Post new topic Reply to topic  [ 99 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
New & updated Black Legion units
 Post subject: New & updated Black Legion units
PostPosted: Thu Jul 24, 2008 5:15 pm
Desecrater: AA with Disrupt is pretty neat.
Oblits: Chaos has altogether too many MWs already, is there any reason to make it worse?
Aircraft: Epic can't really handle the fine grain differences between the Helltalon and the Thunderbolt, just give them the same (ish) stats, its the Swiftdeath that's the cheap, wave of fighters plane.
1 attack at 15, 1 at 30, 6+ armor, fighter speed
-James O'Barr, the Crow
PostPosted: Thu Jul 24, 2008 5:37 pm
I disagree. I think the game can.
The Swiftdeath will be removed from the list as soon as we can finalise stats for the Hell Talon and Hell Blade.
PostPosted: Thu Jul 24, 2008 8:38 pm
Well, let's put your money were your mouth is.
The Helltalon and Thundebolt are easily comparable.
The Thunderbolt is more heavily armed and armored.
The talon is more maneuverable.
Clearly the Talon is a fighter, the Bolt a fighter-bomber.
In Epic the Armor save is a factor of actual armor and maneuverability so they have the same save.
There is no way to avoid the fact that the Bolt has more guns, ergo more firepower. You don't have to like that the rulebook Bolt is way undergunned and a pain in our collective hindends because of it. Them's just the breaks.
Constant Aircraft creep is unacceptable, Chaos planes are comparable to Imperial planes for the very simple reason that they are made by the same caliber of people with the same basic resources and knowledge.
Until the unlikely event of all the aircraft being reviewed and brought in line the fact that they aren't WYSIWYG is a limiting factor.
At least until we all give up and just play another wargame.
PostPosted: Thu Jul 24, 2008 8:45 pm
Quote: (Lord Inquisitor @ 21 Jul. 2008, 19:39 )
My main reason for not liking the 2x30cm shots for the hellblade is that it introduces another 30cm interceptor, which doesn't need to enter flack range for bombers. Of the rulebook bombers we have the fighta-bomma and landa (15cm defensive flack), the thunderhawk and landing craft (15cm defensive flack apart from the front arc), the marauder (15cm defensive flack). Only Eldar bombers don't have 360-degree defenses. Of the rulebook interceptors, bommas need to enter defensive flak range and thunderbolts are less effective outside 15cm range.
30cm range means that hellblade interceptors will be able to pull the same trick as Eldar nightwings - fire at full effect while staying outside of defensive flak range. Is this what we want? This is the big question in my mind, the actual firepower is less important, it doesn't really matter that much in the big scheme.
A no-save interceptor under the new air-combat rules (i.e. +1 to AA) is going to suffer heavy casualties on approach if they only have 15cm range. Conversely, with 30cm range, the interceptor can probably intercept just about any enemy without risk of air flack by moving into their side arc and staying more than 15cm.
15cm vs 30cm has a massive effect on the craft's role as an interceptor and its point cost to boot. What role should it have - eldar-like killer, dancing around outside enemy flak, or a much more numerous interceptor hunting in packs and getting shot down by those brave marauder crews with the dashing haircuts, only dragging them down by sheer weight of numbers?
QFT.  As far as I'm concerned, Lord_I has the exact right thought process on this.  It's a matter of style for the aircraft first, then a matter of approximate proportional power compared to other air units, then a matter of balancing points.
My take on it is that the Hellblade background describes a horde strategy.  It's also a dedicated interceptor.  A sort of "berzerker" mentality would seem to fit with a semi-kamikaze approach.
My vote is 15cm.  Keep the strafing ability moderate.
2x 15cm AP4/AT6/AA5 gives it interception equal to Tbolts without the stand-off ability.  It's weaker on strafing except versus pure infantry (and then only marginally).  Overall, it comes out weaker than the Tbolt all around, but the problem is that if you go with the 30cm range, not only does it change the style substantially, but it gets much better.  If it needs a tweak, give it expanded arcs and/or a mobility-justified armor save.
Something in the neighborhood of 3 for 200 points would be about right for a 15cm range version.
Other units:
Obliterators:  Looks like nice flavorful stats.  They would still be 10-15 points higher than a Chosen Termie - Inv save, better ranged fire, better assault (slightly worse CC but 1.5x FF), Fearless.
Stalker:  I'd go with 2 shots.  At the current stats, I'd put them at no more than 50 points, possibly less.  They're comparable to Flakwagons with slightly better ranged fire, half the assault ability and double the AA.  They have better command and control, but I still think 50 points is sort of the top end for them and possibly too much.
Defiler:  Stats look pretty good to me.  Much better emphasis on CC and getting up close and personal.  Is the 20cm move to intentionally prevent garrisons?  Personally, I think 20cm is slower than 15cm from a practical perspective.  I believe it will functionally limit Defilers to 1 per garrison formation.
