EDT BATREP: Elysians vs Space Marines
 Post subject: EDT BATREP: Elysians vs Space Marines
PostPosted: Fri Apr 14, 2006 8:05 am
Battle Report ? Elysians vs. Rainbow Warriors, 3000 pts
Elysian Order of Battle
This was my first battle with the Elysians and the new v2.11 list. Expecting Brett to take a fair number of Thunderhawks, I opted for a decent amount of AA assets in the form of Lightning interceptors. I also was planning on trying out the Drop Sentinels in a big way.
1 x Regimental HQ, 1 x SC, 8 x infantry
4 x Drop Troop companies, 1 x Command, 8 x infantry, 2 x Hardened Veterans
4 x Drop Sentinels, 4 x Sentinels
2 x Vulture squadrons, 4 x Vultures each
2 x Lightning squadrons, 3 x Lightnings each
Rainbow Warriors Order of Battle (from memory)
2 x Tacticals, w/Hunter, w/2 x Dreadnoughts, w/Leader
4 x Terminators, w/Leader
1 x Predator detachment (2 Destructors, 2 Annihilators)
1 x Scouts
Scenario
I have had this idea of running a ?linked? set of battles loosely modeled on Operation Market Garden for quite awhile now, and so Brett was kind enough to humor me as I work out the scenario details. The idea behind the scenario is to put the Elysians (or for that matter, the Space Marines) in a situation where their rapid strike capabilities can be used in a fashion similar to how we would normally expect a modern elite or airmobile force to operate.
In this version of the scenario, which is similar to the first map exercise I ever played with the Elysians, the dominant table feature would be a river which is impassable to most foot borne troop types, except for a large bridge. The goal of the attacking force would be to secure the bridge and the entry and exit points of the road that crosses the bridge. The reasoning for those objectives being that with those three points, then follow on assets would be able to enter the battlefield, get over the river and exit the battle field to other areas of interest.
So the victory conditions were:
Decisive victory: Control the bridge, and the entry and exit points on the road
Victory: Control two out of the three objectives
Loss: Control one out of the three objectives
Go back to Jump School: Control none of the objectives
Control is defined as having more unbroken units within 15cm of the objective than the opponent. Units that rallied from being broken at the end of the turn also do not count.
The victory conditions will be checked at the end of Turn 3 and if a decisive condition is not met, then a fourth turn will be played.
The board had a lot of hilly wooded terrain on it, bisected by a large river running SW/NE, a large bridge near the center of the board and a road that runs roughly N/S. Also on the North side of the board were some industrials complexes.
Also to add a little, uh, ?spice? to the game, I had modeled an objective marker with a wrecked rhino, a wounded commander, and a command squad which just so happened to be in the livery of the Rainbow Warriors (boy, think of the odds of that happening by chance).
Initial Deployment
I can honestly say, that I was excited about trying out the new list, but wasn?t so sure that running up against the SM?s who are the supreme drop troops, was going to be the kind of opponent that I really wanted to butt heads with. Still, it looked to be a very interesting match up and with the high mobility of each force, liable to be full of twists and turns. Little did I know?
Turn 1
So, with the initial teleports, Brett was deep into my backfield with a nasty number of terminator squads and I knew that if I didn?t deal with them, then they?d run roughshod all over my side of the board. However, I felt like I had just the answer for that in my Drop Sentinels and their macro weapon attacks. So as Brett started placing his Termies, I followed up with Sentinels. The Sentinels really needed to clear the termies out as soon as possible to allow follow on drops to get to the bridge unimpeded.
Another play I needed to get a handle on was the air game. Since Brett had not taken any air assets (they fell off their bases pre-game), I needed to be able to allow my aircraft to attack where ever they needed and that meant getting rid of the Hunters. The opening shots from a Vulture squadron took care of one of them, as well as knocking out two rhinos from one of the tactical squads, but unfortunately, that just sequed into the Terminator/Sentinel salsa dance. Oddly enough, I was able to severely damage (left one stand) or wipe out two formations for the cost of one Sentinel squadron and things were looking pretty good.
