[NetEA] Chaos Army Section - DRAFT 2010
 Post subject: [NetEA] Chaos Army Section - DRAFT 2010
PostPosted: Sat Dec 11, 2010 5:11 am
Greetings from the NetERC and the NetEA Project!
Please find attached the 2010 Draft of the Chaos Army section of the NetEA Army Book. Please examine this document for typos, inconsistencies, and unclearness, or any other issues you may feel need to be resolved before final release. I do not have full names for either Frogbear or BlackLegion, so I need those for their lists.
Thank you!
This section includes the following armies:
13TH BLACK CRUSADE BLACK LEGION CHAOS ARMY LIST - APPROVED
THE STIGMATUS COVENANT CULTIST CHAOS ARMY LIST - APPROVED
WORLD EATERS CHAOS SPACE MARINES ARMY LIST - IN DEVELOPMENT
EMPEROR’S CHILDREN CHAOS SPACE MARINES ARMY LIST - IN DEVELOPMENT
THE THOUSAND SONS CHAOS SPACE MARINES ARMY LIST - IN DEVELOPMENT
DEATH GUARD CHAOS SPACE MARINES ARMY LIST - IN DEVELOPMENT
RED CORSAIRS ARMY LIST CHAOS MARINE ARMY LIST - IN DEVELOPMENT
ALPHA LEGION UPRISING CHAOS ARMY LIST - EXPERIMENTAL
DAEMON WORLD CHAOS ARMY LIST - EXPERIMENTAL
VRAKSIAN TRAITORS CHAOS ARMY LIST - EXPERIMENTAL
If there are lists you feel have been missed, please feel free to contact myself, Steve54, or any other members of the NetERC.
2010 - NetEA-ArmyCompendiumS1.8 - Chaos.pdf [395.3 KiB]
Downloaded 1636 times
 Post subject: Re: [NetEA] Chaos Army Section - DRAFT 2010
PostPosted: Sat Dec 11, 2010 6:44 am
Hi Chroma
Thanks for the awesome work you are placing into this project. Unsung hero.
Just a quick run of the document brought these up:
Document Itself
- Is missing the Frenzied rule
World Eaters List:
-pg. 9 All Skull Lords replaced with Chaos Space Marine Lord - was this just to save room? I just feel it loses a little flavour by changing this even though the stats are the same.
- pg. 9 World Eaters Terminators should state One World Eaters Skull Lord character upgrade and four to eight World Eaters Terminator units.
- pg. 9 World Eaters Terminators should cost 350 first 4 units +75 per extra unit
- pg. 9 Auxillery Formations should state: "Up to four Auxiliary Formations may be included in the army for each World Eaters Berserker Retinue selected."
- pg. 9 World Eater Bikers do not have EA+1
- pg. 9 Keeper of Chains states "Add an Icon Bearer to a unit in the formation ", should be "Add an Keeper of Chains to a unit in the formation
- pg. 9 Keeper of Skulls states "Add a Champion of Chaos to a unit in the formation ", should be "Add an Keeper of Skulls to a unit in the formation
- pg. 9 Keeper of Skulls Stats are missing (I guess you are referring people back to the Chaos Icon?)
- pg. 9 World Eaters Battle Barge should have an Initiative rating of 1+
Emperor's Children
- pg. 10 Degenerate States Champion of Chaos. Same deal as the Keeper of Skulls above?
I will read more when RL issues allow :) Probably tonight.
PostPosted: Sat Dec 11, 2010 10:51 am
Just sent Steve a PM about the Harbinger.
I still believe it can come down to 400 points. Any reduction from it's current cost to make it a viable option would be a good thing.
PostPosted: Sat Dec 11, 2010 11:03 am
Should the Black Legion Navy be 1+ Initiative?
PostPosted: Sat Dec 11, 2010 11:07 am
World Eaters List: Defiler Engines should be initiative 2+ as well
PostPosted: Sat Dec 11, 2010 1:04 pm
Red Corsairs Initiative values are messed up. It talks about Black Legion for instance.
Stats for the Traitor Warhound are missing.
That just for a quick glance. I will go over it in detail later.
PostPosted: Sat Dec 11, 2010 3:11 pm
frogbear wrote:
Document Itself
This will be a generalized special rule, so it will show up at the start of the document, like Expendable and such.
World Eaters List:
-pg. 9 All Skull Lords, Keeper of Chains, Keeper of Skulls
- pg. 9 states "Add an Icon Bearer to a unit in the formation ", should be "Add an Keeper of Chains to a unit in the formation
- pg. 9 states "Add a Champion of Chaos to a unit in the formation ", should be "Add an Keeper of Skulls to a unit in the formation
As this is not a "supplement", but an army compendium, units with the same stats will be given their "generic" names for the most part, to save space and to avoid confusion. In supplements it's fine to use "flavour" names.
If that's the case, then they need to be armed with a different weapon, as the basic guideline is "Same weapon name = same weapon stats".
Cool, hope you've got your magnifying glass! :D
PostPosted: Sat Dec 11, 2010 3:12 pm
D'oh, I know what happened there.
Actually, they're not "missing", please read the "Traitors" special rule at the start of the doc.
Great!
PostPosted: Sat Dec 11, 2010 3:13 pm
Hena wrote:
Because I suck, the list has older version of Death Guard. Chroma can you use the Death Guard 2.3
Hey Hena!
Can you please email me the DG list in a non-pdf format?
PostPosted: Sat Dec 11, 2010 10:59 pm
Correct. They are normal Chaos Bikers. Now you can save even more room! :D
PostPosted: Sat Dec 11, 2010 11:07 pm
Chroma / Steve
Can I please place in a clarification on the costing for the Khorne: Daemon Assault Engines in the STIGMATUS COVENANT CULTIST CHAOS ARMY LIST (pg8).
With the Defilers going down to 250 points, I believe it was decided that the Khorne: Daemon Assault Engines were to drop to 250 points. In comparison they are not worth the 300 points with Defilers at 250 points.
The World Eaters costings for these were also based purely on the Defilers dropping to 250 points with Init 2+
PostPosted: Sat Dec 11, 2010 11:30 pm
Chroma wrote:
frogbear wrote:
Keeper of Chains
Keeper of Chains does not have the same stat line as the Icon Bearer (KoC does not have Leader) and already has a seperate stat line in the list itself, so Icon Bearer is confusing when attempting to determine which you get for the 25 points.
PostPosted: Sun Dec 12, 2010 11:11 am
Regarding the Traitor Warhound: It has Inspiring as part of it's special abilities because it has a Dirge Caster. Thinking of this that i initially made it +50pts before the Space Marine's Warhound's points increase the Traitor Warhound should cost 350pts too.
As for Initiative:
Red Corsairs have no "Faction" rule.
All formations have Initiative 1+.
Chaos Navy and Daemon Engines have Initiative 2+.
Thwe rest of the list looks fine :) Thank you for your wotrk Chroma :)
PostPosted: Sun Dec 12, 2010 10:43 pm
Is Steve54 around at all? Haven't seen him posting lately.
