Post new topic Reply to topic  [ 634 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 43  Next
Red Corsairs (or generic Chaos Space Marines)
 Post subject: [fanlist] Red Corsairs (or general Chaos Marines)
PostPosted: Thu May 14, 2009 2:15 am
It's not a special rule per se its a simple note in the units Notes-section.
BTW the Plaguereaper has the same critical as the Brass Scorpion in the RedCorsairsV3.9 list with the addition that Nurgle units don't take hits.
PostPosted: Thu May 14, 2009 2:16 am
Hmmm.
Tell you what, I'll accept CC4+ if you accept a normal critical :p
PostPosted: Thu May 14, 2009 2:24 am
Actually i find the critical very fluffy for a daemonengine which REALLY wants to kill its enemies :D
Both the Brass Scorpion and the Tower of Skulls have the +2 on the Catastophic Damage table which results on an Explosion on a 2+.
Both the Plaguereaper and the Plaguetower always explode even if they roll only a Destroyed result.
To me both read as an auto-critical if reduced to DC0.
PostPosted: Thu May 14, 2009 2:29 am
Sure, but I don't see that as important enough to break with convention. No official unit have automatic criticals, or even criticals on anything other than a 6. Epic has a very different criticals system to 40k, and I don't think a direct transfer is a good idea.
Well, it's hardly a major point; we've got the main stats agreed seemingly.
PostPosted: Thu May 14, 2009 10:36 pm
Seems so  :laugh:
So what is the view of others about the critical?
PostPosted: Thu May 14, 2009 11:31 pm
Ok some stat ideas for the (Greater) Silver Tower of Tzeentch and the Subjugator Titan.
War Engine 15cm 5+ 6+ 4+
Weapon Range Firepower Notes
Beam of Power 45cm MW3+ Titan Killer
Bolts of Change 15cm D3 x AT5+
Damage Capacity 2. Critical Hit Effect: The Silver Towers  reactor explodes. The  Silver Tower  is destroyed and any units within 5cm of the model suffer a hit on a D6 roll of 6.
Notes: Invulnerable Save, Fearless, Reinforced Armour, Skimmer.
Slaanesh Subjugator
War Engine 30cm 4+ 4+ 4+
2 x Tormentor Cannons 45cm AP4+/AT4+ Disrupt
Twin Blastmaster 30cm AP3+/AT5+ Disrupt
Subjugator Doom Siren 15cm AP4+ Ignore Cover
Hell Slicers (base contact) Assault Weapon Macro-weapon, Extra Attacks (+2)
Damage Capacity 3. Critical Hit Effect: The Subjugator is caught off-balance and staggers. Move it D6cm in a random direction. If this move takes the Subjugator into impassable terrain or another unit it can’t move over then it stops when it contacts the obstruction and suffers an extra point of damage. If it staggers into or over any units then they will take a hit on a D6 roll of 6+ (make saving throws for the unit normally).
Notes: Invulnerable Save, Fearless, Walker. May step over units and impassable or dangerous terrain that is lower than the Titan’s knees and up to 2cm wide.
PostPosted: Fri May 15, 2009 6:32 am
What is wrong with the existing Subjagator stats in the LatD?
www.epic-uk.co.uk
PostPosted: Fri May 15, 2009 10:13 am
It was made before the Apocalypse datasheet  :laugh:
PostPosted: Fri May 15, 2009 10:26 am
Which is no reason at all to change it - the unit is still broadly the same in use. I don't think we should blindly follow 40k let alone apocalypse
www.epic-uk.co.uk
PostPosted: Fri May 15, 2009 10:32 am
If it wasn't a reson i wouldn't have come up with my own stats. :p
But i guess i couls subly alter thename so thatit is clearthat it isn't the Subjugator from the LatD armylist. I changed the name of the Silver Tower too but didn't came up for a new one for the Subjugator. What about Subjugator Grant Knight? IIRC the Slaanesh Scout-Titans and Slaanesh Knights all came from the Traitor Knight Household Diedne.
PostPosted: Fri May 15, 2009 10:35 am
Why do we need a set of alternative stats trying to mirror apoclaypse?
www.epic-uk.co.uk
PostPosted: Fri May 15, 2009 10:47 am
Why do we play wargames instead of doing something more productive?
Because we enjoy it more.
PostPosted: Fri May 15, 2009 10:49 am
So because we can?
www.epic-uk.co.uk
PostPosted: Fri May 15, 2009 10:58 am
Too.
And because Epic isn't the game which brings new units for Wh40k anymore. It's now the other way round.
PostPosted: Fri May 15, 2009 12:04 pm
I would base it off the L&TD Subjugator stats.
However, I am under the impression that the L&TD Subjugator is over-strong?
EDIT:
Definitely go with 'normal' criticals for the Brass Scorpion.
