Post new topic Reply to topic  [ 86 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
[Black Crusade] Cadian call to arms!
 Post subject: [Black Crusade] Cadian call to arms!
PostPosted: Tue Dec 09, 2008 5:43 pm
One will definately end up better tested than the other, that's inevitable.
Still, I just don't like the idea of having two lists for the same army in one book. It just feels wrong.
PostPosted: Tue Dec 09, 2008 5:51 pm
What feels "wrong" about it?  It's just that it's never been done.
The Cadian "Interior Guard" Regiments, that defend Cadia and surrounding systems from within fortresses and entrenchments have a radically different organizational/deployment structure than Cadian "Shock Troop" Regiments going on the offensive.
Yet, they are the "same" army.  My whole point in this exercise is to show that the "same" forces can be played in very different ways by the nature of an army list's structure... and both can be fun and playable, without the need for an "all-inclusive" list that contains all options.
PostPosted: Tue Dec 09, 2008 5:53 pm
That leaves *only* the Cadian list/lists to be tested... so, yeah, two lists should be fairly easy to test.  *laugh*
Especially considering there's no deadline.
Well, there is kind of a deadline.  Your deadline.  Bear in mind the only point of reference I have is my own, but the work that goes into this was fatiguing.  The reason I didn't hold off on releasing Raiders was because I just couldn't do it anymore.  I wanted it done and off my table.  If I knew there was another month or two to work on it I probably would have scrapped the whole thing (yes, really).  Chroma, you may be wired differently in which case my warning is unnecessary.
However, if I had to guess, these projects have a life of about a 12-14 months.  Past that and you'll have it start to unravel for a variety of reasons.
Once again I am not saying two lists is BAD, just that it is a lot of work and I would warn you against underestimating the amount of work YOU will have to do for a supplement of this scope.
PostPosted: Tue Dec 09, 2008 6:03 pm
Once again - I'm sure you're feeling picked on here - but do you need two lists? The question is, what is going to make these lists really unique?
As far as the Cadian Interior Guard are concerned, the things that make them really different is the high proportion of Kasrkin and a close connection with the Ordo Malleus. Turning them into a rapid-reaction Kasrkin strike force with Inquisitorial elements makes for a really unique list and that - to me - is pretty exciting.
You need to set out what makes the Cadian Shock Troops different from the Steel Legion (or the Siegemasters, either), different enough for a whole seperate list from your Kasrkin-heavy strike force. Steel Legion mark II with Kasrkin doesn't really float my boat - it's just another Guard list with a few options switched here and there.
Now, if you have two drastically different lists in mind (e.g. a true Cadian Shock Troops list and an Interior Guard with Inquisition) then that might work, but if you CAN turn them into one list that does both, then you can keep everybody happy and certainly playtest it MORE than you could possibly playtest two lists - and it makes for a more realistic project for yourself (you might regret it later if you don't!)
PostPosted: Tue Dec 09, 2008 6:29 pm
The way I see it, it's your baby Chroma.  If you want two lists, do two lists. People will have a preference for which list they will use but having more options never hurt anyone.
Honestly, is anyone going to not buy the book if it contains two Cadian lists?
PostPosted: Tue Dec 09, 2008 8:34 pm
Nah, I don't feel picked on... I've called it down on myself!  *laugh*
Okay, here's my reasoning for wanting two Cadian/Imperial Guard lists in the book:  During the 13th Black Crusade, the Imperium engaged in two very different styles of conflict: 1) Resisting the invasion of Chaos Marine forces and 2) putting down Chaos-spawned uprisings.  I see the two Cadian lists as mirroring the two Chaos lists that will also be in the book.
I envision the "Defense" list as elite, stalwart defenders, hunkered down in bunkers and fortresses, ringed with minefields and razorwire, running through trenches, using the deadly and reliable technology of the Imperium to thwart the Great Enemy.  A brutal hedgehog of well-equipped, brave men fighting to retain every metre of Imperial soil.
I conceive of the "Offense" list as elite mechanized infantry spearheading attacks against heretics and deviants, backed up by the power of Imperial armour and technology.  A "rapid response" Regiment that "shocks" its way through the enemy, crushing those who defy the rule of the Emperor beneath the treads of their tanks.
One is "static" while the other is "dynamic"... I currently don't see a way of combining the two that doesn't dilute them both into "generic multi-purpose Imperial Guard army".
As to the Inquisitorial presence, I'm intrigued by it, and have an "alternate" idea about how to include them, which I'll get to later.
PostPosted: Tue Dec 09, 2008 10:59 pm
I don't see how the 'offense' list is anything other than a very slightly tweaked Steel Legion army list.
