Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 13  Next
CHAOS Titan & Aircraft stats !
 Post subject: CHAOS Titan & Aircraft stats !
PostPosted: Wed Mar 19, 2008 8:50 am
nice paint job on the epic Khorne.
i am going for a daemonic and machine hybrid look to the chaos titans. made two warlords but not happy with the legs so are going to have another go tonight to fix them up also going to try and make a tyranid bio-titan tonight as well.
PostPosted: Wed Mar 19, 2008 9:06 pm
Sounds like a good concept, go for it ! And thanks, my Khornate forces are basically black with red and gold/bronze details.
PostPosted: Fri Mar 21, 2008 3:41 am
here is some better pics of my scratch built Chaos Titans.
the first two are my Warlords, followed by two Reavers [they were originally going to be Warhounds but got to big]
Warlord Titan armed with 2x Carapace Missile Launchers, 1x Gatling gun [eg, Auto-cannon, Vulcan mega-bolter ] 1x defense laser/macro gun [eg, big gun],
Warlord Titan armed with 2x Carapace Missile Launchers, 1x Plasma Cannon,  1x defense laser/macro gun [eg, big gun],
PostPosted: Fri Mar 21, 2008 3:48 am
the two Reavers [both armed the same] still in the under coating stage.
Reaver Titan armed with, 1x Carapace Missile Launcher, 1x Multi-melta, 1x Power Claw [eg, power fist]
If there are any Chaos mutation upgrades i'd see if there was some form of tail weapon and add it to the Reavers as well.
These two will be the close assault option for my Legion of Titans whilst the big guys sit back and blast any thing and every thing to bitz.
PostPosted: Fri Mar 21, 2008 7:03 am
I'll tell ya what, those are absolutely outstanding !!!  Very nicely done, very evocative, well animated and just darn cool !  You get a big "thumbs up" from me !  :D  Good job !
PostPosted: Fri Mar 21, 2008 8:34 am
i'll get some more pics of the Reavers up tomorrow they've been inked so are not to bad, i might still give them all some high lighting....but then again I might not as I want them to be dark and menacing.
Starting my attempt at a Bio-titan. we'll see how that goes.
Cheers for the feedback Legion 4....
PostPosted: Fri Mar 21, 2008 9:35 pm
Sounds Good ! Look forward to seeing those Big Bugs !  And I'll work on sending that data to you too !  :D
PostPosted: Sat Mar 22, 2008 8:08 am
the Reavers with a bit more paint on them. Still have to add the banners to the titans. designing them at the moment then print them off.
PostPosted: Sat Mar 22, 2008 6:55 pm
Looks really Great ! A great job of melding the "Bio-mechanical" ! Chaos warping of corrupted flesh and tainted metal ! :ghostface:
PostPosted: Fri Apr 04, 2008 5:41 am
ok I've dropped the idea of doing Bio-Titans due to the fact I couldn't get the legs to work on the body. also scrapped the Imperial titans as I couldn't get the reavers legs to work for me and the warlord titan looked to overloaded and clunky.
So I've decided to make two more chaos Warlord titans and two Chaos Reaver titans.
most likely these new titans will be from the Slaanesh Cult.
I got one question. do I have to only use the chaos weapons or can I use some of the imperial weapons instead?
AJ
another thing whats the smallest points people play for Epic? Looking at Titan Legions and see some of the weapons only deal to light tanks and infantry not titans.
I have modeled some of these weapons on to my titans and not sure what to do. etc etc
PostPosted: Fri Apr 04, 2008 6:16 am
Yes, there is no reason, that you can't use Imperial Weapons on Chaos Titans. In AT1 that's the way it was.  As far as Titan weapons, that depends on your Tactical concept of Titan deployment in battle.  My local gaming crew and I see Titans as heavy mobile weapons platforms, in support of ground forces. A Titan's first priority is to destroy other Titans. Any shots on any other target is a waste. All firing should be directed at other Titans. Once there are no enemy Titans left, then shots can be directed at other targets. That is our Titan Battle Doctrine. Titan Tactics - armed with heavy weapons, no close combat weapons ... Only ranged weapons.  Maneuver Titans into firing positions and blast the enemy Titans. So according to our tactical doctrine - arm your Titans with weapons that can kill other titans at long range.  And we generally play 3000-4000 point games.  1/3 of those points (based on E:A) can be used on Titans, Attack Aircraft and off board support, like orbital weapons, distant batteries, etc. ...  So in a 6000 point game, 2000 can go for Titans ...
PostPosted: Fri Apr 04, 2008 10:57 am
my two Khorne reavers have power claws. not sure what to give the two Slaanesh reavers.
So how many points worth of epic would I need to have field 2x warlords and 2x reavers?
if I buy 2x packs of chaos epic figs is that going to be enough infantry? if I am only fielding Khorne or Slaanesh by them selves [eg Khorne Vs Slaanesh chaos wars]
AJ
PostPosted: Fri Apr 04, 2008 6:48 pm
Well at current Epic:A costs - Warlord = 850 pts ; Reaver = 650 pts. When I say 3000-4000 pts, that's per side. Not total ... So if, for example, your Khorne Force is going to deploy 2 Warlords (850 each) & 2 Reavers (650 each) = 3000 pts.  So 9000 pts total with 3000 going to Titans.  That's a pretty big game.       Two boxes of Chaos infantry is good.  Do you plan to have any other Chaos vehicles and/or aircraft ?  Do you have the current Chaos Rules ? They are available here, on line.
PostPosted: Fri Apr 04, 2008 10:21 pm
yeah maybe some tanks and stuff...
looked at the chaos legion of the dammed. looks just like a chaos imperial army......
thinking of doing a Khorne and Slaanesh version of this.
any advice?
PostPosted: Fri Apr 04, 2008 10:58 pm
Khorne and Slann are fine. I'm a student of combined arms, and even though Chaos has Deamons, I fight them as such. And since you are going need 6000 points of other than Titans, Deamons count toward that. And you get them in the Chaos boxes with the CSMs, etc., anyway ... ?Since you are going to use all your 3000pts (1/3) on Titans, you can't afford aircraft, or orbital support. ?So your Titans can/will provide the fire support for the rest of your forces. Try to mount all your CSMs in Rhinos or Land Raiders for mobility. And support them with Tanks, and as much Artillery type weapons that are available to Khorne and Slann.
