Post new topic Reply to topic  [ 175 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11, 12  Next
World Eaters 3.7 - List Reviewed and Released
 Post subject: Re: World Eaters 3.7 - List Reviewed and Released
PostPosted: Sun Sep 02, 2012 1:32 pm
frogbear wrote:
While I can do a straight match for the Khorne Support Engine Warpcannons (Cannons of Khorne), I have to do some work on the Doom Blasters. In this case I would look for some point reductions which would/could mean stat reductions to bring them down to the 200 point costing in line with hellcannons. .
Doom Blasters a bit off their cost, lose 1 BP, and get IF. They would be no better than Whirlwinds without ATSKNF. This would facilitate prepping for assaults a lot, which is one of the weaknesses of the list. Alternatively, the 2 BP could be kept but with slow firing?
frogbear wrote:
I am unconvinced that Predators will ever make an appearance in a force and the same can probably be said for all the other marine vehicles (bar Rhinos). So I need a solution for all of these. .
Currently they allow retinues to place BMS, but the upgrade is too costly, thereby my proposition to include vindies. Alternatively, the Armor formation could always be included, and as the models are very readily available and the formation is both balanced and useful.
PostPosted: Mon Sep 03, 2012 4:09 am
Yeah I was looking at Doom Blasters dropping to 1 BP and possibly gaining Disrupt. With only a 45cm range with no indirect and limited to a formation of 4, this could be enough. If there is the wild gnashing of teeth and hair being pulled out over how 'powerful this is', I could always keep their speed at 20cm thereby taking away their ability to Garrison.
As for Marine armour, well that is another problem which causes gnashing of teeth from me. :{[]
PostPosted: Wed Sep 05, 2012 6:15 am
Any chance DB get IF?
What's the problem with SM armor formations in the army?
PostPosted: Wed Sep 05, 2012 7:11 am
frogbear wrote:
), the Daemon Engines would need to step up. So I will need to push the LatD AC to get a move on with these and see about reducing costs on these units. If support Engines (as above) come in at 200 points, we need something comparrable on the close support front.
Apart from reducing costs, why do you think 45 cm range on the weponry is necessary?
Could we not introduce the SM vehicle formation to have ranged fire support?
I have no internet for about 72 hours. Hence only have my iphone.
BY THE WAY: what is IF?
PostPosted: Wed Sep 05, 2012 7:15 am
As for SM Armour, it is a consideration if it adds to the list.
PostPosted: Wed Sep 05, 2012 7:48 am
Indirect Fire, and it took me a minute or so to click what it was too.
PostPosted: Wed Sep 05, 2012 8:19 am
Ah! Thanks for that.
That will be a no for now. Lets try without it as it is unique - IF is not.
PostPosted: Thu Sep 06, 2012 10:17 pm
I am sorry but what is unique?
PostPosted: Fri Sep 07, 2012 7:20 am
Unique is not having IF on everything so you can sit back and shoot like every other Marine, Eldar and IG Force.
Unique is not panderring to every idea.
The skill of the Doom Blasters is getting them within range, within LOS and in sufficient numbers to shoot and make an impact. It may not be for everyone, but some people (like me) like the challenge.
I have no desire to create a daemonic whirlwind at this stage which is what the suggestion would create.
PostPosted: Fri Sep 07, 2012 7:25 am
I don't understand what you have against daemonic whirlwinds?
The list suffers from a great difficulty to place BMs and deal with formations that retreat from assault range.
This formation would fill that niche nicely and fluffily.
Besides, DBs right now are a lowish save low range expensive small formation, just asking for trouble...
PostPosted: Fri Sep 07, 2012 8:55 am
My opponents hate it when i block large areas of the table with doomblasters and cannons. Give it try. What you have to understand is that this is not a standard marine or chaos list.
It does struggle at times and i am working on the ground element, however i would rather not change a unit to do something that it never has done.
Has it changed since Apocalypse came out?
PostPosted: Fri Sep 07, 2012 9:01 am
I summon Black Legion!
PostPosted: Fri Sep 07, 2012 11:43 am
*BAMPF!* As you wish master....
No. There is still the same Apocalypse datasheet downloadable from GWs site:
*looks it up* Hmm actually i can't find ANY of the Apocalypse datasheets anymore....
Anyway i put the sheet in this attachment. It's a Baneblade chassis with CC5+ and a 75cm 4BP weapon. It has NO Indirect Fire ability.
Chaos_Space_Marines_Datasheet_-_Doom_Blaster_of_Khorne.pdf [269.55 KiB]
Downloaded 2397 times
PostPosted: Fri Sep 07, 2012 12:21 pm
It's a WE?
Should these engines be 2 DC WEs?
For the IF, I stand corrected.