Brett on the other hand, used his terminators to just wail on a Vulture squadron, causing them to break. That hurt because I really had plans for those Hellstrikes. Bummer.
One Lightning squadron came in to finish off the stubborn terminator, while the other picked on the Preds who had tripled over to the middle of the board heading for the entry point as quickly as they could. One pass later and two were gone. However, being Space Marines, they were not broken and so remained a thorn in my side.
Turn 2
Brett drops another Terminator in my backfield and another near the bridge. I try to control my enthusiasm. I was starting to get this uneasy feeling that I didn?t have enough guns again (comes from playing other armies besides Tau). Still, the Sentinels teamed up again with a Drop company and wiped out another terminator squad. So that was three down.
However, it didn?t all go my way. By now, the other tactical unit and scouts had gotten close to the bridge and were in a very solid position. Unfortunately, this solid position also turned out to be a solid ?firing? position and some of my Drop companies began to suffer the ill effects of bolter, assault cannon and dare I say it, assaults. At this point, I?m starting to see my thrusts towards the bridge start to falter.
I need my aircraft to come in and save my rear end, and to facilitate that effort, the lone Vulture from the previously shot up squadron, spies a Hunter leading a tactical formation and introduces it to Mr. and Mrs. Hellstrike.
That?s the ticket! Now the flyboys can come in and be heroes. Unfortunately, that fire support request must have interrupted a poker game or something, as one squadron doesn?t show. The other is a little ticked that they fell for the ?you go ahead and scramble and we?ll be right behind you? line and decide to save their ammunition for later in the game.
Consequently, a broken Terminator unit remains untouched, leaving me with two potential formations on my side of the bridge, plus a nearly full strength tactical unit on the other side.
Also, my other Vulture unit decides to stay close to the baseline so that they are not accused of appearing too aggressive, should this effort not turn out for the best and there ends up being some sort of War Tribunal or something.
Turn 3
In what probably turned out to be the most futile move all game, I drop a company into the industrial complex in an attempt to contest the exit point on the road. Bad move. The rear most tactical unit moseys on over and blows me out of the buildings without hardly breaking a sweat. I think Brett was +12 on the roll for resolving the assault. Sigh?
The other tactical unit not wanting to be left out of all the fun, skips down to the river bank and using an impressive amount of automatic fire from across the river, strips the nearby forest of leaves, branches, squirrels, and a fair number of Elysians.
Also, in a display of tactical brilliance, Brett helps me figure out the best way to attack the scouts who are anchored on my side of the bridge, which I then promptly whiff on.
We look at all our stuff and where it is lined up and I have the entry point, Brett has the exit point, and we?ve got the bridge contested.
So, off to Turn 4 we go.
Turn 4
I don?t know why this turn seemed to take so long, as we were both starting to run out of units?well, maybe it was just me that was running out. Anyway, I attempted to assault the bridge again, bounced out of the assault, thus ensuring that my by now very small, supporting formations also break, leave me standing out in the wind.
Brett?s Predators shoot up a three stand unit holding my end of the road, causing me to loose that objective. The flyboys finish up their poker game and break the scouts on the bridge and although they do a decent amount of damage to the remaining tactical formation, it?s not enough to break them and so the Rainbow Warriors grab a victory by holding the bridge and the exit point. ?
After Action Report
Wow! What a cliff hanger!
So again, I saw the Elysians strike hard and apparently get off to a good start in the early stages of the game, only to see my advantage slowly slip away by the end. Oddly, I?m not disappointed with this behavior as I?m still getting the timing of attacks down, and the fact that the Elysians in no way operate anywhere near like my Tau,, means that I still have a way to go, when it comes to understanding how to best use them.
