to remember, breaking as it does the cardinal rule of only having to remember good rules!
PostPosted: Fri Sep 05, 2008 7:36 am
Quote: (Ginger @ 04 Sep. 2008, 13:32 )
Quote: (Irondeath @ 04 Sep. 2008, 13:03 )
Thanks for the report.
I would add that it seems you had an exciting, balanced game but I may be mistaken.  :;):
Well, I would tend to agree that this game was exciting and not totally unbalanced. But you should also note that, while we were in 'testing' mode, I won both this and the last game reasonably easily using the BL. You should also note that I have failed to get into the top '6' of any of the UK tournaments this year including Britcon - where there were only 10 players.
So I would start to get concerned if, despite my lack of skill and appauling luck with the dice, I continue to trounce TRC (and others) using the BL.
- - - and the other UK competitors may get worried if I start fielding the BL for real - -  :p
But didn't you lose the first game util you restarted? - also i doubt Chris or any other IG player would field that army in a game they wanted to win.
That you had to restart to show the power of the Chosen just shows the inherent gamble with them of the initiative roll and overwatch - why both Nathan and I don't follow this tactic.
Who has actually done better in tourneys using BL?
www.epic-uk.co.uk
PostPosted: Fri Sep 05, 2008 9:01 am
I like facing BL :devil: , just ask Steve and Nathan, but not Kev :sulk: .
Its Obliterators I can't deal with.
PostPosted: Fri Sep 05, 2008 12:14 pm
Actually, we did not re-start so much as keep the GD alive to evaluate how strong he was. The OW fire and the loss of the GD did not actually break the Chosen, so we could have carried on anyway. Had we done so, the result of the assault would have been almost identical and the only real difference in the game would have been the Chosen dying slightly sooner. The point of this "suicidal" assault was both to see if they could get in and then to evaluate the power of the attack (accepting that the BTS would probably die as a result).
Also note that, were this a tournament game, I agree that both the armies and tactics might well be subtly different - for example, I might well have teleported against the shadowswords, and assaulted them after using a Feral to remove the vultures that were screening them. Given that these two formations were the ones that actually caused most damage to the formation, there is a good chance that it might have survived the game - but then given my dice, perhaps not :smile: .
PostPosted: Fri Sep 05, 2008 12:19 pm
If you check the Championship thread, you will find that you, Nathan, Mark Hargrave and Kevin Bott have all finished in the top four positions in the Uk tournaments to date (though not at the same time :smile: )
PostPosted: Fri Sep 05, 2008 12:40 pm
Well, if having a Bloodthirster charging was irrelevant to the results, why bother fielding one? I don´t think that is an accurate statement.
The Feral seems ill-equipped to handle to Vultures as well, since they are Scouts you´ll get only one under the template, doubling lands you at 4x5+ for the Death Storm, 1x6+ on the Hellmouth, you´d be lucky to make a single kill that way. Just for placing a BM I´d use a Forlorn Hope or somesuch.
PostPosted: Fri Sep 05, 2008 12:45 pm
Surely losing a GD and its 3x3+ attacks with 3x3+ TK attacks and Inspiring bonus along with the chance of it taking other summoned units back into the warp with it. Plus losing the possibilty of making more saves in the assault due to its reinforced armour would have had some effect in the result or why keep it on the table.
I won't call you surely again  :vD
PostPosted: Fri Sep 05, 2008 12:49 pm
Thats if the feral survived the vultures overwatch shots too.
PostPosted: Fri Sep 05, 2008 1:47 pm
Well, the inspiring DP was still there, the IG also lost 3-4 units (that would have been killed by the TK shots) and everything bar the daemons has RA anyway - so it's loss was less significant that it might have been in a weaker formation
Glad to hear that wonderfull line from 'Airplane' again :vD[/quote]
PostPosted: Fri Sep 05, 2008 1:50 pm
This is possibly why I don't do so well in tournaments :smile:  - and why it could be worrying that I still keep winning with the BL  :p
PostPosted: Fri Sep 05, 2008 2:13 pm
Gavin, the GD crit affects only daemons, so no 3-4 dead IG, or Chosen:
Critical Hit Effect: The greater daemon is hurled back into the warp and destroyed. Any daemonic units within 5cms will be dragged back into the warp with the
greater daemon and destroyed on a roll of 6.
PostPosted: Fri Sep 05, 2008 2:42 pm
Of all the theorising and bedating about the problems of the BL this is the truly worrying statement that may show a problem  :oo:
PostPosted: Fri Sep 05, 2008 2:59 pm
Agreed we can't have Gavin winning games. Somebody swop his dice again.  :p
PostPosted: Fri Sep 05, 2008 3:32 pm
Fair enough but he did go down and took daemons with him, and does so in games so perhaps if you want to use the game as a basis for commentary you might actually let the game flow naturally.
I think your comment actually makes the entire test game seem very biased. You left it in to attempt to show how powerful it is. And yet it wasn't as it died and took out a chunk of your daemons.
The game is skewed and I think you really sound as if you have an agenda with this test and aren't simply testing the game.
