Post new topic Reply to topic  [ 146 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 10  Next
Elysian List
 Post subject: Elysian List
PostPosted: Wed Sep 30, 2009 10:14 pm
Quote: (Moscovian @ Sep. 30 2009, 21:46 )
Come to think of it, the Griffon is a heavy mortar and at 1BP and not indirect.  Bombards are 2BP siege mortars and not indirect.  Perhaps the light Mortar units need a revamping to bring them below the Griffon (that thing is a big mortar piece on top of the vehicle).
They both have indirect fire.
PostPosted: Wed Sep 30, 2009 10:30 pm
Quote: (Chroma @ Sep. 30 2009, 21:06 )
Quote: (The_Real_Chris @ Sep. 30 2009, 20:59 )
120mm mortars
Are 120s really considered "light" mortars?
To me, they seem more like the "heavy mortar" referenced above, usually moved by a light transport, not man-handled easily (10cm move).
Yes you are right since those things weigh something like 150kg (well, I'm sure L4 used to carry two in his pockets)
If you are carrying it I suspect infantry understandably prefer 60mm mortars :) Could have a 15cm move like everyone else then to. Would fight with a 30cm/XxAP5+/Indirect profile then. Downside is your mortar models would be very fine tubing, what 1mm diameter? :)
I used a 120 as it was the easiest to make to scale with the infantry and this was for sieger troops who didn't expect to move much anyway!
Incidentally here is an US airborn regiment 120 in operation.
PostPosted: Wed Sep 30, 2009 11:37 pm
Note the vehicle, probaby its transport, in the background.  :)
All modeling aside, we should consider these mortar something on the order of a 81mm or so.
Oh, and Moscovian it occurred to me why FW won't (you heard it hear first) model a man portable AA figure.
Scenario:
Joe Modeler flies his brand new $350 USD Marauder Destroyer onto the table to attack the Imperial Guard artillery position. Jerry Skinflint mentions that he is firing his brand new FW portable squad $30 USD SAM team and shoots down Joe's Marauder.
Joe's not happy. Projected 12 month sales for the Marauder suddenly vanish.
Realistically, GW does not want the "true" level of technology to rise above WWII. That way, planes can fly on the board, bomb stuff, deal with AA tanks and the models mechanism stays relatively clean. If you try to add a little more "realism" to the model, all sorts of things start to break.
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Wed Sep 30, 2009 11:40 pm
That's all part of the fun of the 40k setting IMHO, that it is so ridiculously anachronistic.
PostPosted: Wed Sep 30, 2009 11:49 pm
Agree wholeheartedly, but I think that's why we see laser beams locked in with diesel engines. True modern combat tends to be extremely difficult to model well.
Honda
PostPosted: Wed Sep 30, 2009 11:52 pm
I'm not sure the difficulty is in modelling it *well*, but making it *fun* to play... since true modern combat is *NOT* fun in reality.   :heart-break:
PostPosted: Thu Oct 01, 2009 12:58 am
For Mortars:
The Mortar used by the Imperial Guard is:
Range 48", Strength 4 , Armourpiercing 6 , Heavy 1, 3"Blast, Barrage
The Heavy Mortar used by the Griffon is:
Range 12"-48", Strength 6 , Armourpiercing 4 , Ordnance 1, 5"Blast, Barrage
and CAN'T fire direct.
The Heavy Mortar of the Death Korps is the same as the Griffons Heavy Mortar but has a selection of different shells (the Griffon Heavy Mortar too but only with IA 3 rules).
The Quad-Launcher of the Death Korps is:
Range 12"-60", Strength 5 , Armourpiercing 5 , Heavy 4, 3"Blast, Barrage with -1 on Pinning tests.
For comparison a Missile Launchers Frag-Missile is:
And its Krak-Missile:
Range 48", Strength 8 , Armourpiercing 3 , Heavy 1
Note that in WH40k all Barrage weapons cause a Pinning test and that not all Barrage weapons have a minimum range.
BTW: I can't find a Mortar or any other Fire Support Squad entry in the Elysians list found in IA3.
EDIT: Ok found them. But they come only with the Company Command Squad and at a very low number.
IF we would finally drop the strange habit to call those Platoon sized formations Companies and call them Platoons as is proper the Fire Support units would be a part with the Command Platoon formation.
That would be:
1 Supreme Commander unit, 2 Fire Support unit each with 2 x Heavy Bolter shots, 1 Anti-Tank unit with 2 x Lascannon shota, 1 Mortar Squad with 2 x Mortar shots and 2 Special Weapons units with no shooting attack but enhanced FF (or Sniper Rifles).
PostPosted: Thu Oct 01, 2009 3:18 pm
I have it! Just came to me.
60mil mortar, 30cm, AP5+, No line of fire needed.
So short ranged cheap firesupport. Or were we after something heavier and longer ranged? :)
PostPosted: Thu Oct 01, 2009 3:44 pm
That seems reasonable at first glance.  The loss in firepower will be mitigated by the 'no line of fire' exception, and when firing indirect it would be hitting on 4+.  Two of them means you'll most likely hit something.  And it also keeps the mortars from taking out tanks.
PostPosted: Thu Oct 01, 2009 3:53 pm
http://en.wikipedia.org/wiki/Blacker_Bombard
PostPosted: Thu Oct 01, 2009 4:18 pm
Then it appears your stats are in need of revision.  Perhaps an AP5+/AT6+ then?
PostPosted: Thu Oct 01, 2009 4:23 pm
God no, about as man portable as an enraged lion. Just showing in the wierd and wonderful world of weapons humans have tried most things :)
PostPosted: Thu Oct 01, 2009 4:52 pm
As cool as Wikipedia can be, I think you're just muddying the water with such links, T_R_C.
The ELysians are using "light" anti-infantry mortars, not specialized or heavy ones.
PostPosted: Thu Oct 01, 2009 10:52 pm
I like this idea. It fits the concept.
Honda
PostPosted: Fri Oct 02, 2009 12:43 am
As the Mortar has a 48" range it could easily have 45cm in Epic as 48" usually translates to 45cm (see Lascannon, Autocannon and Missle Launcher for example).
Apart form that. The "No line of fire needed" should be used by a majority of current Indirect Fire weapons. Because not all Wh40k weapons double their range or have a minimum range when firing indirect.
Users browsing this forum: No registered users and 91 guests
