Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Core IG Month regiment - Elysian Drop Troopers
 Post subject: Core IG Month regiment - Elysian Drop Troopers
PostPosted: Mon Jun 09, 2008 8:38 pm
*snaps the loop with a scissor* Aaaah much better :D
Yes it's the same weapon with the same strange stats :D Which would make the Rocket Pod Sentinel a very...strange unit's choice in Epic.
Go there, shoot, run to elswhere and then act as speedbump for the rest of the battle:D
PostPosted: Mon Jun 09, 2008 8:40 pm
In 40k the support sentinel's main use is as a communications beacon to help the drop troopers land at the right time/place. This isn't really representable in Epic without a clutered special rule.
PostPosted: Tue Jun 10, 2008 4:48 pm
There was an IG lander at steel legion testing stage, but it was dropped. Now it can be resurected!
Oh and no way little sentinel units get to be one shot - too much book keeping!!!
PostPosted: Tue Jun 10, 2008 5:56 pm
Where there ever stats published for the Imperial Guard Lander?
Fix for the Sentinel would be easy:
Valkyrie has Rocket Pod which is one-shot
Sentinel has Multiple Rocked Pod which can fire every turn.
PostPosted: Tue Jun 10, 2008 6:42 pm
From a long long time ago, probably in a galaxy far away?
COLOSSUS (Armageddon Pattern)
<<< The Colossus is a large Imperial Guard orbital lander, designed to land Imperial Guard troops on hot landing zones. It is well armoured, but although similar in size to the Capitol Imperialis the need to minimise its weight means it is not nearly as sturdily built. >>>
Type Speed Armour Close Combat Firefight
War Engine Aircraft (bomber) 6+ 6+ 5+
Weapons: 4 x Twin Lascannon Turrets, 4 x Twin Multilaser Turrets
Weapon Range Firepower
Twin Lascannon 45cm AT4+
Twin Multilaser 30cm AP4+/AT5+/AA6+
Notes: Damage Capacity 4. Transport (may carry up to twenty of the following units: Imperial Guard units: Supreme Commander, Commander, Infantry, Storm Troopers, Fire Support, Snipers, Ogryns, Sentinels; plus up to three of the following units: Leman Russ, Vanquisher, Demolisher, Griffon, Hellhound). Reinforced Armour. Thick rear armour. Fearless.
Critical Damage: Power conduits damaged, only six turrets may be fired from now on (attackers choice as to which) . Further critical hits cause an extra point of damage instead.
PostPosted: Tue Jun 10, 2008 6:50 pm
The critical hit results looks a bit of a nonsense.
Personally, I'm not sure if the Elysian list needs it ; Elysians don't hotdrop from space directly into combat, they establish a base on the planet and then fly to the target zone in Valkyries, where they then hot drop.
Notably, the lander's vehicle transport capacity would be wasted as Elysians don't use anything heavier than a Sentinel (No Chimeras, not Russes, no tanks of any kind).
PostPosted: Tue Jun 10, 2008 7:36 pm
Armageddon Pattern too? Hmmmmm. Doesn't really for with my Steel Legion PDF.
And 6+RA....well at least the critical is very forgiving.
Else: If this thing could transport Valkyries then the Elysians would use it :)
What about:
COLOSSUS (Elysia Pattern)
<<< The Colossus is a large Imperial Guard orbital lander, designed to land Elysian Valkyries on hot landing zones. It is well armoured, but although similar in size to the Capitol Imperialis the need to minimise its weight means it is not nearly as sturdily built. >>>
Notes: Damage Capacity 4. Reinforced Armour. Fearless.
Transport (may carry up to thirteen of the following units: Imperial Guard units: Elysian Supreme Commander, Elysian Commander, Elysian Drop Troope Infantry, Elysian Storm Troopers, Elysian Support, Elysian Mortar, Elysian Hardened Veteran, Elysian Drop Sentinels, Elysian Support Sentinels; plus up to seven of the following units: Valkyrie).
Drop Sentinels are threated as with Jump Packs equipped if they disembark.
Critical Damage: Structural integrity damaged. The Lander suffers a further point of damage.
PostPosted: Sun Jul 13, 2008 7:22 pm
In dark Apostle the Elysian use some heavy landers which deploy vultures on the way down.
Tyranid air marshal
