Salamander Scout Tank: 'Counts as': Chimera?
 Post subject: Salamander Scout Tank: 'Counts as': Chimera?
PostPosted: Wed Oct 20, 2010 6:51 pm
As above: all the GW rulebook lists the Salamander as counting as is a Salamander! I've got a whole bunch of these sitting around and want to parse my IG collection down a bit before revamping it but also want to use things at tourneys.
Has anyone got any idea what the Salamander is actually, officially, meant to count as?!
I'm sure no one in the UK tourney scene would give a stuff if I say they're Chimera's but you never know with some tournament organisers!
MoK's Painting Blog
Now Showing:
 Post subject: Re: Salamander Scout Tank: 'Counts as': Chimera?
PostPosted: Wed Oct 20, 2010 6:56 pm
I've seen them used as Chimeras at events, I usually use them as Land Transporters in a LatD list or you could use them as Salamanders in an Ulani Tank list.
PostPosted: Wed Oct 20, 2010 7:03 pm
Residue of when SG intended to actually release a Steel Legion Salamander (With an enclosed cab) I guess.
I've seen them used as "command chimeras" in Steel Legion lists.
Alternatively the Minervan Tank Regiment list from Epic Raiders has them.
PostPosted: Wed Oct 20, 2010 8:04 pm
Chimpa's it is then :-)
R>
MoK's Painting Blog
Now Showing:
PostPosted: Thu Oct 21, 2010 1:37 pm
Think I'll keep em for now I'm afraid Rug...but if OtteryAPC's are to my liking in a couple of months time and yr price is right then we can chat :-)
MoK's Painting Blog
Now Showing:
PostPosted: Thu Oct 21, 2010 1:57 pm
Pretty sure this is correct. I seem to recall that Salamanders were one of the intended new sculpts that were eventually pulled from the test lists after it became apparent they would not be done in time for the release. IIRC, the IG arty company was 9 arty units and a Salamander command unit (but that was a long time ago and I might be wrong).
PostPosted: Thu Oct 21, 2010 2:00 pm
The Salamander model was actually completed IIRC.
I'm sure I have a photo of the master model around somewhere.
PostPosted: Thu Oct 21, 2010 2:03 pm
Found it.
PostPosted: Thu Oct 21, 2010 2:22 pm
OK. change that to "would not go into production for the release."
