Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
CSM typos
 Post subject: CSM typos
PostPosted: Wed Jul 11, 2007 7:07 pm
(Hena @ Jul. 11 2007,11:04)
Just consistency *shrug*. Makes the lists a bit more uniform.
Maybe I just don't see it since I am expecting to see (base) all the time as that is what the entry used to be.
Have the lists all changed to use (base contact) now?
PostPosted: Wed Jul 11, 2007 8:05 pm
Okay:
Rulebook ...> (base contact)
Speed Freaks...> base contact
Swordwind ...> (base contact), base contact and, more commonly, (Base Contact). Sometimes variation between formatting within a single datafax!
White Scars ...> (base contact)
LATD...> (base contact)
Personally, I like (Base contact) as Small arms and Assault weapons are capitalised, but it seems that (base contact) is the most "proper" format.
PostPosted: Wed Jul 11, 2007 8:12 pm
I'll see if it fits.
PostPosted: Fri Jul 13, 2007 2:41 pm
Not really clear on what you are suggesting.
PostPosted: Fri Jul 13, 2007 2:49 pm
In the stats it said Great Daemon of XXX but it should be Greater Daemon of XXX.
PostPosted: Fri Jul 13, 2007 2:56 pm
Ah
PostPosted: Sat Jul 14, 2007 6:32 pm
(Hena @ Jul. 14 2007,10:20)
5. Would it be possible to write the notes special abilities in alphabetical order?
Goodness no :-)
I've already got more work to do just fixing these issues :-)
PostPosted: Sat Jul 14, 2007 6:45 pm
@Hena: currently Raptors have acsess to more spcecialweapons than AssaultMarines (up to 3 instead of up to 2) which makes the FF-value better and have DaemonicDread (malus on leadership tests for opponent in closecombat) and FallingBack (can always disengage from closecombat without ill effects) special abilities which in turn prevents worsening the CC-value.
But it seems in the new Codex they will loose those two special abilities.
PostPosted: Sat Jul 14, 2007 6:46 pm
What he said :-)
PostPosted: Sat Jul 14, 2007 8:31 pm
Aye, I'd expect to see Raptors downgraded slightly after the new codex comes out (A FF change at the least).
Though Assault Marines may be nudged upwards at some point too.
Maybe they'll meet in the middle. :)
PostPosted: Sat Jul 14, 2007 8:43 pm
If the rumours will be true the Raptors stats and options will be identical to current Codex: SpaceMarines' AssaultMarines.
Differences are only that Raptors are 5-20 CSM and can use Plasmaguns and Meltaguns too (AssaultMarines can only take Plasmapistols and Flamers) and can have a ChaosIkon.
Oh and all Raptors can swap CC-Weapon and Boltpistol for CC-Weapon and Bolter.
