Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
Commanders?
 Post subject: Commanders?
PostPosted: Sat May 19, 2007 9:32 pm
Shouldn't the Tank company, Super-heavy Tank Company and Artillery Company include one vehicle with the Commander special ability?
PostPosted: Sat May 19, 2007 9:58 pm
(BlackLegion @ May 19 2007,21:32)
Er... why?
Commander is used to get multiple formations into assaults, something I certainly don't see Arty Companies wanting to do and I see it as usually unlikely for the other two formations as well.
Why do you think they should have them?  Commissars provide leader to remove BMs, and that's been good enough for the most part.
PostPosted: Sat May 19, 2007 10:05 pm
Well all three Infantry Company types have one. It's the officer leading the company.
Each company is led by an officer regardless if it is a lieutenant or a colonel.
It doesn't matter if the officer is walking around on foot or drives a tank. The abilites he has should be the same and that is Commander.
The (Supreme) Commander for Infantry units has this ability, why shouldn't the "Commander" of a tank company  have it too?
Commissars aren't supposed to lead troops. They advise the officers leading the troops and holding up the morale (by virture and example or by force doesn't matter). Yes there are exceptions (like Commissar-Colonel Ibrahim Ghaunt from the 1st Tanith Regiment) but it is not the rule.
PostPosted: Sat May 19, 2007 10:26 pm
I could see it on a Tank Company - lets them get in close and fire up close!
Airspace - AeroImp Forum
PostPosted: Sat May 19, 2007 11:05 pm
In real-life, yes ...  Based on SM1, the way we do it,  all plt. level units have commanders, as well as Co. Cdrs, a Bn Cdr and a Rgtl Cdr ...
PostPosted: Sat May 19, 2007 11:23 pm
(orangesm @ May 19 2007,22:26)
Well, the Vanquisher probably *should* be a Command tank, and I've always thought the Arty Company should have a Commander-and-Chimera attached to it, but I'm not sure how much it would add to to game to add them.
PostPosted: Sun May 20, 2007 12:16 am
But it is logical.
Same officers, same communication equipment. For Tanks even more so because communication devices could be bigger and more powerful.
Commander is the ability to stay in contact to nearby formations to coordinate a task together.
Yes Artillery Companies wouldn't use it because be engaged in a firefight or more worse closecombat is suicide for them. But the officers have the equipemt to do so if they wish. And Leman Russes and Baneblades surely would want to be engaged in firefights. Preferably with some infantry as back up. But if there are no infantry naerby its is better to have more tanks (a second or even third Tank Company) than to assault alone.
Leader is only there to hold the formation together so that i wouldn't fall apart as squads get lost during maneuvers in unknown terrain.
Leader is coordination of several squads.
Commander is coordination of several companies.
PostPosted: Sun May 20, 2007 6:06 am
What we may want to consider is how this is dealt with in other IG list.  The Steel Legion Commander only being in Mechanized Infantry Companies makes sense (assume the Infantry Companies are just dismounted) - it is a Mech Inf list.  But for say the Tallarn List - the Tank Company should be the Company that has the Commander ability.  Put the focus on the unit type that the list is focused on.
PostPosted: Sun May 20, 2007 7:50 am
Alright, if you're talking logic, reality etc., then all plts, Cos., Bns have a leader ...
PostPosted: Sun May 20, 2007 10:12 pm
Well, true ... So game-wise, you could standardize commanders, by unit and type...
PostPosted: Mon May 21, 2007 7:55 pm
(BlackLegion @ May 19 2007,16:32)
My Answer: Yes and no.
Yes, in theory every company, regardless of type, should have a commander. ?In real life you have that, and if your army is well trained enough then the commander for something like an artillery company might be well trained enough to recognize the tactical situation and coordinate nearby armor and infantry for an assault. ?They would probably even listen and follow his commands.
There is another reason why "Yes" would be my answer, but I want you to read the following first.
No, for two reasons:
1) Game Balance - If you were to allow every company to have a commander you would give the IG an unfair advantage. ?With the army list structured around buying companies and then adding on upgrades and supporting platoons you would be giving the IG more commanders than what other armies could normally generate.
3) Background - With the rigidly structured training and tactics that the IG would normally follow I seriously doubt that a Leman Russ platoon attached (support formation) to an infantry company would follow the dictates of the field artillery company commander. ?His own company commander, definitely. ?A Leman Russ Company commander, probably.
Which leads me to my other "Yes."
One of the things that has bothered me about the Steel Legion IG has been that almost everything is done at the company level. ?In effect what has been created is the situation where if the commander wants to make a combined assault then he has to have some support formations nearby (unlikely given how the army list is structured) or he is getting 1 or 2 other companies to assault with him (which means you are playing too many points on a small table or you have dangerously concentrated your forces.)
If you were to buy companies but have the individual platoons activate on their own, plus maybe some special rules on how IG commanders operate then I could see where every company would have its own commander.
1) When you buy companies you instead buy 2-4 detachments and a commander/command section. ?(A lot like how it was done in SM/TL) ?For example, if you buy a Leman Russ Armor Company you get a Command Vanquisher and 3 platoons of 3x Leman Russ tanks. ?When you buy an Artillery Company you get a Chimera (or some other appropriate units) with the Commander Special Ability and 3 batteries of 3x artillery units such as Basilisk, Bombards, or Manticores.
