Harbinger?
 Post subject: Harbinger?
PostPosted: Fri Nov 06, 2009 11:58 pm
deleted
PostPosted: Sat Nov 07, 2009 12:43 am
It does stand out on it's own doesn't it?
Firstly, the BP should be '6' rather than '1'. Does that help?   :;):
I have to admit that in all the games that I have played, the Harbinger has never even been a consideration due to it's points. If it is purely the 30cm range on the Reaper that is the issue, then it could be changed to multilasers which gives 1 less AP (5+).
This would probably not be in line with FW stats (I have to see if I can find the stats again)  :shutup:   Not sure whether it would assist with dropping the cost either.
Overall, I do not think its cost justifies the impact it will have on a table. Especially when opponents (such as eldar) have aircraft that should be able to intercept or CAP it out of existence.
PostPosted: Sat Nov 07, 2009 12:48 am
Not sure how old this is but it gives the weapons layout:
http://www.forgeworld.co.uk/pdf/harbinger.pdf
PostPosted: Sat Nov 07, 2009 3:39 am
deleted
PostPosted: Sat Nov 07, 2009 4:46 am
The 30/15 split is the same as defence weapons on the marauder, thunderhawk, etc.
PostPosted: Sat Nov 07, 2009 10:21 am
Indeed, it's to do with the way the weapons are mounted. Little odd seeming at first but it's the way the epic aircraft rules generally are done and balanced.
PostPosted: Fri Nov 27, 2009 2:40 pm
imho 6BPs are not enough... it´s a Monster of a Bomber, it can levle whole citys... it should be more powerfull imho just look at its stats in AI its by far more powerfull in bombing than any other aircraft!
(26 "normal" Bombs +1 Giant Bombs or 13 additional normal Bombs)
www.ttc-cosmophobia.de
PostPosted: Fri Nov 27, 2009 2:48 pm
6BP with ignores cover puts as much metal downrange each turn (over the course of a game) as 6 Bombards... not bad IMO...
PostPosted: Fri Nov 27, 2009 9:39 pm
6 BP sound quite enough. Its not like it drops its entire load on one run, I would assume. Levelling a city takes time, even if you've got a lot of bombs. 6 BPs is a lot of bombs, a lot more than otehr armie's bombers.
"Don't use finesse, if force will solve the problem."
- Lieutenant General Michael O'Neal
PostPosted: Sat Nov 28, 2009 2:07 pm
then add the Big Bomb ^^
one shot, 3BP, MW2+ TK1 or something like that.  :laugh:
