Elysian/Vanaheim questions.
 Post subject: Elysian/Vanaheim questions.
PostPosted: Sun Feb 20, 2011 4:38 pm
I'm trying to plan a Vanaheim List, possibly to cross over as an Elysians as well. I have most of the items figured out: EW Valkyries and Transports for Valks, Vultures, and Vendettas, EW Legionnaires as Stormtroopers, and I think I may have a good idea where to get my basic troopers as well ;) .
The main hang ups are air support and Sentinels. I'm trying to keep costs down, so no GW or FW if possible. I'm considering using Kazari Raiders as Sentinels in a Vanaheim list, and as Tauros in an Elysian list, but that means I'd still want Sentinels for the Elysians. Are there any good Sentinel proxies out there? As for air cover, I'd really like something less expensive than the FW models for the T-Bolts and Lightning Strikes. Are there any good proxies, or am I stuck? The DRM Kronos looks good, but I don't know what size it is? And that would only cover one of the two.
Does anyone have any suggestions?
Last edited by Spectrar Ghost on Tue Feb 22, 2011 2:52 am, edited 1 time in total.
 Post subject: Re: Elysian/Vanaheim Models questions.
PostPosted: Sun Feb 20, 2011 5:00 pm
I'll measure a Kronos for you later, but from memory they're about 4cm wide.
 Post subject: Re: Elysian/Vanaheim questions.
PostPosted: Tue Feb 22, 2011 3:02 am
Follow-ups: Aside from taking a Fire Support Platoon to split the BTS and SC, is it worth taking company upgrades in a Vanaheim list? I really only mean the Infantry, Fire Support, and Mortar Platoons, the Vendettas will be appearing. It seems taking a Mortar Platoon would be useful at times, as it would allow two BP6 barrages on top of two Vendettas, and 2BP/turn after that. Of course, that assumes I'm able to keep them outside the vehicles, essentially a Double or Advance under 30cm initial range, or Sustain.
Which are preferred, 2 Lightning Strike Squadrons or a Vulture Squadron? LIghtnings have the endurance, but Vultures can put out more firepower in a single turn, and can capture/contest. I'm leaning towards Lightnings more, though I have a Vulture Squadron in my current list also.
The list I'm considering consists of :
Vanaheim Regimental HQ 500
3 Valkyrie
2 Vendetta
1 Supreme Commander
9 Infantry
Vanaheim Infantry Company 400
3 Valkyrie
2 Vendetta
1 Commander
9 Infantry
3 Valkyrie
2 Vendetta
1 Commander
9 Infantry
3 Valkyrie
2 Vendetta
1 Commander
9 Infantry
Storm Trooper Platoon 350
4 Valkyrie
8 Storm Troopers
Vulture Squadron 300
4 Vultures
Light Sentinel Squadron 100
4 Light Sentinels
4 Light Sentinels
Lightning Strike Fighter Squadron 150
2 Lightning Strike Fighters
Thunderbolt Squadron 150
2 Thunderbolts
Any C&C?
PostPosted: Tue Feb 22, 2011 9:53 am
To follow up, the Kronos is 4.75cm wide (wingspan) according to the file I have on my computer.
It is 4cm long, nose to tail.
PostPosted: Tue Feb 22, 2011 11:13 am
From my experience playing against the list (A sum total of twice, both of which were wins to me), I'd say generally it's not worth taking anything that must be paid for, other than to get a non-SC BTS.
Always take the maximum ammount of Vendettas though, because they're free (in this list), and are better than Valkyries.
I'd never take the Mortars upgrade as you lose Disrupt on your barrage attacks.
Personally I'm a fan of Vultures.
Any aircraft-heavy list is going to suffer against Tau or Eldar.
PostPosted: Tue Feb 22, 2011 2:29 pm
So, approximately the size of the FW TBolt (5.5cm W x 5cm L).
I totally missed the loss of Disrupt, can't believe it.
I should be OK on the AA front for a little while; the local meta is virtually AC free, so it should be surprising until I play enough people to affect it. :) After that, wel'll see.
Thanks for the tips.
PostPosted: Tue Feb 22, 2011 5:40 pm
A Mortar platoon will only get two BP, plus 2 OS, Disrupt BP from the Valk. But the conclusions hold, more or less. It's something to think about.
PostPosted: Tue Feb 22, 2011 5:59 pm
SC/BTS: I don't think it's necessary to force these into separate formations. Yes, it's 2 targets on a formation instead of 1 target on 2 different formations, but that also means that if you are reduced to needing to hide or protect it, you are only pulling 1 formation out of the fight instead of 2.
PostPosted: Tue Feb 22, 2011 6:07 pm
You'll note in my initial list that I haven't done so. What you say is true, but it also means my opponent has to either split the fire he could otherwise level at a single formation, or decide which formation is more important to destroy. On average, I split them when it is convenient, but don't make it a hard and fast rule.
PostPosted: Tue Mar 08, 2011 11:10 pm
How are the Marauder Destroyers in the list? 2 bombers with 4+ saves and a sizable amount of standoff weaponry seems like a steal at 275 points.
Users browsing this forum: No registered users and 89 guests