Implications:
A) The IG lose a lot of their resiliency because instead of trying to break a company you are only trying to break small platoons. ?This could be countered with a special rule that says that break point, blast markers, etc. are based upon the company as long as the platoons in question are all within 5cm unit coherency of at least one other company platoon. ?In a way this could become the Epic: Armageddon version of the SM/TL rules that the IG had to operate under, the IG Command rules. ?(You know, the pain in the ass ones about how formations had to stay within 25cm of the company commander. ?That is one thing I don?t miss about SM/TL!)
B) The commander, being his own formation, might become more prone to pinning or breaking if the special rule is not done.
C) Upgrades such as Ogryns, Snipers, Flak would become part of the command formation or other formations in the company while others such as Fire Support Platoons, Infantry Platoons, Tank Squadrons, etc. would become simply additional formations. ?These would be different than support formations in that they have greater availability.
D) It will be easier to add in new and different units such as the Leman Russ variants, the Forge World stuff, etc, because it will simply become just another line item in the army list.
E) Shooting oriented companies like the Tank Company and the Artillery Company would have their effectiveness reduced by not being able to bring a full company?s firepower on a target. ?The Tank company would be compensated by having a little more freedom of movement and could split fire on different targets. ?The Artillery Company would be more impacted since they typically don?t move and would not be able to combine BP at company strength. ?(See below for a potential solution.)
2) Every company would have its own commander, but it would only be able to use the Commander Special Ability on all of the platoons / squadrons / batteries in its own company without problems. ?Platoons / squadrons / batteries from other companies could be part of the combined assault but the normal 3x formation limit would come back and there would be a -1 penalty to the activation roll for each one included.
Implications:
A) The IG would not be able to mount huge assaults with three companies anymore, but it could mount large ones if a lot of support formations and upgrades are added to the company since the wording I used above means that the 3x unit maximum would not apply if only formations that are part of the company are combined in the assault.
B) The IG would need another special rule that would turn the normal Commander Special Ability into a more broad ability. ?The IG Commander rule would allow commanders to either have a company assault or fire.
3) The IG could see a huge jump in the number of activations. ?Either this would have to be accepted as normal for the IG (they are the human ?quantity is quality? army) or a special rule could be enacted that would require 2 (or three, or more) formations be activated per time.
Proposed Special Rules as part of this discussion:
Imperial Guard Commanders ? Some Imperial Guard units and characters are noted as being Imperial Guard Commanders. ?Imperial Guard Commanders can order all of the formations that are a part of his company, added as a Support Formation to his company, or added as a Company Upgrade, to follow them when they make an assault, as long as all of the formations can trace 5cm unit coherency, even through other formations of the company, back to one unit within 5cm of a unit from the Imperial Guard Commander?s formation. ?
Alternatively an Imperial Guard Commander can order all of the formations that have Sustain or Advance Orders and that are a part of his company, added as a Support Formation to his company, or added as a Company Upgrade, to fire upon the same target formation or combine barrage points, as long as all of the formations can trace 5cm unit coherency, even through other formations of the company, back to one unit within 5cm of a unit from the Imperial Guard Commander?s formation.
Imperial Guard Command Rule ? All Imperial Guard formations activate, fire, and take damage as per the normal rules. ?Imperial Guard formations that can trace 5cm unit coherency, even through other formations of the company, back to one unit within 5cm of a unit from the Imperial Guard Commander?s formation are all considered to be part of the same formation with the allocation of casualties and blast markers. ?If a formation leaves unit coherency from the rest of the company (or the company command formation is destroyed) then the blast markers are proportionally distributed between that formation and the remaining units.
Commissars ? All Imperial Guard companies may include 1D3 Commissar characters. ?The Commissars do not cost any points. ?If the dice roll exceeds the number of Commissar units that a player has available then these may be represented with other appropriate markers (certain colored dice, special counters, etc.) as long they are consistent and the other player agrees.
Roll to see how many Commissars a player may add to each company at the start of the battle before each player sets up. ?If the company includes a Supreme Commander then the first Commissar must be attached to the Supreme Commander?s formation. ?Any further Commissars may be attached to any other formations that are part of the company. ?You may not include more than one Commissar per formation. ?If you have more Commissars than formations then any excess are lost.
Is this worth pursuing?
PostPosted: Mon May 21, 2007 9:46 pm
I like it.
I think a possible solution is to instead of having Companies be individual activations, have them activated all at once.  This represents the orders you give the commander being done with his own twist.  This lets the artillery company all go on sustain fire and target the formation ahead, but can not have huge numbers of BP (which actually is not necessarily that beneficial).
PostPosted: Mon May 21, 2007 9:53 pm
Woa! You just put here the explanation for "complicated".
1. Splitting a company in 3+ formations would give the IG an insanely high amount of activations. The IG is supposed to be large numbers and unwieldly. Your proposal makes them very flexible.
2. If you say that each company needs an as part of the comopanys activation one activation roll for each platoon/squadron/battery to counter the high activation number you archive nothing else as to decrease the firepower of the company. Because some platoons could fail to activate, while others can shoot, etc.
Really this is too fiddly.
I agree, that the Artillery Company don't need Commander but i see nothing wrong in a Tank Company calling for support for an assault from a nearby Super-heavy Tank Company and an Infantry Company.
IG might be unwieldly but they can throw an insane amount of troops at single target.
