Tanith List - PDF
 Post subject: Tanith List - PDF
PostPosted: Thu Apr 03, 2008 11:29 pm
This is the updated version - it's just got some corrections from the previous one.
E&C - I'll correct all the guns for the next version, hoping to remove that special rule if possible.
Tanith First and OnlyV1.1a.pdf
"Stars in my pocket like grains of sand."
www.spartangames.co.uk
PostPosted: Thu Apr 03, 2008 11:44 pm
Some quick thoughts :
- Single Hydras can be bought as allies as independent formations? I suspect that's a mistake, unless it's intentional that the Tanith can take 20 individual Hydras for 1000pts and popcorn the enemy to death with a thousand small cuts. :D
- Tanith Heavies have Autocannons (45cm range) but the 'Tanith' Special Rule means that they can only have a maximum of 30cm range on their guns... why not change their gun to being the Multilaser, which has a range of 30cm and AP5+ / AT6+ (IE: Stats are the same, but the special rule is then not required).
- Tanith Commander is missing the Anti-Tank value from its Treadfether.
- Tanith Infantry, as with Heavies their Autocannon (Which currently lacks a range stat) could be renamed to Multi-Laser, thereby avoiding the nessesity of having a special rule.
- Scout Heavy Stubber lacks '30cm range' on the profile.
Overall I'm looking forwards to facing it again.
PostPosted: Fri Apr 04, 2008 10:44 am
Thanks for the points, I'll change them asap, the single Hydra option is indeed a mistake, it's a hanger-on from a previous unit, it's an upgrade, comes under the Pardus upgrade rules.
Users browsing this forum: No registered users and 91 guests
