Post new topic Reply to topic  [ 222 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15  Next
Elysian List Issues
 Post subject: Re: Elysian List Issues
PostPosted: Sun Sep 04, 2011 2:06 pm
The 40k rules for Tarantulas aren't that bad as Honda might suggest. The rules arethat what you would expect from an automated gun with limited intelligence.
Tarantulas have either a 90° arc of fire and a long range or a 360° arc of fire and a short range. AP-Tarantulas will only target infantry and AT-Tarantulas will only target vehicles.
PostPosted: Sun Sep 04, 2011 10:47 pm
From which, the implication is that you might get to choose what type of Tarantula unit you add to the formation on a unit-by-unit basis (like Predators). However I suspect that even so, a lack of mobility (10cm move??) will make them unwieldy to an attacking force, so only usefull as a point defence for garrison forces. Moreover, these seem rather similar to Tau Drones, and while I still have a strong hankering after those elusive but iconic units, perhaps their history should be a warning to the use of Tarantulas here? :)
Stepping back a little, I am still not sure we have fully articulated the "problems" with the current list have we?
  1. Mosc has suggested the Elysians suffer against lists that gain air-superiority.
  2. I have suggested the LV transports are more of a liability than an asset, in small numbers they are a target while in large numbers they reduce activation counts
  3. We all recognise that the list's minimal armour values encourages both high activations to reduce the impact of attrition and terrain hugging to almost fanatical extents.
  4. An implied concern many that the list does not behave as intended, while not being entirely clear/agreed just how it should actually work: how to make the list work in practice, and how close that reality is to the portrayal in the "Fluff".
  5. Etc
Perhaps if we could better articulate the problem and the constrtaints, then we might find more appropriate solutions - so for example, what is the recent debate about ground-based AA actually trying to address? Is it purely to reduce the impact of opposing air-superiotity or some wider reaching concern? And given Honda's constraint, how should this be addressed (if at all)?
Finally, what are the lists intended strengths (as opposed to their mechanics)? Again, it does not seem to be entirely clear what the Elysians should do well.
PostPosted: Sun Sep 04, 2011 10:58 pm
I revisited the AA unit in order to try to avoid a special rule of auto-CAP. Given Honda is not keen on AA units, the solution is to institute the auto-CAP that was suggested by multiple people and agreed upon by Honda.
The high activation is already addressed in the latest list.
As for the people who who have issued complaints about the list's playing style, most haven't even played with them. I think trying to rework the list based on a few theoryhammers is counter-productive.
PostPosted: Mon Sep 05, 2011 5:10 pm
Have people worked on play-testing the list as it currently stands? What sort of feedback do those people have? Is the lack of AA really losing Elysians games?
PostPosted: Tue Sep 06, 2011 1:47 pm
IMO it is losing 'some' games when your opponent brings more aircraft formations than you, thus the move to reduce the interceptor formation from 4 to 2. Not sure about the experience of others. How about you?
PostPosted: Tue Sep 06, 2011 2:04 pm
In games where CAPing CAP is allowed a 4 strong interceptor doesn't have much going for it, and certainly doesn't scream "air superiority". It's certainly more robust but that comes coupled with not having it around for a turn (something that could take out a 2 aircraft formation would reduce a 4 unit formation to half strength and give it 3 BMs, having it come in on a 5+ at least) as well as having all your eggs in one basket (leaving you to intercept/CAP only one enemy formation while the others get free reign due to the lack of your on table AA).
I think it's a change worth considering, but you also have to worry about activation creep.
PostPosted: Tue Sep 06, 2011 2:11 pm
Who are you calling a creep!?! :P
PostPosted: Tue Sep 06, 2011 2:21 pm
The Greatest of all Epic players, The Terminator of Tyranids, The Crusher of Chaos, The Eviscerator of Eldar, The Subjugator of Space Marines, The Invincible Vs. Imperial Guard, The Overlord over Orks, Vanquisher of all, Receiver of Stunning Victories over all (especially Dave), the Dread Archon, the Man who removes the 6-pip side from his dice just to make it fair, the Maha-Moscovian.
PostPosted: Tue Sep 06, 2011 2:36 pm
In that case, you can add creep to that title if you want. ;D
PostPosted: Tue Sep 06, 2011 2:51 pm
Won't CAP-on-CAP or not make a pretty big difference to the power of air fms? (In favor of ground attackers) Seems hard to test the list properly if the rule is played either way.
PostPosted: Tue Sep 06, 2011 2:54 pm
But, this would also make it impossible for him to roll a 1, since there would be no 6-side to land face down to show the obverse 1-side?
PostPosted: Tue Sep 06, 2011 2:58 pm
Yes, however it is just one piece to the puzzle. The big killer for Elysians are multiple fighter formations. If your opponent has more than one, you are at a major disadvantage since your only heavy support comes in the form of bombers. Multiple fighter formations PLUS CAP-on-CAP and you are pretty much hosed.
He's using a five-sided dice.
You've seen one of those, right? I thought everybody knew of those these days.
PostPosted: Tue Sep 06, 2011 3:01 pm
Prefer rolling spheres myself, that way you can legitimately shout balls when it all goes wrong.
/derailing
Users browsing this forum: No registered users and 62 guests
