Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
Change to warhound points needed?
 Post subject: Change to warhound points needed?
PostPosted: Thu May 29, 2008 1:53 pm
Ok, while I accept the principle that a given formation may have different stats in different armies because of its relative 'usefullness', just how do you balance that objectively??
Furthermore, the Warhound also provides a further dilema through the Chaos varients - - - -
Anyhow, given its place in the "spacecraft" section of the lists, and the relative cheapness of the IG formations, I would suggest in this case that the +25 points is warranted for both IG and SM:-
- SM because (to quote Hymirl's excellent summary), we want to discourage a Titan variant list with SM cheerleaders.
- IG for similar reasons, and also because they have plenty of alternatives.
PostPosted: Thu May 29, 2008 4:58 pm
I'm sort of new to epic and all, just learning everything and getting familiar with the rules, but this seems a bit off IMO. It seems a very bad reason to increase cost just because there are plenty of alternatives and I think a simpler solution to the marine cheerleader option discussed would perhaps adjust them to say maybe only a quarter of the total army points could be used on Navy and Titan support. Would have the effect of limiting them to 3 warhounds in a 3k point game.
-Vaaish
PostPosted: Thu May 29, 2008 5:31 pm
Interesting idea, but it would mean that marines couldn't take a Warlord at 3k, so is probably too retrictive.
The one time I've taken a Warlord with my marines at 3k it did awfully, but it's nice to have the option.
PostPosted: Thu May 29, 2008 9:54 pm
A completely off-the-wall suggestion sparked by Vaaish's suggestion might be a further restriction of 0-2 Titans within the spacecraft section, or perhaps amaximum 1 titan of any description per 1000 points ???
PostPosted: Fri May 30, 2008 6:19 pm
We could take the Titan Legion Battlegroups section in the ImperialGuard/Marine army list's which says 1 or 2 warhounds for 250 points each to literally mean that.1 battlegroup of either 1 or 2 warhounds and no more.
PostPosted: Fri May 30, 2008 7:15 pm
dptdexys : Again, non-scaling limits are bad. 1-2 warhounds max might be fine for a 3000 point game, but what about a 10000 point game?
PostPosted: Fri May 30, 2008 7:22 pm
Take 3 seperate armies 4k,3k and 3k and don't forget all limits in the tourney lists are per 5000 points.
PostPosted: Fri May 30, 2008 7:24 pm
Why on earth should you be forced to do that?
In that case, in a 3000 point game I'll take 2 1500 point armies and have 4 warhounds anyway...
The idea doesn't work.
PostPosted: Fri May 30, 2008 7:31 pm
If you are playing a 10k battle it would not be at a tourney .If you and your opponent s cannot come to an agreement to allow leeway on things like this then maybe you shouldn't be gaming together.
The Idea I put forward wasn't serious ,maybe I should have added a smillie.