The Cadians are mainly famous for their 'Shock Troop' regiments... as an infantry based Guard force / high tech siege list they'd have a unique place.
PostPosted: Tue Dec 09, 2008 11:42 pm
Couldn't the same thing be said about White Scars vs "normal" Marines?
The "offense" list is Mech Infantry based, pratically everything is mounted, it's designed to make blitzkrieg style attacks, with a variety of supporting options... there's a lot fewer Company choices, but their SR is one higher than the IG average.
That can occur too... *laugh*  People can focus on test the "Defence" list if they desire, it's no skin off my back to round up locals to test the other list if people aren't interested in doing that.
PostPosted: Wed Dec 10, 2008 12:59 am
I thought the defining cadian military facet was infantry - what would have been called line infantry or maybe medium infantry (certainly aren't heavy).
The challenge is to make armies that are infantry centric and work.
For the defense its easy, infantry are great defenders, slap in a few bunkers and emplacements (no treches I would say) and give them decent hardware and you are away. I wonder though as to the simularities witht he deatgh korps.
Offensively its far harder. Orks get away with it with mono use infantry through the initiative system. The temptation would be to rely on special forces karskin for the offense, or allied formation of armour. That would be a great shame as essentially thats the current guard list. If you could come up with an army that had offensive dismounted regular guard infantry at its core, supported of course by a variety of superior high tech stuff, that would be fantastic.
PostPosted: Wed Dec 10, 2008 1:08 am
No, the White Scars are quite different organisationally to the Codex Marine army list.
Whilst at the same time, I don't really see many opportunities for differences between an Armageddon Steel Legion Mechanised infantry army list and a Cadian Mechanised infantry army list.
I believe that upping the Strategy Rating of a Guard army in this way without conceeding something big (Like the Elysians for example, who conceed the ability to take all tanks and Titans!) might not be the best way to start out with an army list.
I'll be focusing my playtesting on the infantry focused list... and remembering the cool story about the Cadian 8th Regiment charging as a huge wave of bodies from the IG codex.
That's what the Cadian Shock Troops are to me... foot infantry at their core, with tanks and mech formations in reserve.
Stray from that, and I think you may muddy the waters unnessesarily, perhaps even gratuitously.
I just can't see a justification for including a variant mech infantry list, unless it is intended as a stealth 'fix' for the Steel Legion mech infantry list.
PostPosted: Wed Dec 10, 2008 1:11 am
Indeed, the 'typical' Cadian army is one of infantry, both regular and conscripted.
I agree.
PostPosted: Wed Dec 10, 2008 1:19 am
I too am confused. The Iconic feature of Cadian warfare is offensive hordes of infantry, yet neither of the two lists are going to reflect this?
PostPosted: Wed Dec 10, 2008 1:44 am
Seems so.
If i would do a Cadian list i would use the Steel Legion list.
- Then i wouldn move Storm Troopers to Core Formations and up the number to Company level.
- Then the HQ would loose it's Chimeras but would gain the option to take a Leviathan/Capitol Imperialis.
- Then the Mechanised Company would be reduced to Platoon size and moved to the Support Formation.
- As new Upgrade i would add 4 Stormtroopers (= Kasrkin).
- I would add an Sanctioned Psyker (15cm MW attack also usabele in FF) to all Supreme Command and Command units.
- Perhabs Rough Riders and Ogryns would be gone.
- I would add a Conscripts Platoon as Support Formation (same size as Infantry Company, but no ranged weapons and Initiative 3+)
There it is. An Infantry Horde style Imperial Guard army with some elite elements.
PostPosted: Wed Dec 10, 2008 1:53 am
Quote: (BlackLegion @ 10 Dec. 2008, 00:44 )
Seems so.
Other than the Leviathan/Capitol Imperialis option, that's almost exactly what's in the Cadian Defense List I've put together.  It also gives them the option to take "Fortified Positions" if they desire.  The "Defense" list allows for "hordes" of assault infantry, if desired.
In all the reference I've looked at, Cadia uses both "Foot" Regiments and Mechanized Infantry Regiments... this is from references Codex: Eye of Terror, Codex: Imperial Guard, Imperial Armour I, and Imperial Armour 3: The Taros Campaign.
What other references can I draw on?
PostPosted: Wed Dec 10, 2008 1:56 am
Then stick to the "Defence" list. Really. Allowing Mechanised Companies in great numbers and you have the Steel Legion army list just with more Stormtroopers.
Look at the entry for Cadian Shock Troops in Codex Imperial Guard. You will notice that they don't have the "Mechanised" Regimental Doctrine. Only the Steel Legion has it.
Users browsing this forum: Google [Bot] and 13 guests
