Post new topic Reply to topic  [ 186 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 13  Next
CHAOS Titan & Aircraft stats !
 Post subject: CHAOS Titan & Aircraft stats !
PostPosted: Fri Apr 18, 2008 10:47 pm
Here are the Chaos Alters I made for Slaanesh and Khorne before I found out that CSM armies don;t have alters only Cultist armies do.  :O
Slaanesh Alter:
Khorne Alter:
Chaos Enemies Side by side:
PostPosted: Fri Apr 18, 2008 11:37 pm
Great looking stuff ! And may I suggest, use the Khorne Alter for a Deamon Engine of some sort ...
PostPosted: Sat Apr 19, 2008 12:07 am
Was thinking of using it as a DeathDealer variant. seems to fit in with the basic design of a deathdealer.
thx for the comments
PostPosted: Sat Apr 19, 2008 12:18 am
With Chaos and the Orks ... you can get away with a lot of stuff.  Yes, it'd make a good Deathdealer.
PostPosted: Sat Apr 19, 2008 6:43 am
decided I am going to cut off one of the chainsaws and replace it with a small claw. so it looks like more of a deathdealer.
will let you know how it turns out.
Do most players base there vehicles and daemon engines?
EDIT: Also for got to ask where would I go to find the rules/stats for the Juggernaut's of Khorne?
PostPosted: Sat Apr 19, 2008 6:54 pm
Some players do base the vehicles/Deamon Engine some don't ... normally I don't, so it's really up to your personal tastes.  Or if you need to base them to keep them from falling over.     As far as Khorne Juggers, the easiest (and best, IMO) fix is use CSM stats but movement of Rough Riders ... Same goes for Slanneshi Riders etc. ... Two or 3 on a base.
PostPosted: Sat Apr 19, 2008 7:07 pm
All Slaanesh riders and Khorne juggernauts I have seen have been used as 'bikes' of the used list.
PostPosted: Sat Apr 19, 2008 7:08 pm
THat's a good idea, rpr !
PostPosted: Sat Apr 19, 2008 9:53 pm
so bikes can be 2-3 figs per base?
I got plenty of Rough riders coming so don't need to use the Slaanesh riders at all but I'll use the Juggernauts as Khorne bikers for the Khorne CSM army...
AJ
PostPosted: Sat Apr 19, 2008 11:14 pm
I did 2 per Base ... You could mix one or 2 Slann Riders with the Rough Riders. Cultists, that have been mutated, or use them mixed in with your mutants ...
PostPosted: Sun Apr 20, 2008 12:08 am
I got bored in the weekend and decided to try my hand at making some epic sized buildings since we are going to be playing this game.  :D  :cool:
It stand about 100mm high which means my Warlord titans have some cover.
Slaanesh HQ
Will start making up some more slaanesh buildings and a Khorne Palace as well.
PostPosted: Sun Apr 20, 2008 5:51 am
Nicely done !  Both the Titans & Palace !
PostPosted: Tue Apr 22, 2008 12:12 am
Have started to paint up big mutants [aka minotaurs]
6x leman russ battle tanks, 3x baneblades, 4x basilisk, and 17x Chimeras in my Slaanesh cult colours....
will get some pics done on my bro-inlaws camera [his is so much better than my cheap as camera]
Also started painting the two converted Decimator super heavy tanks, and 5x chaos dreadnoughts in Khorne CSM colour schemes.
should have them all done by the end of the week if I can find the time....
still not sure if i'll base the tanks or not. last time i played epic i didn't do this but may try it this time....
got to find the right base first off then go from there.
cheers
AJ
PostPosted: Tue Apr 22, 2008 12:42 am
Pics are good ! :D
PostPosted: Tue Apr 22, 2008 9:11 am
I am thinking of making up some feral scout titans.
what would be the best weapon combination on these?
also how many should I field ? 1-2 or 2-3?
AJ
