Post new topic Reply to topic  [ 126 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
Apocrypha of Skaros 1.0e
 Post subject: Re: Apocrypha of Skaros 1.0c
PostPosted: Fri Jul 09, 2010 11:53 pm
You like what Epic was 15-20 years ago, I get that.
Actually, I like aspects of that, aspects of what it's like now, and aspects of what it was like a little before that, too. :P And aspects of what it was like ten years ago.
But for ten years, "Tarantula" has meant a static autonomous sentry turret.
Call 'em "Tracked Tarantulas", and everybody's happy again.
I'll likely just blather on about how inferior Tarantulas are often used for area security, but in a fluid battlefield role the older, more mobile type will be used, despite the difficulty of maintaining them. That do the trick?
I've noted before that looking at it by eye I think it looks overpowered.
I recall it indeed (I actually pondered it quite seriously). Since your initial comment, the list has lost single Warhounds and Air Assaulting (leaving aside the various wiggling surrounding the Artillery Pieces and their arrangements). That would seem to limit its options sufficiently to add some serious challenge back (at least IMO).
Disagree?
The Apocrypha of Skaros 1.1
Rogue Trader Expedition 0.4
The Horus Heresy 0.5
Night Lords 0.1
My Trade Thread
PostPosted: Sat Jul 10, 2010 12:17 am
Here are a few relevant quotes from Imperial Armour on the subject of Tarantulas:
"Many veterans refer to sentry guns as "Tarantulas"; the origins of this name are unknown.
Many Marine Chapters also keep a small supply of sentry weapons in their armoury, finding them especially useful for routine guard duties due to their relative lack of manpower.
Tarantulas are only deployed for static defence, their lack of mobility severely restricting their use during a fluid battle" - IA1, p104.
There are plenty more quotes I could pull from there that repeatedly hammer home the point: Tarantulas are static sentry guns.
You "blather on" about Tarantulas being the tools of a fluid combat force, and you're just making stuff up that bears no relation to the Warhammer 40,000 background setting.
At most, you could make them move 0cm, but transportable by Rhinos. There's no other way you're going to get them into a list as being mobile. And even that doesn't really follow the background.
Imperial Armour makes it abundantly clear that Space Marines regard using Tarantulas as an offensive, mobile weapon, as a hinderence rather than a boon.
Your thoughts?
Lots of formations still look too cheap.
PostPosted: Sat Jul 10, 2010 12:25 am
Just don't call them taruntulas, mostly because it'll contrast with other lists likely to use the more modern version like the elysians.
"tracked tarantula" or "support platform" or something would be fine.
 Post subject: Re: Apocrypha of Skaros 1.0b
PostPosted: Sat Jul 10, 2010 12:40 am
Simulated Knave wrote:
Changelist (1.0b->1.0c)
Tarantula MkIs are now Support Weapons. Speed returns to 10cm.
Field Guns are now Artillery Pieces. Speed returns to 10cm.
Teleport option restored. Cost to 50.
Am I missing some part of this conversation somewhere? Are we talking about flavor text or something?
We are. Leastaways I am.
PostPosted: Sat Jul 10, 2010 12:43 am
Ahh, I see. Most of the chatter had left me scratching my head. Wouldn't 'First-Generation' work just as well, or something like it, as 'Tracked,' so people know that these are old-timey Tarantulas and not the new modern spider sentries?
PostPosted: Sat Jul 10, 2010 12:45 am
Indeed, all it needs is a different name, and the waves settle.
PostPosted: Sat Jul 10, 2010 1:12 am
zombocom:
They're called Support Weapons in the list. Tarantulas are mentioned as being Support Weapons in the flavor text.
E&C:
Which, by itself, could easily point to them being different than the original Tarantula. Clearly, they're named for their similarity to the original, which is only infrequently deployed in the current era.
Also, the quotes you cite do not necessarily refer to Tarantulas in particular. The Space Marine quote, for example, refers to "sentry weapons", not Tarantulas specifically. Clearly, the Marines are still using the superior grav-equipped version, whose statistics are not presented here in order to avoid sending Guard players into fits of jealousy. :P
Alternately, I'm balancing the modern interpretation with the old.
I am going to explicitly point out that these aren't the same Tarantulas Imperial Armor talks about. The most recent source is not God, E&C. Indeed, it's a Forge World publication. Forge World, you may have noticed, are not the Studio, for all they are closely associated and I think their work is occasionally better. I have multiple portrayals of Tarantulas that have them mobile. This forum is filled to the brim with people who pretend vast swathes of background don't exist according to their whims, sometimes including almost everything after Space Marine. Considering the amount of stuff in NetEA lists that has been made up, I think mashing together two bits of background and whistling innocently is relatively minor.
