Leionary Glaive SHT stats?
 Post subject: Leionary Glaive SHT stats?
PostPosted: Tue Jul 09, 2013 8:02 pm
Feedback and suggestions for stating a Glaive would be appreciated. Something along the lines of this comes to mind
Legion Glaive Superheavy Tank WE 20cm 4+ 5+ 4+
Volkite Carronade 45cm 2xMW3+, Disrupt
2x Quad Lascannons 45cm 2x AT4+
Twin-Linked Heavy Bolter 30cm AP4+, Fwd
DC3, Reinforced Armour. Critical Hit Effect: Destroyed. Units within 5cm of the model suffer a hit on a 6+.
 Post subject: Re: Leionary Glaive SHT stats?
PostPosted: Wed Jul 10, 2013 2:55 pm
Need 40k stats for ideas.
PostPosted: Wed Jul 10, 2013 4:26 pm
They're available on the FW site.
http://www.forgeworld.co.uk/New_Stuff/LEGION_GLAIVE.html
PostPosted: Thu Jul 11, 2013 2:50 pm
I have no clue what Deflagrate and Haywire does.
Stats for a Quad Lascannon is the same as on the Rapier?
PostPosted: Thu Jul 11, 2013 3:20 pm
Deflagrate causes an extra hit for every wound caused and Haywire is especially useful for vehicles and involves a special chart to use. Basically if you penetrate bad bad things happen. Seemed a fair choice to model those as MW ability and contributing to Disrupt when you add in the Beam effects. The Beam ability of the cannon being able to blast units and keep hitting the next poor schmuck in line is probably best to be considered a 2x attack on the weapon. An imperfect abstraction but one that seems to be statistically equivalent.
IIRC the quad Las cannon discussion with the Spartan settled on it being easiest to be 2 twin-linked Las cannons so I followed suit here.
PostPosted: Thu Jul 11, 2013 11:57 pm
Then the stats look ok to me .)
PostPosted: Fri Jul 12, 2013 12:01 am
Well it's not a stat unless BL blesses it! ;)
thanks, brother and I've added this to my running list of Experimental Formations document for posterity. :D
Users browsing this forum: Google [Bot] and 47 guests
