Platoon based Steel Legion army list
 Post subject: Platoon based Steel Legion army list
PostPosted: Tue May 22, 2007 10:23 pm
Platoon Based Steel Legion Army List
Steel Legion Imperial Guard armies have a strategy rating of 2.  Steel Legion Imperial Guard formations and Imperial Navy formations have an initiative rating of 2+.  Titans have an initiative rating of 1+.
Special Rules:
Imperial Guard Commanders ? Some Imperial Guard units and characters are noted as being Imperial Guard Commanders.  Imperial Guard Commanders can order up to all of the formations that are a part of their company, added as a Support Formation to their company, or added as a Company Upgrade, to follow them when they make an assault, as long as all of the formations can trace 5cm unit coherency, even through other formations of the company, back to one unit within 5cm of a unit from the Imperial Guard Commander?s formation.
Alternatively an Imperial Guard Commander can order up to all of the formations that are a part of their company, added as a Support Formation to their company, or added as a Company Upgrade, to have the same orders of Advance, Double, Marshall, Overwatch, or Sustained Fire Orders and to fire upon the same target formation or combine barrage points as long as all of the formations can trace 5cm unit coherency, even through other formations of the company, back to one unit within 5cm of a unit from the Imperial Guard Commander?s formation.
Imperial Guard formations that are from a different company may be part of a combined assault or combined fire, but the number of formations that may participate are limited to 3 formations and there is a ?1 penalty to the activation dice roll for each formation from outside of the Imperial Guard Commander?s company.
Imperial Guard Command Rule ? Imperial Guard formations from the same company that can trace 5cm unit coherency, even through other formations of the company, back to one unit within 5cm of a unit from the Imperial Guard Commander?s formation are all considered to be part of the same formation with the allocation of casualties and blast markers.  If a formation of the company is within 5cm unit coherency of the command formation at the beginning of the move and at the end of the move then they are considered to have maintained that coherency during that move if attacked by units on Overwatch.
If a formation leaves unit coherency from the rest of the company (or the company command formation is destroyed) then the blast markers are proportionally distributed between that formation and the remaining units.
Imperial Guard Mass Movement ? The Imperial Guard are not as well trained nor experienced as the long-lived Space Marines or Eldar.  To make sure that such a large force can operate well on the battlefield the Imperial Guard relies heavily upon basic training and following the orders passed down from the chain of command.  To represent this the Imperial Guard player must activate three formations every time it is his turn to take an action.  Should the Imperial Guard player use an Imperial Guard Commander to combine the actions of multiple formations those formations count towards this requirement.  Any attempts to retain initiative after the three required actions will only result in one more action, not three separate ones.
Commissars ? All Imperial Guard companies may include 1D3 Commissar characters.  The Commissars do not cost any points.  If the dice roll exceeds the number of Commissar units that a player has available then these may be represented with other appropriate markers (certain colored dice, special counters, etc.) as long they are consistent and the other player agrees.
Roll to see how many Commissars a player may add to each company at the start of the battle before each player sets up.  If the company includes a Supreme Commander then the first Commissar must be attached to the Supreme Commander?s formation.  Any further Commissars may be attached to any other formations that are part of the company.  You may not include more than one Commissar per formation.  If you have more Commissars than formations then any excess are lost.
Steel Legion Companies
0-1 Steel Legion Regimental Headquarters Company - 500 points
1x Regimental Command formation of 1x Imperial Guard Supreme Commander unit and 1x Chimera
2x Mechanised Infantry Platoon formations of 6x Infantry units and 3x Chimera each platoon
2x Support formations allowed
3x Company Upgrade formations allowed
1D3 Commissars allowed
Steel Legion Infantry Company - 250 points
1x Infantry Command formation of 1x Imperial Guard Commander unit
2x Infantry Platoon formations of 6x Infantry units each platoon
Steel Legion Mechanised Infantry Company - 400 points
1x Mechanised Infantry Command formation of 1x Imperial Guard Commander unit and 1x Chimera
Steel Legion Tank Company - 700 points
1x Command Tank formation of 1x Leman Russ or 1x Leman Russ Vanquisher (has Imperial Guard Commander Special ability)
3x Tank Squadron formations of 3x Leman Russ or 3x Leman Russ Demolisher each platoon
Steel Legion Super Heavy Tank Company - 550 points
1x Command Super Heavy Tank formation of 1x Baneblade or 1x Shadowsword (has Imperial Guard Commander Special ability)
2x Super Heavy Tank Platoon formations of 1x Baneblade or 1x Shadowsword each platoon
Steel Legion Artillery Company - 700 points (750?)
