Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Vraksian Traitors 1.08
 Post subject: Re: Vraksian Traitors 1.08
PostPosted: Fri Jan 24, 2025 1:04 pm
Thanks Mattie.
I must say, I have very little experience of this. What would you say is a good 'ball park' figure? It will be a while away, but I can report results.
We are playing just casual campaign play, not tournament, so as long as is not really badly mismatched we probably won't notice :)
PostPosted: Mon Jan 27, 2025 5:14 pm
"Worker Rabble" idea.
Test option 1
0-1 Worker Rabble. 12 stands 180 points
Save 0 CC +6 FF+6
Test option 2
Worker Rabble upgrade. Any number of stands can be add to the Infantry Company at 15 points each.
Save 0 CC+6 FF+5 expandable
mattie
http://maashes.blogspot.com/
PostPosted: Wed Jan 29, 2025 5:00 pm
Option 2, though you may want to cap it at some largeish number
PostPosted: Wed Jan 29, 2025 5:12 pm
Anything much more than 10 and you give up an activation. So if one was to load up and sacrifice 2 or 3 activations. FaFo
mattie
PostPosted: Fri May 09, 2025 9:29 pm
The issue is it doesn't scale up in larger games. As you say, FAFO so it's not an issue at 3k
PostPosted: Fri May 09, 2025 11:29 pm
It is a low activation list to start with. One plays the list for the malcadors. Only taking 1 or none could more easily be represented by an approved list.
mattie
PostPosted: Sun Jun 29, 2025 11:28 pm
I was asked this weekend about testing the siege lines. Vraks is a list designed to hold onto ground. The option is below;
*Vraksian Fortifications Test Option;
Vraks are a defensive siege army known to use filed works very extensively. One Fortified Position may be
taken per Vraksian Regimental HQ Platoon and Infantry Platoon. Fortified Position are up to 50cm of
trenches, minefileds and or razor wire.
My issue is the Krieg army has them. DkoK is an army list with a design to take ground. Could one not represent Vraks Traitors with the Krieg list with a few limitations?
80cmof trenches, 20cm of razor wire, and 4 bunkers
If you have the time and want Vraks fortifications, please test it out and report the battle.
mattie
