Post new topic Reply to topic  [ 80 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
Cadian Shock Troops v1.2
 Post subject: Cadian Shock Troops v1.2
PostPosted: Wed Mar 30, 2011 9:02 pm
v1.2 Changes
Core:
None
Upgrades:
None
Support:
Added Armored Fist Platoon
Fortifications:
Wording changed to "Up to 50cm of trenches, and up to six gun emplacements."
Allies:
Marauder Colossus stats redesigned (see units) Cost changed to 300pts.
Units:
Stormlord FF changed to 3+. Typo/Holdover from v1.0.
Marauder Colossus: Colossus Bomb changed to fit background. Stats changed to 15cm, 3BP, IC, Fixed Forward, Slow Firing AND MW2+ TK(d3), Fixed Forward, Slow Firing. Turrets separated into one 15cm, AP4+/AA5+ Forward Arc, and one AA5+ Rear Arc. Added note: The Colossus Bomb’s MW attack must target the unit closest to the center of the Barrage attack.
Elite special rule changed to flat +1 to rally.
With any luck this is a list that can stay relatively stable in terms of structure and unit stats, so we can get some real playtesting done to hammer out costs on the new units.
Here's the link to the previous versions thread: viewtopic.php?f=74&t=20430
cadians v1.2.pdf [132.77 KiB]
Downloaded 663 times
Last edited by Spectrar Ghost on Tue Jul 19, 2011 10:57 pm, edited 2 times in total.
 Post subject: Re: Cadian Shock Troops v1.2
PostPosted: Wed Mar 30, 2011 9:28 pm
Thanks for the update.
I expect to have my basic infantry models ready in ~1 week, after which I'll do lots of playtesting.
PostPosted: Fri Apr 22, 2011 4:00 pm
Got another game in last night with the following list:
Cadian Regimental HQ 650
1 Supreme Commander with Commissar
7 Kasrkin
1 Leviathan
2 Battle Psykers
Kasrkin Company 425
1 Commander with Commissar
7 Kasrkin
1 Stormlord
Kasrkin Company 425
7 Kasrkin
1 Stormlord
Griffon Platoon 200
6 Griffons
Griffon Platoon 200
6 Griffons
Super Heavy Tank Platoon 200
1 Shadowsword with Commissar
1 Stormsword with Commissar
Artillery Battery 250
3 Manticores
3 Manticores
Played against a Biel Tan drop list. Now this was the first time my opponent had played such a list, but nonetheless he made a good showing, trapping and destroying one of the Kasrkin Companies on the drop. I did win 3-0 (BTS, TNH, TSNP) in the end.
Thoughts: This army is capable of bringing a LOT of templates to the party. The count for my list maxed out at 2-6 Disrupt, 4 Standard, and a MW template per turn. Against an infantry heavy force, they are brutal. I'm not sure it's more than a Steel Legion army could, in fact I doubt it, but it's worth mentioning. It also is confined more towards the direct fire and fire support than the Steel Legion, whose templates tend towards true artillery.
There is also the opportunity to have a great number of Superheavies. Given the importance of the Cadian gate, I'm not sure this is a bad thing, but should be watched. It should also be mentioned that the living Kasrkin company singlehandedly took the TNH objective, and that the Cadian RHQ was instrumental in fighting off the drop (firing the shot got me TSNP as well), so in that manner the infantry had a disproportionate influence on the game even with the number of SHTs I took.
PostPosted: Thu May 05, 2011 3:25 pm
I've been thinking about the fighting platforms on the Stormlord and Leviathan for the past few days. I'm concerned they are open to gamey abuse. Here's what I mean.
I have an RHQ with Fire support and two Psyker upgrades. I can move forward and fire from the platform with 4 Fire Support and the Supreme Commander. If I then get assaulted and pinned inside, I can FF with 4 Kasrkin and the two Psykers. This seems gamey, if not entirely unrealisitic.
Now, I like the Platforms from a fluff standpoint, especially on the Stormlord, but I'm concerned that the abuses may outweigh the thematic concerns. However, they do make staying inside a 15cm transport more attractive. What are people's opinions? Are the potential problems greater than what they bring to the units they are on?
PostPosted: Thu May 05, 2011 3:32 pm
How about:
Fighting Platform
Some super-heavy vehicles are equipped with a fighting platform which allows transported troops to take part in anassault.
Any transported unit in a unit with the Fighting Platform ability can't be trapped inside their transport vehicle if to much enemy units are in base contact to the transport.
PostPosted: Thu May 05, 2011 4:09 pm
Interesting. Definitely simpler, but as of now the Leviathan, for instance, is only able to FF 6 of it's 16 stand capacity. This is offset by the ability to hit the units directly. Also, there's a good likelyhood that the units will be fighting CC, not FF, as they should from a platform.
Would it be easier to remove the ability to shoot from the platform, so the units that should be using it are always the same?
PostPosted: Mon May 09, 2011 5:00 pm
i'm curious about the list, where is the stormlord mentioned in the list construction.. i can't find it, but i see what the stats are...
Is it under super heavy tank platoon, or did you accidentally forgot to add it? Also what is the stat.. IC.. sorry haveing a blonde moment.
PostPosted: Mon May 09, 2011 5:28 pm
Stormlords are under the "Assault Transport" Company Upgrade: add one or two at +200pt each.
IC is Ignore Cover. IIRC there were some spots there wasn't room on the line to spell it out.
PostPosted: Mon May 09, 2011 11:30 pm
thats cool. i found it. thanks again.. i forgot the shorthand for ignore cover
PostPosted: Mon Jun 06, 2011 12:35 pm
Has anyone else been able to do any playtesting on this list yet? I've had a terrible time getting a game in the last month, so I've had little opportunity.
PostPosted: Mon Jun 06, 2011 12:58 pm
Getting my first game in this thursday.
I'll be using a downgraded Leviathan main cannon stat, though, because that thing is obviously overpowered.
PostPosted: Mon Jun 06, 2011 8:28 pm
I'll probably use this list:
Cadian Reg HQ - 600pts
2x Psykers - 50pts
Cadian Infantry Company - 250pts
2x Snipers - 50pts
Whiteshield Company - 200pts
Sabres - 100pts
Basilisk Platoon - 250pts
Tank Platoon - 400pts
Sentinel Squadron - 100pts
Storm Trooper Platoon - 350pts
Baneblade - 200pts
Flak Battery - 150pts
Thunderbolt Fighters - 150pts
Marauder Bomber - 150pts
PostPosted: Mon Jun 06, 2011 9:58 pm
How are you downgrading? Range?
PostPosted: Mon Jun 06, 2011 11:10 pm
I was thinking of dropping the range to 90cm, for starters.
Being able to sustain into an opponents deployment zone with a mw template on turn one... Not likely to be good.
PostPosted: Tue Jun 07, 2011 12:32 am
LOL.....Not good for the opponent but good for the user! ::)