1 Command formation of 1x Salamander Command vehicle (with Imperial Guard Commander Special Ability) or 1x Imperial Guard Commander unit and 1x Chimera
3x Steel Legion Artillery battery formations of 3x Basilisk, 3x Bombards, or 3x Manticore
Steel Legion Support Formations
(Two formations may be taken per Steel Legion Company)
Artillery Battery formation of either 3x Basilisk, Bombard, or Manticore units ? 250 points
0-1 DeathstrikeMissile Battery formation of 2x Deathstrike Missile Launchers ? 200 points
Flak Battery formation of 3x Hydra units ? 150 points
Orbital Support (Emperor class battleship) ? 300 points
(Luna class cruiser) ? 150 points
Rough Rider Platoon formation of 6x Rough Rider units ? 150 points
Sentinel Squadron formation of 4x Sentinel units ? 100 points
Storm Trooper Platoon formation of 8x Storm Trooper units ? 200 points
(may have 4x Valkyrie Transport vehicles) ? (+150 points)
Super-heavy Tank Platoon of either 1x Baneblade or 1x Shadowsword unit ? 200 points
Vulture Squadron formation of 4x Vultures ? 300 points
Steel Legion Company Upgrades
(Three formations may be taken per Steel Legion Company)
Adeptus Psyker character added to the unit with Imperial Guard Commander special ability ? 50 points
Fire Support Platoon formation of 4x Fire Support units* - 100 points
Flak upgrade of 1x Hydra unit added to the Command formation ? 50 points
Griffon Battery formation of 3x Griffon units ? 100 points
Hellhound Squadron formation of 3x Hellhound units ? 150 points
Infantry Platoon formation of 6x Infantry units* - 100 points
Ogryns upgrade of 1x or 2x Ogryns* units added to the Command formation ? 25 points each
Snipers upgrade of 1x or 2x Snipers* units added to the Command formation ? 25 points each
Tank Squadron formation of 3x Leman Russ or 3x Leman Russ Demolisher units ? 200 points
*  These units?s formations may have Chimera transport vehicles.  Each Chimera costs 25 points.  You must take enough Chimera to transport the whole formation if any are taken, but you may not take more than 1x Chimera per unit in the formation.
Imperial Navy Aircraft
2x Thunderbolt Fighters ? 150 points
2x Marauder Bombers ? 300 points
Titan Legions Battlegroups
1x Warlord Class Titan ? 850 points
1x Reaver Class Titan ? 650 Points
1x or 2x Warhound Titans ? 250 points each
PostPosted: Wed May 23, 2007 6:44 am
So I have a stack of small activations?
The game would fast become an activation battle - I would max my BM from firing at the enemy.
I can tell you from doing so much siege testing that activations count for a lot - if I can get 30+ I can smuther you with blastmarkers. It was a similar problem for the closest comparison, the original siegemaster infantry formation plus 2 flak gun formations during testing. 20+ activations and you won simply by breaking the enemy, the firepower wasn't enough to kill much (unless it was an infantry horde which also was the biggest danager) but a bm was a bm.
Here the strategy would be to break as much as possible before it activatives, then eek out formations untilt he enemy has all gone, then run rings round them.
PostPosted: Wed May 23, 2007 9:52 am
Sorry I see no justification behind completely destroying the known IG structures. The army list works quite well now.
Beside this I don?t see the influence of a single low ranked officer (platoon leader) in battles including bataillons full of troops. Leave it to a commander to lead the formation. Low level officers may be present but their job is to get their platoons where the commander wants them. So see them as invisible command structure to get the company work at all.
We do not need to copy all stuff from old games, especially if they make the existing game unwieldy and foremost unbalanced. Next step we try to design special rules for Marine Veteran Sergeants or Infantry grunts with MK41 hot pants from forgeworld "the 70s". All this things only make the game complicated without adding depth.
my 0,002 cents
PostPosted: Wed May 23, 2007 9:10 pm
Very Good points, all of you ... We still use the SM1 and some SM2 MTO&Es  ... They work very well for our purposes.  But you guys a really doing some good work regardless ... :)
