Post new topic Reply to topic  [ 94 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
Elysian Aircraft
 Post subject: Elysian Aircraft
PostPosted: Wed Feb 11, 2009 12:02 pm
Quote: (Lion in the Stars @ 10 Feb. 2009, 21:58 )
Why did the Lightning Interceptor lose it's AP5+ and AT6+ attacks from the autocannon?  To differentiate it from the TBolt (ie, make it less effective as a ground-attack plane)?
Wingtip Lascannons should probably be AT5+/AA5+ (Marauder twin lascannons are 45cm AT4+/AA4+, but that's too much for a fighter)
1) Lightning Autocannon:- Yes. Granting the Interceptor a second weapon with ground attack capabilities made the Interceptor too generalist thus rendering the Strike variant redundant. It also made the '4' ship formation overpowered.
2) Point well made on the Lascannons. I suspect this was a typo as we have always been advocating AT5+/AA5+ for the 'common' weapon in use on both Lightning variants. We just got a little hung up on the name. :laugh:
PostPosted: Fri May 29, 2009 12:41 am
I've hit page three of the thread and may as well chime in with my stats. I did a load of testing of Destroyers and lightnings way back when (maybe 2 years ago now - edit a quick search reveals I started testing them back in 2005) with some more done maybe a year ago, maybe a bit more. I was okay with the Destroyer, 80% happy with the Lightning, ambivalent on the strike after a bunch of games supporting mechanised Guard.
The Lightning I was/am set on a 'Lightning Autocannon' 45cm AP5+/AT6+/AA6+ gun. It deliberately breaks the 30cm barrier and I think thats fair because the beast is built around it. I then cheated with the lascannon, listing them as 'Twin Wingtip lascannons' giving a straight 30cm AT5+/AA5+. The plane was a fighter with no save (it has to jink!). Though I occasionally changed my mind and made it save 6+. Either one shows the effect of manoeuvrability in Epic Air.
The 45cm problems have related specifically to three craft in Epic, the proposed Siam Hain beast, the TK A-10 attack and the Chaos AA4+ 45cm attack (which was its only AA attack).
Attack wise a single stand off 6+ (modded to 5+ on intercept) isn't that hot. Low risk but not in the same leage as the above. It is somewhat similar to the Tau guided missiles bm chaff but here the formation are more expensive by far making it a less than optimum usage, still its something to bear in mind.
The comparison is to a thunderbolt. It should be better at intercepts and worse at ground attack.
Intercepts
Lightning
45cm 5+
30cm 4+
Thunderbolt
6+ Save
30cm 4+
15cm 4+
Clearly the lightning has the edge. Against the things you want to kill you can attack at full force, whereas the poor old thunderbolt has to typically only use one attack. Against things like fighters the thunderbolt does get to go full force - but still has to get close which brings up the synergy with defensive ground flak providing a protective umbrella for friendly craft the lightning can potentially avoid (again here in the game its raw range but in my head its due to doing a wickedly fast intercept). The save isn't really worth much.
Ground Attack
Lightning
Fighter
45cm AP5+/AT6+
30cm AT5+
Thunderbolt
Fighter Bomber
6+ Save
30cm AP5+/AT6+
30cm AT4+
15cm AP4+
A trickier beast. The thunderbolt has the raw firepower but has to close to do it (never actually a problem for me - the stuff a thunderbolt can get is typically isolated by the time they attack). Ironically the fighter bomber rule makes it harder for the Tbolt to manoeuvre during the attack run.
To me its equal, but thats on my expected usage, others reckoned the lightning was 10-15 points ahead in a 2 man squadron.
For these chaps I favour a 3-4 plane squadron. 3-4 for two reasons. One they used to be sold in packs of 3 :) Two a 4th plane isn't 33% increase in effectiveness over two. Going with 250 for 3 +1 for 75 I think would be fair based on the old experiences (and could even be 225 for 3 +1 for 75 - it all comes down to do you compare against the optimum use of both planes?).
I tied myself in knots trying to balance it against the strike on the same points, though eventually I think I gave up.
I tried range 45cm missiles, but to no avail. Here it is the planes main attack so you can shoot up armoured columns and never get worried by flak. Making it 30cm at least gets some risk back into the equation!
Cutting the development chat this time I eventually hoped for the following to balance with the interceptor. Ultimately I don't think it did, but I think it was close. Of course in a list with very poor AA the lightning is a better bet.
Fighter-bomber
Twin wingtip lascannon 30cm, AT5+/AA5+
Missiles, 30cm, 3xAT5+
Why 3x5+ not 2x4+? Well here this is me modeling the use of typhoons and similar. You didn't hunt targets in cover, but rather stuff on the move (of course having the added effect of making everyone quite timid on the march). In Epic 2x4+ gets 1 hit or 2/3's on something in cover. But 3x5+ gets 1 hit or 1/2 on targets in cover. An important distinction for me and reinforcing its use.