As you can see, these two armies traded blows back and forth all game long and I do take some comfort in the fact that a fourth turn was forced. However, what I really missed in looking back at my other games with the Elysians is the fact that I did not take any Valkyrie transported units this game and the lack of follow up mobility really hurt me in the latter turns.
Also, even though I failed some rather important rolls, I don?t think the dice ended up favoring one side or the other. There were times when we both had to look at each other and just smile because either somebody who really had to move didn?t, or the hits we were counting on to sustain our momentum either didn?t arrive or were saved. So, overall, I?d just have to say that they were a wash.
Once again, I did not use the Iron Discipline rule and in this game, I think it would have helped me a couple times, not with rallies, but in keeping units from breaking. So, eventually I?ll get that into my game plan. I think the heroes on my side were the Drop Sentinels. Even though they were all wiped out, their macro attacks really helped me hold off the terminators while I was working on getting my infantry into assault positions. If I hadn?t of taken them, I?m quite certain that the Terminators would have locked me up by the end of Turn 2.
So, I?ll go back to the drawing board as far at my list goes and do a re-think. The list is close to where I need it, but somehow I need to figure out a way to hit hard, keep mobile, strike unexpectedly, and defeat all serious threats when required?piece of cake.
Great game, Brett!
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Fri Apr 14, 2006 8:17 am
Hmm, do you think the ability to planet fall rather than teleport troops into captured/contested objectives would help? (Imagine gliders or further drops into established beach-heads.)
Of course, could always give them spirit stones :)
PostPosted: Fri Apr 14, 2006 8:31 am
Hmm, do you think the ability to planet fall rather than teleport troops into captured/contested objectives would help? (Imagine gliders or further drops into established beach-heads)
Actually, I'm rather puzzled as to why you might make that suggestion. From what I read of the PF rules, there is less precision associated with the drop than if a unit teleports.
I know you brought this up once before, but I think that teleport is a better mechanism for how the Elysians should operate.
Also, I had a couple of misplays and functional weaknesses in my list that contributed to some of the pain I was feeling.
I'll get better.  :/
We collected some in our last battle and it made the Eldar rather angry.   :p
Honda
PostPosted: Fri Apr 14, 2006 9:49 am
Its mainly to cut down the blastmarkers collecting on units, which can be a fair bit when you come in. Contributes to any wilting going on.
PostPosted: Fri Apr 14, 2006 2:37 pm
Fair enough statement.
From what I can see at this point, managing the BM's hasn't been what I've been struggling with. Since there aren't a lot of ranged weapons in the drop companies, then they tend to be less concerned with BM's as they are almost always assaulting.
Also, given their lack of mobility (relatively speaking), not landing where you need them to be could become extremely problematic. Any unnecessary exposure to shots means that you almost always start taking off units as there are very few armor saves in this army.
So, on the surface it might seem like saving 1 or 2 BM on the way in might sound tempting, in the long run a less accurate drop (not to mention the potential loss of a unit that goes off the board) would be more painful that what they are currently experiencing.
I should also mention that I have yet to take any Commissars (for fluff reasons), whereas others fielding the Elysians will not be under the same self-restriction.
Honda
PostPosted: Fri Apr 14, 2006 4:05 pm
Good report Honda.  I would think the addition of at least one if not two Valkyrie transported units would have helped here.
It would have given you the mobility you needed, and it would have helped pack an extra punch in the form of some extra BM's.  Those extra BM's can really help against marines because they need so many to actually break a unit.
I think I am pretty happy with the way the list is shaping up.  Seems like everyone else thinks marines are one of the weakest armies out there right now (general opinion) - so I am a little concerned we aren't running roughshod over them like a lot of other armies - but really it doesn't concern me that much, as I would rather have to tweak the army up later than trying to remove power from it.
I'd like to see how this army performs against orks and/or tau  - I think it would have a much tougher time, just based on how it plays against marines.
Anyone have any Tau opponents near by to play against?
