Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5
Results from the NDC Step 3 vote regarding Imperial Gu lists
 Post subject: Re: Results from the NDC Step 3 vote regarding Imperial Gu l
PostPosted: Sat Oct 05, 2019 8:43 pm
Largo_W wrote:
I am asking about the changes you put forward, DKOK Warhound and Baran
I need to check because it’s been a while, but from memory Baran and DKoK tweaks (the NDC ones) are also with ERC.... I should have a good opportunity to catch up with what’s going on next weekend.
If you’re looking for some sort of answer or definitive update immediately you’re going to be disappointed, give me a fortnight and a couple of PMs to keep me on task and we should get somewhere.
PostPosted: Sat Oct 05, 2019 10:29 pm
This is all we got for DKoK and BSM:
DKoK:
DKoK: Remove single warhounds from list.
Siege Masters:
Make Flak battery 150 points from current 100 points.
Bunkers become difficult terrain for WE:s with clarification that WE:s can't barge units out of bunkers.
Add no barging rule to trenches (se suggestion for bunkers).
Steve posted that on 2018-09-16, they were voted on, approved and in the TP the next day.
Squats 2018-05-15
PostPosted: Sun Oct 06, 2019 12:12 am
DKoK:
Siege Masters:
Yep, they’re the ones. Thanks Dave.
PostPosted: Sun Oct 06, 2019 7:16 pm
Great, thanks for the update! Was a bit in muddy waters here as no update came through "here" :)
Looking forward to your update after the tourney!
PostPosted: Mon May 04, 2020 1:27 pm
Did the fire support for DKoK get adjusted also?
Latest PDF stafes 4 stands, Army builder states 6
PostPosted: Mon May 04, 2020 1:49 pm
As far as I'm aware the TP is correct.
Squats 2018-05-15
PostPosted: Mon May 04, 2020 2:05 pm
so 4 bases is it... right? when did this change... as it was not listed in the changelog? (or i am just to blind to spot it somewhere)
PostPosted: Mon May 04, 2020 2:27 pm
Not certain if that's actually a change. Checked the original published list from Epic: Siege and it was 4 units back then as well. Doesn't mean that it wasn't bumped to 6 at some point. Could have been a simple transcription error when put into army builder. OTOH Matt Shadowlord kinda had a habit of making "official" changes that never got actually approved. Could have been one of those. Might be worth digging through his posts?
edit:
pertinent posts I found on that topic in this section
https://www.tacticalwargames.net/taccmd ... 03#p631503
https://www.tacticalwargames.net/taccmd ... 19#p578919
From my digging it appears this 4-6 happened as part of Matt dreaming it up in this timeframe. Can't see anything discussing a it ever being put to a vote and actually approved.
https://www.tacticalwargames.net/taccmd ... 74&t=30347
Matt collates here what was approved from that pdf above
https://www.tacticalwargames.net/taccmd ... 68#p606068
