Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 13  Next
CHAOS Titan & Aircraft stats !
 Post subject: CHAOS Titan & Aircraft stats !
PostPosted: Tue Mar 11, 2008 4:15 pm
graywolf
they seem quite small. I'm worried that the sentinel fig will be to big for even the warlord titan.......
how big are thay.
and why not try somthing like putting the body under the leg mech, for the underslung look.
sg titan is about 7cm tall not including the base and if i was to stand him upright i could push for 8cm
http://s266.photobucket.com/albums/ii249/kev101/
PostPosted: Tue Mar 11, 2008 4:33 pm
hope this helps
PostPosted: Tue Mar 11, 2008 4:52 pm
Yes, those are cms, not inches. Actually Titans are 1/500 scale and Epic ground forces are 1/300. So a Warhound would really be as big as a Warlord titan. The pics E&C posted really helps, thanks E&C !  And the Warlord generally can have any of those weapons on any mounting point, carapace or arms, based on what system is used. However, The Macro/Quake Cannon, Volcano Cannon/Defense Laser and Plasma Cannon are usually considered Super Heavy Weapons and mounted on the carapace.  But if you look at my titan pics you'll see various weapons configurations.  Most of my Warlords are based on the AT1 cards and Codex Titanicus. And my Reavers and Warhounds from additional data from White Dwarf 109, when AT1 had just been released.  As some of the later titans I did, these were based on some of those changes with the newer rules.  But AT1/CT are good sources IMO ...
PostPosted: Tue Mar 11, 2008 5:11 pm
Also, keep in mind that the current MK III Warlord is a good cm or two taller than the MK I Beetleback.
PostPosted: Tue Mar 11, 2008 5:23 pm
Yes, the Carapace is higher on the Mk.III, but with the Mk.1's weapons they look pretty close.
PostPosted: Tue Mar 11, 2008 5:38 pm
[CODE]  Mk.III
PostPosted: Tue Mar 11, 2008 5:41 pm
[/CODE]  Mk.II
PostPosted: Tue Mar 11, 2008 5:45 pm
[CODE]  Mk.I
PostPosted: Tue Mar 11, 2008 5:50 pm
[CODE]  (early L4) Reaver
PostPosted: Tue Mar 11, 2008 5:53 pm
 Warhound Mk.1 (my EA Hound is SIB)
PostPosted: Tue Mar 11, 2008 5:59 pm
[CODE]  The Big "I" ... No reason to post these titan pics, but it makes what we're talking about a little clearer.  FYI- This Titan is mounted on a CD ...
PostPosted: Tue Mar 11, 2008 8:22 pm
Thx Evil and Chaos. that pic helped alot as it is the actual sentinel I have.
I have 2 of those sentinels and was going to under-sling them from the start.
And it helps as I was still deciding whether to make them as Warlords or Reavers but I'll make them as Warlords.
I found a site that listed all of the body parts for Chaos titans and I see they have a chainsaw tail. Can the warlord Chaos Titan have this?
and thx Legion 4 for more of your pics keep them coming....
AJ
PostPosted: Tue Mar 11, 2008 11:11 pm
Yes, any of those Chaos titan parts can go on a Warlord. THey were actually made for the Warlord. If you look close at my Chaos Reaver on pg.1 of this thread, I used one of the Khorne Titan heads ...   I figure you seeing some of my Titans gives you a better idea about the whole topic.  :D
PostPosted: Tue Mar 11, 2008 11:16 pm
I use 40K plasma cannons for plasm destructors and two plasma guns side by side for plasma cannoons.  So a single plasma gun could be used as a plasma blastgun
Tyranid air marshal
PostPosted: Wed Mar 12, 2008 1:55 am
I got some chaos weapons on order, [flamer, plasma- gun, melt-gun] its hard to find heavy plasma guns.
will try to do a hunt for one soon but I think I've got some good options.
what would be a good mix for two Chaos Warlord titans that will be fighting  Tyranid Bio-titans.
AJ
