Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 513 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 35  Next
World Eaters List - Be Scared!
 Post subject: World Eaters List - Be Scared!
PostPosted: Fri Jul 31, 2009 1:46 pm
Some thoughts:
I cannot see the Brass Scorpion as an Armoured Vehicle, as it is as big as a Baneblade. I feel the stats Blacklegion and Zombocom developed are much more appropriate.
Unless you're basing the stats on the ancient Epic model, which would make me sad.  :sad:
The World Eaters Dreadnought is misspelled as Dreadnaught. It's also worth more than 50 points IMO, considering it has twice the FF of a loyalist Dreadnought and an extra MWCC attack. Who cares if it has no ranged attack if it's only ever going to be seen emerging from Drop Pods?
Nice list though.
PostPosted: Fri Jul 31, 2009 1:56 pm
Some thoughts:
I must say it is based on the old model. Some good news however is that I understand that FW are making an even bigger version of the Brass Scorpion again (??). We could incorporate all three as the Lesser, normal, and Greater Brass Scorpions. I knew this would be a talking point so glad you brought it up. Would it make you  :sad:  if there were different versions of this in a list?
Thanks for that. It will go on my list of 'things to discuss' over the week.   :agree:
Nice list though.
Thanks dude. We have spent alot of time on it and taken note of requests people have made with other lists of different armies to get it to this stage at least.
Cheers....
PostPosted: Fri Jul 31, 2009 2:05 pm
Nope.
There are three Brass Scorpion models that have been made over the years:
OOP Epic model - AV sized model. "Brass Scorpion"
40k recommended conversion made from 3x Defiler kits - 2DC War Engine "Brass Scorpion"
Forgeworld model - 3DC War Engine "Elder Brass Scorpion"
That does indeed give space to make lesser, 'standard' and greater Brass Scorpions... whether there's a need for so many units that do pretty much the same thing is debatable.
Personally I'd just stat up the 'standard' one, so that you can reasonably use any Brass Scorpion model with those stats.
Not sad, but I do believe that every unit should be able to justify its existence, especially if it is OOP or requires a conversion.
PostPosted: Fri Jul 31, 2009 2:21 pm
Quote: (frogbear @ 31 Jul. 2009, 13:16 )
The whole aspect of the Chosen are the veterans who could also be the possessed
Theres an idea for an alternate weapon then - hellfire or similar. 15cm, stats whatever.
Also, I never did like the name 'Forlorn Hope'.  :disagree:
Not a big musket era wargamer then :) Forlorn hopes are in some ways the most evocative formation of those times, combining brutality with desperation!
Be aware your doom blaster can garrison.
These are the most WE lists I can devise
Edit - new ones below
PostPosted: Fri Jul 31, 2009 2:53 pm
I just updated the links with some naming conventions that I left out and the Destroyers being able to be taken as upgrades for Chosen and Daemonic Assault Engines.
TRC: Not bad numbers in those lists. I struggle sometimes to get 7 activations.
However, you cannot take more bike units than you have berszerkers. Read the restriction at the bottom of the Core formations.
Let's see what you come back with   :;):
PostPosted: Fri Jul 31, 2009 2:57 pm
Yes
It was to help balance this against the Cannons of Khorne
We did not want to give it indirect fire as the fluff specifically states it cannot fire indirect. The range is comparable to a conversion from the old Epic as well.
Rather than give it 3 or 4 BP, we agreed that 2BP with an ability to garrison would balance this unit of 3 (kill 1 and they are broken). Remember that an opponent places the markers where you garrison so effectively, you may find that you may not want to, but the choice is there.
Do you think they are a problem at garrisoning? They do need line of sight and 45cm is not all that crash hot for such a support. Also their numbers (3 to a unit) is a hinderence. We were even considering a future discussion (based on the 'how many are 3 whirlwinds worth?' thread) to lower this units points.
Interested in your thoughts.
PostPosted: Fri Jul 31, 2009 3:34 pm
Yeah they can probably come down. I was just pointing out they could garrison so you were aware in case you hadn't noticed :) .
Incidentally do Khorne guys turn into oblitorators?
Oh your destroyer AA weapons don't make any sense. To be 360 weapons the ground varient would have to be 60cm (to reduce for being a 360' mount) or AA4+ fixed (to come down to AA5+ not fixed). Reapers have a ground range of 30cm so here your chaps would be 30cm AP4+/AT6+/AA6+ or 15cm AP4+/AT6+/AA5+.
Your blood lord and demon prince stats are a bit weird are they meant to be characters or not?
So I can't go for the bikes?
