Help a new warboss
 Post subject: Help a new warboss
PostPosted: Sat Jan 19, 2008 7:47 pm
Hi.
I have managed to convince someone at my local GW to start playing epic (which has lead another person think about it, because he now knows that two other people play epic at the store :D ).  He has decided to play as Orks and has designed an initial 4000pt list to buy too.
Since neither of us know that much about Orks in Epic I said I would post his list here to get suggestions on tweaks.
The list is (roughly) as follows:
Big warband, 2 extra boys, 2 dreads, 1 kan
Warband with 8 kommandos and two extra boyz
Warband with 10 big gunz
Warband with 2 extra boyz
Big warband with 2 extra boyz, 2 gun fortresses each with an oddboy, 5 battle wagons
Stormboyz mob with 2 extra storm boyz 5 warbikes and 8 deth koptas
Blitz brigade with an odd boy
Gargant.
Or something like thart.
He is planning on buying
a character pack (Is it just full of Nobz?)
2 warband box
A warbike blister
A deth kopta blister
A big gun blister
A gunwagon blister
A battle wagon blister
A Gargant
A FW battle wagon blister (sincet hey are suppose to be big enough to be fortresses)
I have given him the dreads and kans, and 8 stands of ratlings to convert into grots
He doesn?t have any flak since I don?t have any aircraft and I am not sure why he hasn?t taken any fightas.
Tyranid air marshal
PostPosted: Mon Jan 21, 2008 4:02 pm
These are just some things to think about.  Mostly, I'm not quite sure of the intended use of some of the formations.
I don't follow the thinking behind this arrangement.  There should be plenty of Nobz, but not enough grots to get all the "free" ones with the extra Boyz.  I think you could stretch this out a lot more effectively (more models/fewer points) by buying more Big/Uge warbands.  Also, I'm not sure about the model count in the infantry boxes, but it looks like there are too many models for just 2 boxes.
I would cut all the extra Boyz and make one of those a Big Warband.  The Warband with Big Gunz is interesting.  Personally, I usually go for a dedicated Gunzmob, but building it on a Warband should provide a very tough formation for parking on an objective.
If there is any way to scrounge up 1-2 more Dreads/Kanz, they should be put in a basic warband, not the large.  Optimally, you will want 4-5 AVs (instead of just 3) so the infantry can use them to claim cover if you need to cross open terrain.
I'm not sure about this one, either.  Personally, I've found single mounted warbands to be sufficiently large on their own.  Also, the mix of AV transport and WE transport will allow the enemy to pick their optimal targets.  I would tend to break this into a Wagon mob and a Fortress mob.
I might break this one up as well.  Stormboyz with the Bikes give the ability to shoot/place BMs and support a follow up assault.  The bikes' 15cm range is fine for that.  The Deth Koptas could then form a separate formation where their additional range and skimmer ability could be put to better use (pop-ups and such).  The formations might be more fragile, but it's more flexible, the formations are more dedicated to specific roles, and the discount for Big Blitz Brigade would shave points.
Gargant.
OK
2 warband box
A warbike blister
A big gun blister
A gunwagon blister
A Gargant
The FW battle wagons would make better Battlefortresses than Gunforts.  They just look like cargo/troop carriers.  If he used them as Battleforts, he could have a Big Warband mounted in a pair (like the fort/wagon formation above) and he could have another Warband mounted in the Battlewagons, giving a second Warband mobility.
I think the big thing I would do is re-arrange the warbands to take advantage of the Big/Uge point breaks.  Something like:
Big Warband w/ Battleforts
Warband w/ Battlewagons
Big Warband w/ Kommandoes
Big Warband
Warband w/ Big Gunz w/ Oddboy
Warband w/ Dreads and Kanz
That's the same number of formations, with comparable formation sizes and about the same number of total units.  It has one less Oddboy but it's almost 400 points cheaper (so it shaves 300+ points, not counting the Oddboy) and it has another mounted formation.
Kommando warband garrisons way out front with the intent of getting in the enemy's face ASAP and harassing with the Scouts.  Gunz warband garrisons on OW with good fields of fire to function for area denial and holding a good objective.  The Mech warbands move to reinforce as needed.  The gargant can stick with one of the smaller mobz to move/shoot while the mob threatens assaults  with Gargant support.  The remaining big Warband can garrison or plan on simply rushing forward, depending on how terrain allows for garrisons.
The Blitz/Oddboy can hang back and hit targets of opportunity, then rush for objectives late in the game if it survives.  The enemy will have too many units in their face to worry about them a lot.  The Stormboyz and Deth Koptas can do likewise.  Stormboyz can also garrison if the situation allows.
You've already identified the major weakness - AA.  I'd say that really needs to be fixed for the list to be viable at 4000 points.  The points saved by a Warband reorganization and a few more from splitting off the Deth Koptas could fit in at least 6 FBs, and possibly 8-9.
PostPosted: Tue Jan 22, 2008 6:51 pm
thanks for all the advice.  I'll pass it on.
Tyranid air marshal
PostPosted: Wed Jan 30, 2008 10:02 pm
thanks for all the advice :D
i have modified the list it is now 5000 pts but i think its worth what do you think
LIST
big warband 2battle fortresses 2 oddboyz
big warband 2extra boyz 8 kommandoes
warband 2extra boyz 5battle wagons
warband 4dreds 3kans (in landas)
warband 2extra boyz 10big guns oddboy
stormboy warhorde 2extra storm boyz 5warbikers
blitz brigade oddboy ( 4 gunwagons)
big blitz brigade ( 8 koptas)
blitz brigade  +guwagon (starts with three flak and gun wagon)
fighta squadran 3extra fightas
landa
landa
gargant
total 5000
Oath and honour
PostPosted: Wed Jan 30, 2008 10:22 pm
Hey Fluffy.  Get together a 2000pt list first, for my imperial might to crush.  Then start looking at building a waaaagghhh.
Tyranid air marshal
PostPosted: Thu Jan 31, 2008 7:30 am
(ragnarok @ Jan. 30 2008,21:22)
Hey Fluffy. ?Get together a 2000pt list first, for my imperial might to crush. ?Then start looking at building a waaaagghhh.
to Crush lol :laugh:  that should be cool
Oath and honour
PostPosted: Sun Feb 17, 2008 1:00 pm
here is the 2k list i'm planning to get
big warband, 2 battle fortresses, 2oddboyz, warboss
700
6 fighta bombas
300
blitz brigade oddboyz, gunwagon
235
200
warband 5 bigguz oddboyz
375
blitz brigade death kopta
185
total 1995
Oath and honour
