EUK LatD
 Post subject: EUK LatD
PostPosted: Fri Jan 29, 2021 10:34 am
More EUK questions!
I can’t find on the list how to include the Arch Heretic Supreme Commander, I’ve probably just missed it, is it a free upgrade for another Character? What are the limitations to where it can be added?
The Daemon Pool appears to be classified as a Coven, does putting daemons in the pool/ taking a daemon pool open up the opportunity to take another Support Coven? It would incentivise taking Daemons and make the list a little easier to use, but I’m not sure this is the intent?
Thanks!
 Post subject: Re: EUK LatD
PostPosted: Fri Jan 29, 2021 12:17 pm
You're right, the Arch Heretic info appears to be missing. From memory, the Epic UK LatD list is pretty much identical to the NetEA one, which says:
"Every Stigmatus Covenant Chaos Cultist army must include an Arch-Heretic character. The Arch-Heretic character is free, you don’t have to pay any points for it, and may be added to any Daemon Prince, Demagogue or Chaos Marine Aspiring Champion unit."
I assume the Daemon Pool being listed as a Coven is a mistake, it would have some weird effects on lists!
The Wargaming Trader
PostPosted: Fri Jan 29, 2021 1:43 pm
N+1 Support Covens where N is the number of Stigmatus Covenant Covens (assuming a Daemon Pool) would be a bit different, but also appreciated to be honest. All the interesting stuff is in support and there’s only the one core option which takes some painting!
I think the format is not intended to be interpreted as above but where it’s actually justifiable there’s a slice of doubt/hope!
I’m certain that Arch Heretic paragraph used to be on the list, it must have got knocked off accidentally during the update.
Users browsing this forum: No registered users and 124 guests
