Post new topic Reply to topic  [ 180 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 12  Next
True Steel Legion
 Post subject: True Steel Legion
PostPosted: Thu Jun 05, 2008 12:14 am
Ok Lightnings will be in the next update :)
Commends on the other changes?
PostPosted: Thu Jun 05, 2008 2:49 am
Will give more detailed comments in a bit, until then how about the
Chimera APDS-6a ?Defender? (Armageddon pattern)
Type                  Speed Armour Close Combat Firefight
Armoured Vehicle 25cm 5+             6+                6+
Weapon          Range Firepower Notes
Laser Destroyer 75cm AT4+ Titan-Killer (1)
PostPosted: Thu Jun 05, 2008 8:39 am
Why did you make it slower than a normal Chimera, when you think a Laser Destroyer Leman Russ should be faster than a normal Leman Russ?
PostPosted: Thu Jun 05, 2008 9:51 am
Because a LR loses a turret and all the equipment and mountings that come with that whereas the chimera loses inf and gain a huge weapon system taking up most of the hull?  ie LR loses net mass, chimera gains?
-Spider Jerusalem
PostPosted: Thu Jun 05, 2008 9:57 am
Even so, I don't see a Leman Russ-mounted Laser Destroyer shifting as quick as a Chimera-mounted one, but then again I've always disagreed with Chris' 25cm speed proposal for the Russ Destroyer... I can't see any tanker wanting to move that vehicle fast over uneven ground, for fear that he'd stick the over-long barrel into the dirt!
PostPosted: Thu Jun 05, 2008 10:01 am
Fairy snuff :)
-Spider Jerusalem
PostPosted: Thu Jun 05, 2008 10:54 am
According to Imperial Armour:
Off-Road Speed
Leman Russ: 21 km/h
Demolisher 17 km/h
Chimera 55 km/h
Destroyer 36 km/h
Thunderer 22 km/h
So
Chimera Defender (Armageddon pattern)
Armoured Vehicle  30cm       5+             6+               6+
PostPosted: Thu Jun 05, 2008 1:11 pm
(Evil and Chaos @ Jun. 05 2008,09:57)
Oh really? :)
http://en.wikipedia.org/wiki/M18_Hellcat
Tank destroyers go hell for leather due to lower armour and enemy tanks being out to get them.
The LR TD is also more than 50% faster than a Leman Russ according to FW. Furhter 30kph is not unreasonable cross country. And TD concepts are shoot and scoot - a lot more time moving than conventional tanks with firing over a shorter period of time.
Chimera wise I would have thought the loss of power was due to the gun needing more from its generators.
Wondering how to make an Armageddon pattern one personally.
I would prefer something like this
PostPosted: Thu Jun 05, 2008 1:12 pm
Reckon thats doable from a salamander maybe.
Anyone got any ideas how the damn thing could look and how to build it?
Another idea is a FW arty chimera hull with a built up compartment and rear facing gun.
PostPosted: Thu Jun 05, 2008 1:15 pm
Or a SG arm. basilisk with a change to its superstructure.
PostPosted: Thu Jun 05, 2008 1:16 pm
On an entirely unrelated note, I'd love an Epic one of these :) Ontos
PostPosted: Thu Jun 05, 2008 2:59 pm
CHris- that first one's an Archer isnt it?  I was going to mention that would be a really cool version for armageddon and would support a fast speed.  Could be easy to build on a FW salamander chassis
Ive also made an epic chimera conversion that looks quite similar to a Marder- ill post that up if you like
-Spider Jerusalem
PostPosted: Thu Jun 05, 2008 5:39 pm
That would be great! And yes its an Archer - the famous rear facing gun for a quick gettaway! The second is teh Marder 2. I personally prefer teh look of the stug but don't know what to use as a base.
That Ontos is an interesting beast, 6 recoiless rifles topping off an atrocious design (too high, has to be reloaded externally etc) - so bad it should be in the Imperial Guard!
PostPosted: Fri Jun 06, 2008 12:31 am
For the Defender i would go for:
a) A turretless Chimera. Replacing the Heavy Bolter with the Laser Destroyer.
b) A Salamander Scout/Command replacing the Heavy Flamer/Autocannon with the Tank Destroyer.
And because it is Armageddon Pattern it has to have an enclosed cabine.
PostPosted: Fri Jun 06, 2008 1:51 am
Option a I tired and failed miserably with. Option b is open topped... The bassie may be a better choice for that.
Users browsing this forum: No registered users and 70 guests
cron
