Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
BL Review - aircraft
 Post subject: Re: BL Review - aircraft
PostPosted: Wed Apr 25, 2012 2:19 am
As a squad of 3, the Hellblades are also quite impervious to most AA that I see as you usually get two through (3 if lucky enough) to continue the mission. That is why I think they are exceptional for their points.
PostPosted: Sat May 12, 2012 9:43 am
Ok then hellblades+spacecraft seem ok then
Helltalons - 45cm AA shot seems to be the issue. How does reducing that to 30cm and costs to 200 sound?
www.epic-uk.co.uk
PostPosted: Sat May 12, 2012 9:52 am
i've been running those stats at 225 with no real issue (though they've been largely underperforming compared to my artillery for the same role. so perhaps the drop to 200 will do them good. alternately i have been considering giving them IC on the bombs to further encourage their role as the bombers of the army)
PostPosted: Sat May 12, 2012 11:03 am
I believe it merely comes down to the role within the army.
Chaos (I would think) would want to have the flexibility of using their aircraft for air engagements and/or ground attacks rather than specialising in this area. So while a drop to 200 points may encourage their use, in a tournament sense (dependent on meta-game), I cannot understand why you would give up options other than taking them as a 2nd aircraft choice - possible.
PostPosted: Sun May 13, 2012 9:46 am
Right, lets test 30cm AA, IC on the bombs, 225pts
www.epic-uk.co.uk
PostPosted: Mon May 14, 2012 2:57 pm
Why should the Twin Lascannon of the Hell Talon suddenly shoot less far than the very same weapon as on the Marauder?
PostPosted: Mon May 14, 2012 3:09 pm
because the marauder cant intercept. it makes the helltalon into a vehicle it is not supposed to be
frankly i dont think the marauder should have that kind of range either, but the impact there is minor
PostPosted: Mon May 14, 2012 3:12 pm
If the Talon is going to drop to this cost I'm going to have to have a look at the LatD Firelord as 2 for 300pts is starting to look rather expensive.
PostPosted: Mon May 14, 2012 5:10 pm
Four or five year old argument :-)
PostPosted: Mon May 14, 2012 5:46 pm
Four or five year old try to fix :)
PostPosted: Mon May 14, 2012 6:40 pm
If you consider anything other than "because game balance" to be needed (which you shouldn't by the way; game balance should always be paramount) then just imagine that hitting a basically stationary tank on the ground at whatever realworld distance 45cm is is a lot harder than hitting an enemy fighter in the air at the same range, doubly so as it's a lot less agile than other dedicated interceptors.
PostPosted: Mon May 14, 2012 6:48 pm
The Marauder's Twin Lascannon also has AA4+. If anything then the Hell Talon's Twin Lascannon should be even BETTER because it is a Fighter-Bomber compared to being a Bomber which the Marauder is.
PostPosted: Mon May 14, 2012 6:52 pm
Balance. 45cm AA intercepting doesn't work
www.epic-uk.co.uk
PostPosted: Tue May 15, 2012 11:42 am
It's not without precedent. Twin HBs on a Thunderhawk = 30 cm AA, twin HBs on a Landing craft = 15cm.
And this is from the main book, not a fan list.
Game balance trumps all IMO.
PostPosted: Tue May 15, 2012 11:54 am
Bad precedent to call - Look at the weapon arcs.