Desecrator:  I think it's okay, but it bears watching.  Compared to a Hydra, it has the same AA, comparable or better ground fire, much better durability (armor, invulnerable, fearless), and much better assault (1.5xFF and CC is just ridiculous) and it has better command and control.  It's slower, but Walker.  Looks pretty close.
Hell Tallons:  Looks pretty good.  They could be a heavy interceptor and do very well, but depending on points Hellblades should still be better.  In any case, their ground attack will be a superior use for them in most cases.
Harbinger:  No clue.  A bit under 6 hits to kill on average is comparable to an Ork Landa.  It's hard to say how much that huge barrage will be worth.  I'd start it at 400+ to establish a baseline.
PostPosted: Thu Jul 24, 2008 9:35 pm
Its armour save, firing arc of weapons and turning cicle.
Fighter and fighter bomber actually refer to ground attack flexibility as they refer to the ability to turn when launching ground attacks. The 'fighter' turning at 90 when attacking ground targets, the 'fighter bomber' turning at 45. Just because something is designed for ground attack doesn't mean it has to be a fighter bomber, if it was very good it would be a fighter.
Again if its 15cm weapons you want I'd go for a twin Reaper 15cm AP3+/AT5+/AA4+ and probably 360 degree fire arc (or forward, whatever). All to try and get it as cheap as possible for three and try for a squadron at 150 for 3. Also allows for a bigger horde!
PostPosted: Thu Jul 24, 2008 10:22 pm
What are you reading this in?
My take from the fluff was a more advanced air superiority fighter that was piloted by servitors or other pilots that weren't as affected by g-forces and could perform superior manoeuvres.
I didn't walk away from any reading with an impression of them doing kamikazee attacks. Quite the opposite in fact.
As mention, I also don't see the point of having this as a TBolt clone. Where is the fun in that? Might as well make it a TBolt then.
PostPosted: Thu Jul 24, 2008 10:24 pm
Why do you want a horde? I know you've mentioned price (and price in conjunction with the Banelord) a few times.
I'd rather have a more interesting and unique fighter that brought a bit of character to the list than a horde of cheap TBolt clones.
PostPosted: Thu Jul 24, 2008 10:58 pm
That was perhaps a poor characterization.  I was thinking of a very aggressive attack style with less regard for individual survival, not an actual suicidal bent.  Maybe a piranha swarm would be a better description.
Or maybe I'm just crocked.  My take on it is almost entirely secondhand.
I don't know how you could read "lighter," "more horde-like," and "dedicated interceptor" and end up with "clone."  I compared them only in with respect to very rough approximations of overall power level.
PostPosted: Thu Jul 24, 2008 11:13 pm
Had a read through the various books and I can't see the berserker horde concept. There is a mention in Aeronautica Imperialis about 2000 of  the Hell Blades being destroyed in a campaign but I'm not getting the same impression from the material that you are Neal.
PostPosted: Thu Jul 24, 2008 11:15 pm
Probably. The lack of concern for individual survival is definetely there are they are meant to be piloted by daemonically possessed servitors or just daemonically possessed in general.
BTW everyone does know that the Swiftdeath has a 30cm weapon and that the "official" Hell Talon stats have two 45cm weapons :-)
PostPosted: Thu Jul 24, 2008 11:57 pm
In the novel Double Eagle the Chaos aircrafts usually attack in hordes.
The Imperial aircrafts seem to shoot down more Chaos aircrafts than the other way round.
And for fighting mentality: Imperial aircrafts usually have ejector seats, Chaos aircrafts don't have such devices.
Ok got hold of Aeronautica Imperialis.
So the differences beween the Thunderbolt and Hell Blade are:
Name: Thunderbolt / Hell Blade
Manoeuvre: High / Very High
Hits: 2 / 1
Max Speed: 6 / 8
Min Speed : 2 / 3
Max Altitude 9 / 9
Thrust: 2 / 3
So you can see that the Thunderbolt is more robust but the Hell Blade is faster and more agile (and for the record the Lightning has the same stats as the Thunderbolt but Manouvre: Very High).
PostPosted: Fri Jul 25, 2008 4:18 am
I like using lots of aircraft? I also like to use Titans. Preferably I like to use both!
Incidentally do you think the current fighters are all clones of each other? That is the Ork Fighter, the Imperial Fighter and the Eldar fighter? If anything lots of Helltalon suggestions put them more in Ork stats than Thunderbolt stats.
PostPosted: Fri Jul 25, 2008 4:19 am
We have to take AI stats with a bit of a grain of salt as they clearly are different than the 40K stats (especially in terms of weapon load) but they are a handy reference for things like manoeuvrability.
PostPosted: Fri Jul 25, 2008 4:21 am
No I don't. I think they have a series of similarities in weapon stats (like ranges) that are artificially there due to errors in the original AA and Flak stats though.
Users browsing this forum: No registered users and 159 guests
