Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 513 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 35  Next
World Eaters List - Be Scared!
 Post subject: World Eaters List - Be Scared!
PostPosted: Sun Dec 06, 2009 6:17 am
I have been under the pump recently so I thought I would get some of these important questions answered.
Just a bit of a heads up, TRC has provided a whole list of ideas (literally about 2 pages worth) with his vision for World Eaters. I have to say that alot of the ideas (if not all) are worth a closer look and review - even if it does change the whole structure of the list. Due to this, I will not be closing off the list at the end of the year as much of what TRC has placed forward is very very good.
I do not believe an AC (list developer) should stick to a schedule when provided with ideas that improve on an idea. Effectively, I would be interested in toiling and testing these ideas to make sure we have the best World Eater list out there for all EpicA, EpicUK, and NetERC players out there (whether they decide to use it or not). Even if some of the ideas challenge my 'pet formations' that I would hate to see changed. Hence the goal is still the magic 20 by the year's end, however any proposal to the NetERC will only be made after we have what we believe to be a competitive and uniquely World Eater list.
So without further rant, let me approach some of the answers to questions from the previous pages:
PostPosted: Sun Dec 06, 2009 6:21 am
Shermo writes
I was making a list yesterday. I wanted to include lesser brass scorpions to make an "scorpion heavy list". But when I compared lesser brass scorpions with slaughterfiends, slaughterfiends where better in nearly every aspect.
Stats
The slaughterfiend has a movement value of 20cm with infiltrator while the the scorpion has 25cm. Being both assault units I think the slaughterfiend has the edge here. The rest of the stats are the same.
Weapons
Shooting weapons are pretty much balanced, but when it comes to close combat, the scorpions has 3 normal attacks and the slaughterfiend has one normal attack and two MW attacks.
Notes
Excluding infiltrator mentioned above and bloodride, both have the same notes.
Points
4 slaughterfiends (275) are cheaper than 4 lesser brass scorpions (300).
So what do you think? Reducing the point costs of the daemonic engines? That would require to adjust a lot of stats
Buffing the daemonic engines? I think the cannon of khorne and the doomblaster are OK, but the rest are a bit underpowered for the cost. Keep in mind that a leman russ costs less than 75 pts each.
That's all. Any thoughts?
But the again, shouldn't the daemonic engines be considered as formations upgrades rather than a formation of its own? I still consider them a bit overpriced if you take into account that 3 leman russes cost 200 pts and are far better.
Much of this is covered in the ideas that TRC has placed forward. The Defiler is the golden position from the standpoint of the ideas and everything else should be compared to that. The ideas do make Daemonic Engines of Khorne a little bit more 'generic' in that you purchase them as either guns, big guns, misc, etc, and then field the model as appropriate.
I did have the thought of dropping the current unit to 275 points or even downgrading some things to make them 250 points. Let me spend some time with TRCs ideas for comparison's sake and let's see what we can do.   :agree:
Side Note: I think the idea of them as upgrades is also a great idea. Leave it with me.
PostPosted: Sun Dec 06, 2009 6:25 am
Honda Writes:
So I ask this as a scorpion aficianado, but do we really need three flavors of scorpion? Shouldn't there just be a FW Vraks variety and whatever Apocalypse is using? The other can just be a "counts as"?
Also part of the review and may be incorporated if the Generic Daemon Engines idea takes off.   :agree:
PostPosted: Sun Dec 06, 2009 6:27 am
eypyeash pick up:
Remove weapon on packmaster and leave with Leader as the weapon does nothing
This can be an immediate thing as it is just 'window dressing'. Consider the weapon removed
PostPosted: Sun Dec 06, 2009 6:31 am
TRC writes:
Its definitively a naval list. With no flak you will always see the navy with them and you save the points of a skull lord if you drop pod in.
Is it intentional to be able drop pod raptors?
I know I've tried an army without Skull Lords but in reality unless you drop pod in you will always want to be with one.
Making a list is somewhat frustrating, with the ability to break very easily the force comes across as bizarrely limited and fragile. Some units are costed out of practical use.
Terminators are an example. As a garrison they are a massive points sink better spent on say a titan. As a mechanised formation they are a minimum of 700 points. If they teleport 450 to 850 rather fragile points of units. No inspiring unless you want to go for the GD making the formation 150-200 points more expensive. So they are always going to cost the earth and if they break get slaughtered. Compare the mech formation to the regular marine one - similar firepower, better CC verses better FF and the marines have inspiring from their chaplain and ATSKNF for an all round boost vs stubborn.
Is it possible to change the stats to bring the points down in formations? In the case of the terminators I would change the stats to one reaper cannon, CC2+ +1MWCC, keep FF at 4+ and then have 2 formations costed separately. A teleport/drop pod formation 4-8 strong and a mechanised formation of 4 terminators and 4 land raiders.
