Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Dark Eldar vs Minervans 4000pts
 Post subject: Dark Eldar vs Minervans 4000pts
PostPosted: Mon Feb 25, 2008 3:00 pm
You will find out about Fleet of Foot soon enough.... :p
PostPosted: Mon Feb 25, 2008 10:59 pm
Mhm. You used a wrong list with way too much MW. If you reduce the demolisher cannon back to 3+/4+, you will see it takes much pressure out of the list. Try it this way and you will see, the results will something very different.
PostPosted: Tue Feb 26, 2008 10:15 pm
I'm confused, who was this comment intended for?
PostPosted: Tue Feb 26, 2008 11:03 pm
Intended to the player of the Minervan list
PostPosted: Tue Feb 26, 2008 11:18 pm
That would be me then, how so a wrong list, you say too much MW, I only took 9 Thunderers in total and only 2 Executioners.
The remaining 23 Leman Russ's were standard pattern. As for the shadow swords and DS they were there to deal with with the Dark Eldar war engines of which their were 4.
The Thunderers did not do the bulk of the LR damage, that came from the standard variant. They were mostly a cheap tough activation.
PostPosted: Tue Feb 26, 2008 11:25 pm
"only" 9 Thunderer are only 9 MW4+ :). I am pretty sure they didn?t do most of the damage, but they add up nicely over time.
Maybe you are right, Thunderers are too cheap. Even with the standard Demolisher cannon they are too cheap.  Thats a point really worth discussing. 240 for 6 4+RA units seems a little bit underpriced.
PostPosted: Tue Feb 26, 2008 11:29 pm
Possibly, but for me the 60 point Standard LR are a bargain and probably underpriced. It wouldn't matter massively if Thunderes didn't have the MW its the 40 pts, RA and 6 strong platoons that make them useful.
PostPosted: Tue Feb 26, 2008 11:37 pm
Righjt Thunderers are too cheap. make em 50 without MW and they are OK. Also helps avoiding the abusive use for saving point issues.