In fact as my hard drive recovery tools slowly dredge up more files from the 3 backups that all bloody failed in the same week (laugh? actually I fell to the floor sobbing) I note I later went for 6xAT6+.
I think this does perhaps make it even adn the one bat rep it was tried in seems to suggest it is, to the extent I've got a note about trying mixed squadrons.
The Destroyer was for me fairly straight forward I tested the following with many other players in several different lists over the years. They have played against ever book list in support of everything from the AMTL to Siegers. Based on the forgeworld model
Marauder Destroyer (Armageddon pattern)
War Engine
Bomber
Armour 6+
3 x Twin Autocannon, 45cm, AP4+/AT5+/AA6+, Fixed Forward Arc
8 x Missiles, 30cm, AT6+, Fixed Forward Arc
Bombs, 15cm, 1BP, Fixed Forward Arc
Twin Assault Cannon, 30cm, AP4+/AT4+/AA4+, Fixed Rear Arc
Twin Heavy Bolter, 15cm, AA5+, 360 degree Arc
Notes: DC2. Critical hit effect, the bombers control surfaces are damaged causing the craft to crash and be destroyed.
Points - 350 for 2.
It is totally balanced design (or at least that's what everyone who played it thought), though points are always subjective and the designs wysiwyg. Though not with mine. As I lost the missiles.
I'm not sure what you are after with the colusus. Historically I thought the FW idea worked on two concepts. the first is the WWII super 'earthquake' bomb. Used to take out bridges, buried bunkers etc. Worked on the principle that shockwaves continue to travel and was devastatingly effective against many different targets (and was a British design). The second is the MOAB a big air burst munition. The first would be in Epic terms a IC MW combo (eek), or maybe just IC, most likely 3bp. The second could fit your concept or using an orbital barrage template. Here though I diverge on grounds of playability. A one shot weapon is interesting but hard to balance when some armies/players kill enemy flak easily and others struggle. You would have to cost it for its optimum use m=which makes it very pricy indeed. If something like 3bp IC is not enough for such a bomb (and why not considering its one big bang rather than lots of small ones, different effects but similar enough for epic surely which goes in for tonnage rather than special effects with bombs) and you have to use the orbital template make it 1BP. If thats not enough make it IC. Pretend its a fuel air explosive maybe. This way a two plane squadron makes gaming sense, you have a reason to bring it back turn two and the effects are horrific but survivable. Other options are availible but I assume you want a two plane squadron which limits things a bit.
Out of interest I haven't recovered my FW books yet, what is its description in there? The asset killer or the big explosion?
Anyway back to the thread, onwards to page 4 :)
PostPosted: Fri May 29, 2009 12:46 am
The summery of the above is
Lightning
Fighter
Long Barreled Autocannon, 45cm, AP5+/AT6+/AA6+
Twin Wingtip Lascannon, 30cm, AT5+/AA5+
Lightning Strike (the conservative option, really read the above its quite good)
Fighter Bomber
6 x Missiles, 30cm, AT6+
Lightnings
225/250 for 3, +1 for 75 points
War Engine
Bomber
Armour 6+
Points - 350 for 2.
PostPosted: Fri May 29, 2009 1:10 am
Wow I'm finding even more notes from 2005, who would have know I was so keen on minutes back then. If anyone wants to see all this stuff its a bit ragged from the recovery process (the embed pics didn't survive) but you can read several dozen pages of musings from the last 4 years if you like :)
So yes finished the thread. I think you have ended up with planes that with one major exception match mine to a surprising extent, and without 4 years of playing with them and innumerable games :)
The Lightning is very much overpointed (or under armed depending on your point of view). Its quite similar to the 1st edition of the pdf planes I tried out a while back actually. I understand the sentiments, however there is no reason I would ever take them bar running out of strike variants in my collection.
The strike is eerily similar to what I settled on after much testing, trail and many errors. With its anti cover ability with a base 4+ to hit if it isn't 200 its 175 points for two. Personally for the reasons I went into above I prefer the 6AT6+ shots - same overall hits but crap against bunkered armour.
The Destroyer is something that I would avoid. First because I don't have a model of it (I've only got the forgeworld ones) and second because its too many points on a dodgy airframe because the dodgy armour means no daring attacks and what I could therefore jump its over gunned for. Funnily enough I think its the only plane in Epic where a head on intercept makes sense. Stats wise you again ended up pretty close to mine, only I kept the internal bomb bay (as it apparently has one), with the obvious exception of the WE stats (2dc 6+ save is far more reliable than a straight 4+ and allows easier pointing) and again you favour the anti cover 2AT3+ as opposed to 8AT6+.
