Ogryns poll and review
No change 73%  73%  [ 19 ]
Reduce Armour to 4+ 4%  4%  [ 1 ]
Remove Mega-weapon from Ogryn Close Combat Weapon 23%  23%  [ 6 ]
Up point cost (specify new value below) 0%  0%  [ 0 ]
Other (specify below) 0%  0%  [ 0 ]
Total votes : 26
 Post subject: Ogryns poll and review
PostPosted: Tue May 22, 2007 8:46 pm
Again, I hope I collected most of the suggestions for poll choices.
I'm kind of stuck on why Ogryns are given a MW CC attack.  The extra attack is fine, I just don't think it should be a MW.  Howling Banshees are all armed with power weapons and they don't even have a MW CC attack.  I think dropping that would be enough to bring Orgyns back in line.
Here's my purposed unit description, again with the cleaned up weapons section (in 40k Ogryns use the Ripper Guns themselves as weapons).
Ogryns
Type      Speed     Amour     CC        FF        Notes
Infantry  15cm      3+           4+        5+
Weapons             Range            Firepower                 Notes
Ripper Guns         (15cm)            Small Arms
AND                     base contact   Assault Weapons     Extra Attacks (+1)
PostPosted: Tue May 22, 2007 10:39 pm
Well Ogryns have a base stength of 5 increased to 6 because of the RipperGuns-as-clubs. This is pretty high. A Guardman equipped with a PowerFist has the same stats but doesn't ignore armour saves and strikes last. But against vehicles they have the same evectiveness.
