IG Stormhammer stas
 Post subject: IG Stormhammer stas
PostPosted: Sat Nov 26, 2005 11:40 am
Has anyone tried to write some stats for the old IG stormhammer? i know there are some offical stats in the E:A rulebook (although no point cost), but they simply seem to weak for me: the old Stormhammer  of SM was the ultimate close-firing killing machine, with all those bolters and cannons, and it's enormous CAF. Now it's an almost useless piece of junk, as it can only inflict 6 hits (provided you have a lot of luck), and only at a range of 30 cm, which generally means that the enemy will be in a position to launch an assault against it, so the tank will have to go with that 6+ CC value... i think they are ridicully powerless if compared with the Baneblades and Shadowswords.
Any ideas?
"It would be most ilogical if i let you kick my ass"
-Spork, son of Spoon son of Fork
PostPosted: Sat Nov 26, 2005 1:59 pm
For simplicity we are going to use the Storm Hammer and all Baneblade varients as Baneblades ...    And Shadowsword/Stormblade varients as Shadowswords ... Between all the G/W and F/W models it only makes sense to us ...   But I'm glad they put the all the stats in the back of the rules.   I like options !  :;):
PostPosted: Tue Nov 29, 2005 9:06 am
The Stormhammer should have higher Firefight value as well as more heavy bolters. In SM2 it had, IIRC, 14 (!) bolters so 8 or so Heavy Bolters wouldn't be an overstatement.
Also, it should have two twin Conqueror cannons rather than demolisher cannons, as the Conqueror cannon is essentially a shortened battle cannon and that's what the Stormhammer had in SM2. The stats of the cannon are in the profile of Leman Russ conqueror.
