Leman Russ Punisher
 Post subject: Leman Russ Punisher
PostPosted: Thu Aug 06, 2009 9:30 pm
I´m not a WH40k player, but I have just read about the Leman Russ Punisher :mad: , armed with some kind of Gatling cannon. Any thoughts about its stats in Epic??
Epic Armageddon in Spanish: http://www.box.net/shared/aii6v2xqu3
PostPosted: Thu Aug 06, 2009 9:48 pm
Isn't that supposed to be equivalent to half of a vulcan mega bolter? I'd used that as a starting point - either half the number of shots or the same number of shots with a to-hit value knocked down a pip.
PostPosted: Thu Aug 06, 2009 9:59 pm
Dunno. Wasn't it one hell of infantry killer but virtually useless against anything but lightest vechiles(LV)?
Unless memory fails utterly it was heavy 24 S5 AP? weapon. So maybe 2-3xAP5+ with FF3+?
www.tneva.net
PostPosted: Thu Aug 06, 2009 10:29 pm
It is Heavy 20, with Strength 5 (same strength as a Heavy Bolter), and no armour penetration.
A pure stat crunching would end up with something like 6x AP5+, 30cm, but that's a little silly, so 3x AP4+, 30cm range?
PostPosted: Fri Aug 07, 2009 12:04 am
I was thinking about making one in Epic scale ... but probably not ... :))
PostPosted: Fri Aug 07, 2009 12:11 am
When I begin on my next modeling project (Leman Russ tank with greater detail than FW's current Russes) I will do the main 3, but may also do a punisher.
PostPosted: Fri Aug 07, 2009 12:17 am
Well that settles that !  :vD  DKoK like the other 3 ?
PostPosted: Fri Aug 07, 2009 12:25 am
You might find this posting helpful:
http://www.tacticalwargames.net/forums....;st=15#
PostPosted: Fri Aug 07, 2009 12:39 am
Yep just a different turret
PostPosted: Fri Aug 07, 2009 5:23 am
U R da Mann !!!!  8v)  :agree:
Users browsing this forum: No registered users and 97 guests