PostPosted: Fri Apr 14, 2006 7:17 pm
Good report Honda.
Thanx! The game itself was extremely engaging (as evidenced by the lack of photos) and Brett is a great person to play against. We had a truckload of fun.
By the end of the game I had come to the same conclusion. Not only the additional BM placement, but being able to pick up and move when needed is a feature of the list that we'll need to take advantage of as much as possible. I wanted to see what a pure "drop" army might do and although there are circumstances where it might work out Ok, as you suggested, the Elysians really need a unit or two that can fly around.
So, denormalizing this foot list into more of an airmobile/drop will be my next iteration.
It would have given you the mobility you needed, and it would have helped pack an extra punch in the form of some extra BM's. ?Those extra BM's can really help against marines because they need so many to actually break a unit.
Very good point. I found myself continually looking for formations that could place even one blast marker on the SM's so that I could at least get some + modifiers in an assault. With their armor and my lack of it, I was almost always behind when we were rolling for resolution.
I think I am pretty happy with the way the list is shaping up. ?Seems like everyone else thinks marines are one of the weakest armies out there right now (general opinion) - so I am a little concerned we aren't running roughshod over them like a lot of other armies - but really it doesn't concern me that much, as I would rather have to tweak the army up later than trying to remove power from it.
Well, I am far from being a master tactician by any means, but a lot of the time, I have to question how people play the Space Marines. From the get go, I have been telling our SM players not to use them like you would in 40K, they're only going to die as Epic plays differently. From my perspective, SM's are a smash and grab kind of force and if you spend time driving across the table or trading shots with someone with superior firepower, then they're always going to struggle.
I still remember my first real game of EA against a plain vanilla SM force and it left an impression on me. I looked at the things the opponent did that went very well and I looked at what was less than successful. When the opponent "dropped from the skies" or teleported in and then used his high strategy rating and initiative, he literally beat us to death. In other areas, he tried to drive them across the field and they suffered. So, from that experience I learned that the 40K way is the wrong way to run them.
Now, all that ranting (I plan on proving my point by eventually building a SM force) to get to my original point which is, in this scenario, I think both the Elysians and the SM got to play to their strengths and when the SM's do that, they are quite nasty indeed.
I'd like to see how this army performs against orks and/or tau ?- I think it would have a much tougher time, just based on how it plays against marines.
Orks will be a very tough match as well. What I learned from my initial map exercise against the Orks is that Valkyries and Vultures are going to be your friends as with all their LV and infantry, you always have targets to shoot at. Where the Elysians start to struggle (and they should) is against forces with a high concentration of armored vehicles. In last nights' game, I had a decent amount of armor to contend with.
If Tactica can be separated from his newly acquired Eldar for a little bit (my precioussss) , he might help out there.
Honda
PostPosted: Fri Apr 14, 2006 7:27 pm
Cool table and report thanks for writting it up for us.
PostPosted: Sat Apr 15, 2006 12:54 am
+++++Comms Open+++++
Brothers Rejoice!
  Noble Brother Captain Glavius has survived his wounds and will be rejoining his brothers in arms.  After securing both objectives imagine our revelation to find him alive near the bridge, Traitor Droptroopers piled like cord wood around his destroyed Rhino Light of the Imperium.
  He fights with us yet again Brothers! (Supreme Commander here I come!)  To victory goes the spoils.  Sadly we do not need any flashlights the Traitors have left us....
+++++Comms Out+++++
    Great game, trading punches left and right.  After turn one I was a bit apprehensive.  Losing two stands of terminators was costly, but it did give me enough time to move the rest up and into contention.  Some good dice rolls either way would have really, really swung the game.
  Honda has a good feel for his list, and had I not thrown the subterfuge of 6 Thunderhawks into the mix, I'm sure he could have found better use for the points.  The Lightnings did do some damage, so all was not lost.
 I really enjoyed this game and can't wait to try it again!
Thanks Honda, Good Game!