Plus you get to remove the teleport upgrade and stick it back on the terminators stats and remove some confusion
You could consider the same with other formations if it works for them too.
Flak wise I would to be honest prefer some kind of demonic engine flak, or even the stalk tank. It feels strange that with beastmen, land raiders, rhinos and so on they don't have any flak. Then again the airplanes are quite good.
Oh and you could add vindicators if you wanted  Oh and definitively correct the Predator stats
Oh with the option of slaughter fiends should there be a re-wording of the transport option? Say add up to enough rhinos and land raiders to transport the formation after other upgrades?
And shouldn't the fiends be able to carry beastmen and stuff as well?
The weapons fit ont he chaos preds is 'wrong'. The Heresy era layout is autocannon and 2 lascannon in sponsons, not the space wolf design of twin lascannon in turret.
Remove the initiative daemons rule.
Pile of Skulls – Daemonic Focus 50/100 points?
Bikes w/ 5+ FF
SL rule – ambiguous (unit w/o a skull lord at any time throughout the battle)
Berserkers w/ SL – 250 points : if not, drop Berserkers to 225 points and boost Dreadclaws – in danger of too good due to beastmen costs?
Dreadclaws – 100 points (added 25 points)
No replies required here as these are being discussed in the ideas placed forward for the direction of the list.
I hope all this updates everyone on their questions. Most likley it developed more questions than it answered, however I will get the TRC ideas up once we have gone through them and decide what to place forward as an idea for the list.
Thank you everyone for the great imput so far. All of this helps.   :yay:
PostPosted: Sun Dec 06, 2009 7:39 pm
I think its a good thing that you are open to ideas. Reviewing your own work and "killing your darlings" is usually a good way to go. I hope you come up with intersting new perspectives. Following your work with great interest.
Brass Scorpion: Lets not get bogged downwih WYSIWYG stuff,this is Epic. Keep the list simple, and allow different models with the same statline. If they're all huge metal scorpions, whats the big deal?
"Don't use finesse, if force will solve the problem."
- Lieutenant General Michael O'Neal
PostPosted: Wed Dec 09, 2009 6:58 am
Nifty objective?
http://www.fortressfigures.com/Fortres....html#23
PostPosted: Wed Dec 09, 2009 7:38 am
Meh. Doesn't grab me enough to buy it.
Been silent on this one at the moment. Have just been organising something for the Bloodbowl community in Australia.
I will be back on here soon enough.
It will also burn some time waiting for the new Chaos AC to come forward.
PostPosted: Wed Dec 09, 2009 11:57 am
A change is coming? Who is/was it? I thought it was BL.
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Wed Dec 09, 2009 12:38 pm
On another thread, Chroma stated it was Steve54 I believe.
PostPosted: Wed Dec 09, 2009 3:40 pm
BlackLegion has not been a head Chaos Champion for the NetEA project, just a helpful contributor.
The Chaos co-Champions have been Lord_Inquisitor (Chaos Space Marines) and Steve54 (Chaos Cultists).  The NetERC has decided to merge the positions into one, with Steve54 taking over Chaos and Lord_I focusing more on the NetEA Inquisition lists.
"Official" announcement should be soon.
PostPosted: Wed Dec 09, 2009 4:49 pm
:;):  Uhhm. No. I only champion the Red Corsairs armylist (and several others which i don't regard that much in comparison) and try to be helpful for the others Chaos armies. Even if someone would appointme to be Army Champion of the whole of Chaos i would refuse because i lack some crucial abilities (foremost the possibility to play regularly) to be a proper Army Champion.
PostPosted: Wed Dec 09, 2009 9:20 pm
TRC
I am still looking through the ideas you placed in, and am interested in the other discussions going on at the moment regarding Daemons, summonings and the like. Many of the ideas and backings that BL has joined in with I feel could actually be taken seriously (regarding daemon Summoning).
I am also waiting on the official announcement regarding the Chaos AC and for him to take up the position so as he may offer some constructive feedback and direction on such a list.
I will be having further discussions and reviews of the daemon Engines as per your suggestions. I think that was a strong proposal. I do wish to try and seperate the Doom Blaster and Cannon of Khorne out from the rest. Just need to get time to sit down and do it however.
So no movement at the moment on the ideas, yet I will not be closing off the supplement either.
Most I will be doing is the last 2 playtests, the Daemon Engines, and maybe some work on the Apocalypse list at the back of the supplement.
Regards...
PostPosted: Wed Dec 09, 2009 9:24 pm
I had also the suggestion to introduce non restricted Greater Daemons appropiate to their Wh40k stats (so AV instead of WE) and rename the WE sized Greater Daemons to Daemon Lords as they more represent the size and power of the Forgeworld Daemon Lords.
PostPosted: Wed Dec 09, 2009 9:27 pm
Interesting.
Worthy of a 2010 playtest changes document?  :O
Users browsing this forum: No registered users and 95 guests