So saying "these are different, superior, Tarantulas", is more than enough. Which is what I will do. But they can have the same damn name in the background text without calamity resulting.
You mean the background which, in Imperial Armor Volume I (page 104) says that Tarantulas "can be carried in the back of a Chimera or Rhino"...?
Well, there're Tacticals, Assaults, Devastators, Terminators, Vindicators, Heavy Support and Dreadnoughts that you could (or could not) be referring to. IIRC, everything else is the same cost as in the Codex list.
Of those:
Tacticals, Assaults and Devastators would seem to be at prices you've suggested before for the default list. I could see Devs going back to 250, but Tacs and Devs seem pricey at those levels.
Terminators can't Air Assault any more and still cost 350 when teleporting. Their reduced cost is to help make the Terminators + LRs combination viable. Are garrisoning Terminators that serious a threat?
Vindicators no one's mentioned so far. If you feel they're too cheap, I could see putting them up to 225. 250 feels like a bit too much (especially next to Predators at 275).
Heavy Support: that's what nealhunt suggested, IIRC, and his reasoning made a lot of sense. Would that price be better for five Support Weapons instead of six?
Dreadnoughts: I think you suggested that price point as well...I may be wrong, though. Perhaps it was Morgan Vening. In any case, it'll be a very slow formation - I can't see anyone being very interested at a particularly higher cost.
EDIT: (You're supposed to point out where my assumptions have fallen flat in the above, just to be clear).
Night Lords 0.1
My Trade Thread
PostPosted: Sat Jul 10, 2010 1:21 am
Everything FW puts out is read and vetted by the core studio first.
Yep, and right afterwards it says Marines would rather stab themselves in the eye than do that in a battle situation (Paraphrased, heh).
Am I indeed?
It's damned late and I'm not going to go through everything point by point right now, sorry.
PostPosted: Sat Jul 10, 2010 1:29 am
No it doesn't...
At least, not in the book I'm reading. Space Marines "[find] them especially useful for routine guard duties due to their relative lack of manpower." That doesn't preclude loading them in Rhinos (or using them in battle, for that matter). Indeed, it slightly implies they do use them in battle...
Am I indeed?
As opposed to accepting them as divinely inspired and not open to argument, that is. :P
Besides, if I could do it, I wouldn't be asking others to, now would I?
Ah well. If you can find the time tomorrow or Sunday or Monday or something of that nature, that'd be more than helpful. :)
Night Lords 0.1
My Trade Thread
PostPosted: Sat Jul 10, 2010 1:37 am
Tarantulas are only deployed for static defence, their lack of mobility severely restricting their use during a fluid battle.
Ie: Marines would rather stab themselves in the eye than use them in a mobile battle.
Am going on holiday this weekend, only passing by PC for brief drive-by shootings. I'd need to write an essay on this list to help you.
PostPosted: Sat Jul 10, 2010 2:05 am
Restricting, not prohibiting. And, in any case, they'd be using the magical grav-lift versions (in the case of this list), so it'd be fine.
Don't be optimistic or anything. :P
Night Lords 0.1
My Trade Thread
PostPosted: Sat Jul 10, 2010 9:01 am
Weeeellll....
Field Guns in Epic are Infantry because they arent' only the gun. They are the gun AND crew. And over the course of an Epic turn which is supposed to be an entire game of Wh40k they can be moved if slowly.
Tarantulas are an exception because they operate alone and never have a crew. So LV for them actually makes sence. If movable or not this is the question because they have no crew to tow them along and they aren't automotive.
PostPosted: Sat Jul 10, 2010 9:07 am
BlackLegion wrote:
Weeeellll....
This is precisely the argument to make them LV.
That's fine. Our group will play at as we see fit regardless of what a list states (INF with mounted most likely).
In regards to naming weapons the same as existing ones with differing stats: what this invariably does is get people on the wrong side and sees a list not being played - just some feedback.
PostPosted: Sat Jul 10, 2010 1:21 pm
The unit is called Support Weapons. Tarantulas are mentioned in the flavor text of that unit as being one of a variety of things that are considered Support Weapons. Furthermore, I am going to revise that text to explicitly explain that these Tarantulas are different than the Guard version (and are instead basically the last Epic version, which was grav-capable).
In regards to the artillery thing: I am being consistent with the rest of Epic. If people want to talk about changing the way the rest of Epic works, I'm more than willing to (indeed, I'd support it, or at least be seriously curious). As-is, I think it's more important to be consistent. Indeed, people keep urging me to be in regard to Tarantulas. :P
Frogbear, could you give me some more details on what, exactly, you found problematic about the Tarantulas (or Field Guns) being infantry during the AoS v.EC game?
Night Lords 0.1
My Trade Thread