So its
425 retinue dreadclaws, Blood Lord
375 retinue dreadclaws
250 Bikes
400 Lord
400 Lord
400 Lord
150 Spaceship
300 Feral
300 Feral
Or maybe
425 retinue dreadclaws, Blood lord
450 terminators, teleport
400 Lord
400 Lord
150 Spaceship
200 Fighters
300 Feral
300 Feral
PostPosted: Fri Jul 31, 2009 6:05 pm
Quote: (frogbear @ 31 Jul. 2009, 14:45 )
Quote: (Flogus @ 31 Jul. 2009, 13:37 )
Look in the properties on the pdf files : "Title : Grey Knights" !  :p
No idea how that got there other than the word doc being a template from Lord Inquisitor's Grey Knights. Would make sense.
People look at the strangest things!   :p
Any opinion on the list Flogus?
In MS Word, look in 'File' and then in 'Properties'.
And I haven't read the list in details, so my comments will come ... later.
PostPosted: Fri Jul 31, 2009 8:13 pm
So its
250 Bikes
400 Lord
400 Lord
400 Lord
150 Spaceship
300 Feral
300 Feral
Or maybe
400 Lord
400 Lord
150 Spaceship
200 Fighters
300 Feral
300 Feral
The garrison option was to compensate in some part for the really short range. The other option was 20cm Move, and 30cm Indirect Range. But as the Frog pointed out, the direct fire weapon was chosen for fluff reasons. And for the quasi-Ork mentality of "Must see the boom! Where's the earth-shattering BOOM?"
I believe the Destroyers were supposed to remove the AA. That was discussed to today. AA is supposed to be provided by the Hellblades, limiting the WE detail a little (sort of self enforcing the Feral restriction). The Devastation Cruiser also does this.
With regards the Blood Lord and Prince, the Blood Lord should be a character. Adding +1 normal CC attack, and Supreme Commander to the Skull Lord, essentially. The Demon Prince is a Replace. Again, this is another sign of premature exposition.
Not sure what the bike thing is about.
The lists look effective. In my outing I took the two Berserkers in Claws (1 with DPact), and 2 Termies (2 with DPact), the Cruiser a Feral and a Cannons squad. Against Marines, the lesser SR cost me the Feral, and the combined fire and some slightly below average dice in the assaults cost me the rest of the game. And I had a miffed opponent when playing Tau against an army with no air defence. I took down all 3 LoB without risking a unit, essentially. I still have concerns about LoB being Support, and would like to see how it fairs against armies that don't have 4 flying Volcano Cannons. But I also don't want to restrict an already fairly crowded 1/3 restriction either.
Morgan Vening
PostPosted: Fri Jul 31, 2009 8:22 pm
Yes, that's because MSWord give the title to the document based on the first line in the document unless you specify otherwise, and indeed I used the Grey Knights as the basis.
PostPosted: Fri Jul 31, 2009 8:29 pm
Nope.
This is all on me. Totally my fault.
When an opponent puts down two units that are smaller than a Land Raider, and says they are both DC2, 5+RA+I, it feels wrong.
Firstly, I felt that the World Eaters list had more than sufficient coverage on a War Engine footing, so I called for it's reduction to an AV.
It became more ingrained when FrogBear wanted to include the variations of the Demon Engines. I voiced early opposition to the entire lot being DC2, and trying to find a balance for the whole 'intermixed' with one being a DC2 WE was difficult.
With regards the OOPness of the old Brass Scorpion, what's your opinion regarding the other Demon Engines and Lord of Battles? All of these died in production about the same time, yes?
The whole 3 scales of Brass Scorpions does make it fall apart a little. Is there a current version of the epic scale middle sized Scorpion? Or are you just going off the 40K version?
But I'd rather see the three versions than seeing the OOP ones being used as WE. I dunno, maybe see the FW Brass Scorpion replace/substitute for the Feral? Put the LoB (beefing it slightly) in a similar position to the Ravager?
Morgan Vening
PostPosted: Fri Jul 31, 2009 8:38 pm
Converting one from one of Otterman's petite crabes was very easy:
PostPosted: Fri Jul 31, 2009 8:40 pm
You can build a Medium Brass Scorpion out of two of Ottermans Petite Crabes. E&C did so and there are some pictures of it somwhere iirc.
EDIT: Here:
http://www.tacticalwargames.net/forums....rs2.jpg
http://www.tacticalwargames.net/forums....rs3.jpg
http://www.tacticalwargames.net/forums....rs4.jpg
PostPosted: Fri Jul 31, 2009 8:45 pm
You got ninja'd pretty badly there BL!  :vD
PostPosted: Fri Jul 31, 2009 9:23 pm
Damn. But my girlfriend distracted me with tender kisses while i was posting so i guess it was worth it  :laugh:
Users browsing this forum: No registered users and 98 guests
