Drop Pods
 Post subject: Drop Pods
PostPosted: Sun Jan 03, 2010 11:34 pm
What are the rules for Drop Pods?  For some reason I couldn't find the stuff below in the Specialist Games free rules.  Maybe my search fu is no good.
1. How do you determine where they land?
2. What happens once they land? (Do they have any offensive weapons)
3. What happens with them on the subsequent turns?
4. What units can be deployed and how many?
If there is a PDF that has this info in it that would be nice as well.
PostPosted: Mon Jan 04, 2010 12:02 am
The rules for plotting are in Section 4 in the air rules.
What can be dropped is covered in the Space Marine transport rule.
PostPosted: Mon Jan 04, 2010 12:04 am
Drop Pods use the Planetfall special rule (see 4.4 in E:A) to enter play. Note that this means they cannot enter play unless you purchase a Spacecraft.
WHen they enter play, they fire their Deathwind at ALL enemy units w/in 15 cm. BMs apply as normal. Troops carried must them disembark in coherency of either the DP or another unit in the formation.
Once landed they are an immobile vehicle.
PostPosted: Mon Jan 04, 2010 9:17 am
How many Deathwind shots do you get? Is it one pod per rhino swap? So a Tactical detachment would have three pod shots? The fact that its not a actual unit and just a marker thingy has always thrown me off.
My NetEA Lists:
Fir Iolarion Titan Clan List
Dark Angels List
Always looking to Trade!
Angel's Trade Thread
PostPosted: Mon Jan 04, 2010 9:19 am
1 shot at every unit in range
www.epic-uk.co.uk
PostPosted: Mon Jan 04, 2010 10:16 am
Quote: (Hena @ Jan. 04 2010, 08:25 )
You get as many shots as there are units within 15cm of the Pod.
Yup. I had a drop go perfectly, 3 formations all essentially surrounding a 'Uge Ork Mob. Ended up with something like 28 shots in total. Being in cover, it only shook out to 2 casualties. C'est la vie.
Morgan Vening
PostPosted: Mon Jan 04, 2010 12:43 pm
Quote: (Hena @ Jan. 04 2010, 07:58 )
Once landed they are removed. The Pod model is only a marker and not a unit itself.
So, why are they listed as Armoured Vehicle in the NetEA/SM Armylists Compendium ?
Being an Armoured Vehicle brings troubles :
- formation coherency
- cover to infantry
- objective contest
Drop Pod should only be a special rule and have no unit profile.
PostPosted: Mon Jan 04, 2010 12:51 pm
The normal answer is you may want to amend the rules for a scenario, so the stat's exist.
It's a topic that normally comes up at least once every 18 months or so  :laugh:
PostPosted: Mon Jan 04, 2010 1:51 pm
Quote: (Hena @ Jan. 04 2010, 12:51 )
The problem is that it needs some rules which are listed in the notes. However I admit that I wasn't thinking about it for that. Would removing the type and save help in this sense? I could poke Chroma to remove them.
Well removing  fully the Drop Pod entry, and add it under a Special Rule (like ATSKNF, or Transport) would be the best solution IMO.
But removing the type and the save would be a minimal solution.
IMO, the Drop Pod has an entry in the profiles list only because it has a miniature. And a profile was a great solution to bring a picture and some background about it, like all others units, just using the same layout ine the rulebook.
But it is only a game effect, not a unit.
PostPosted: Mon Jan 04, 2010 1:56 pm
It is the symptomatic proof that something is wrong about the Drop Pod rules.
PostPosted: Mon Jan 04, 2010 2:30 pm
In my opinion it's a simple mistake in the original rules that noone has the cajones to change.
PostPosted: Mon Jan 04, 2010 4:03 pm
They've been changed to a "Special" unit type in the latest (not yet posted) draft documents, with a note that they're removed once the drop is completed.
This will also be the case with Dreadclaws and Mycetic Spores in the Chaos and Tyranid armies.
cron
