Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
Chaos Titan Legions: Nurgle: Festering Death 1.0.3
 Post subject: Chaos Titan Legions: Nurgle: Festering Death 1.0.3
PostPosted: Tue Jul 14, 2009 1:37 am
Could someone with the correct moderating powers please move this thread to the AMTL forums, as per the decision that C&E as AMTL Champion is responsible for it. (and delete this post)
Chaos Titan Legions: Khorne
PostPosted: Tue Jul 14, 2009 2:23 am
I still believe this fall under both Chaos and AMTL purview and, as a "Chaos" list, is better served here.
I'll discuss it with Neal.
PostPosted: Tue Jul 14, 2009 6:13 pm
I think chaos titan lists should best be considered AMTL variants.
PostPosted: Tue Jul 14, 2009 6:18 pm
Why wouldn't they be a "hybrid", since they are using Chaos rules as well; at least if there's any summoning or factions and such and they should be designed to play, relatively, nice with other Chaos lists, something E&C is striving for with the Titan Legion lists possibly integrating with other Imperial lists.
They're Chaos lists, and should, in my opinion, and if it's even necessary to deliniate such things, fall under the aegis of Chaos (the army list) with advice/guidance from Evil and Chaos (the person).
PostPosted: Tue Jul 14, 2009 6:21 pm
However it is classified, it can't be denyed that this list is an AMTL varient, based on the current AMTL list.
If someone takes an existing list and makes changes that makes it a varient of that original list.
PostPosted: Tue Jul 14, 2009 6:23 pm
ho ho ho  :))
As long as a particular champion is appointed to keep a close eye on the Chaos Titan sub-list(s) I'm happy either way, just as long as it doesn't fall into a limbo between the three of us (Me, Lord I & Steve54) where no champion is helping to guide the list's progress at all.
PostPosted: Tue Jul 14, 2009 6:40 pm
Quote: (Hena @ 14 Jul. 2009, 17:53 )
I went through the list of weapons in here. I must say that it's more imaginative that this. You've copied over half of these directly from Imperial titans (including just name changes).
Why all the Plasma weapons are there? Chaos should have deteriorating quality and sticking the high-tech on them doesn't seem right. Also somehow the "clean" weapons of plasma and Inferno cannon doesn't sit well. Inferno could be replaced for example with Stream of Putrescence.
There has been reason why no close combat weapons is in warhounds. They are fast enough to actually make them quite offensive.
Daemontitan. Would it just be easier to stick Daemonic Pact to a titan? Wouldn't need to make up new special rules.
Corbulent bulk. It should increase the Warlords DC more than one. Loss of 5cm of 15 is loss 1/3 while from 20cm it's 1/4. The difference is use is a lot greater. Incidentaly this is one bit that annoyed me a bit in
One, this represents ALL Nurgle Titan legions, including ones that are newly fallen - and infact, plasma weapons have been quite prevailant in on Plaguemarine models since I remember - they age, and they get dirty and leaky and dangerous, but they still function, as for copying/changing names, most of these weapons are designed to represent Nurgle's tendency towards bombardment with pus and disease, so thats the theme I've run with. If weapons come across as clones, usually more an accident, I started the list by shaving out X number of spaces for new weapons and then writing in new ones - if you have submissions regarding weapons that could replace them I'm more than willing to phase out Imperial weapons to add more differentiation.
The Bident is a warhound weapon that appeared in the book Titanicus, and its something I'm trying out in all the Chaos Titan lists, if playtesting finds it to be horrifically powerful, it will be ammended as necissary not before.
Daemontitan, Because its a semi-different rule, and because its connected to the Titan and has nothing to do with it making a pact so much as it beeing a warp beacon - again with corpulent bulk, I'm willing to see it change, but I don't want to make things too great.
I'd just like to know which Champion I need to hand my lists over to so that they can get into officiality and circulation
PostPosted: Tue Jul 14, 2009 7:18 pm
May have to make a few ammendments now Neal has fashioned me with the old Chaos articles for Bubonis, got a wealth of new weapon and daemonic upgrades.
PostPosted: Tue Jul 14, 2009 7:47 pm
I'm using BlackLegion's very well written Red Corsairs Daemon Engines as the basis for stats.
PostPosted: Tue Jul 14, 2009 8:13 pm
LATD Engines are only likely to be recycled for the Dark Mechanicus list - BlackLegion has statted allot of Engines that have been introduced recently/by forgeworld.
