Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 9  Next
Consolidated view so far
 Post subject: Re: Consolidated view so far
PostPosted: Fri Aug 05, 2011 12:09 am
It solves it in the same way that removing warhounds from the list entirely solves it.
PostPosted: Fri Aug 05, 2011 12:15 am
I'd say we should at least tryremoving the singles. People still take scout titans for Eldar, and honestly I think it's better if there are no Titans in Space Marine lists than if there are two single Warhounds in every Space Marine list.
PostPosted: Fri Aug 05, 2011 12:18 am
I disagree, but unless it's tried we won't ever know will we...?
PostPosted: Fri Aug 05, 2011 12:35 am
It's excessive, and in no way the sort of caution that should be displayed in dealing with an official, finished list. This is not the place for wild experiments.
PostPosted: Fri Aug 05, 2011 12:43 am
And I would ask then, why is it that people are still calling for change to the half titans/air "Space Marine" lists so prevalent in many tournaments...?
The "finished" list is far from perfect.
PostPosted: Fri Aug 05, 2011 12:45 am
I also disagree with this planned Warhound action and it looks like most people do too.
Warhound pairs aren't not the issue or the issue people are complaining about. The issue and the same that people are complaining about is Single Warhound spam.
Yet some say there no issue at all.
I see the only reasonable options are....
1) No Change and Leave Warhounds alone OR
2) 0-1 On Single only.
But Price rise on something that didn't need fixing and gutting singles all together seems odd.
Last edited by Angel_of_Caliban on Fri Aug 05, 2011 12:54 am, edited 1 time in total.
PostPosted: Fri Aug 05, 2011 12:50 am
Dobbsy wrote:
1/ Land Raider 325 points - a conservative start but I would like to see it drop to 300 if the Warhound proposal below is not implemented.
Fine.
Vindicator - 225 points. 50 point upgrade. A +5 cm movement would be good for the upgrades but I'm still trying to decide if it could work alongside the price drop. This is a late idea but what about a 3+FF instead? Would it be warranted? It's an awfully big shell....
225pts is fine. No to increased FF.
3/ Predators - flat 250 (FF3+ for Pred D incorporated after the discussion thread for the preds a while back) - I want to be conservative with this change (i.e. no 225 for 4 D's) even knowing that there's a good chance they don't equal a WH. Plus, it's just easier to price them the same to start with.
Fine.
4/ Tacticals - confirm 275 and LR upgrade option
Fine with cost. Not keen on the upgrade.
5/ Warhounds - 550 - a pair with no discount. You still get to use them but you don't get 2 pairs. I'm still debating on 500 though but I'm siding with 550 more atm. EDIT - No singletons available for purchase at all.
Absolutely not. No limit on single and no cost increase to pairs.
Thunderbolts 175 - proposed by Dave Thomas a while back and in league with the Warhound change so you won't get 3 squadrons (basically a +1 activation boost) and your Warhounds.
Not keen on this but I understand that having the higher SR could be a reason for this. There would only be a few times that a Marine players first activation would be CAP.
Warlord 825? - Mainly as an option to still allow 1 Thunderbolt Sdn in addition to a Warlord choice. This idea is a bit new but I remember TRC asking to keep the option for both viable when the TBs were discussed a while back and it seems fair to me. Also E&C proposed the idea recently.
Not in favour of this because of the possible knock on effect to other lists.
I don't take Warlords because of the limited loadout of the Titan. If I could customise the titan I would use it but then it would truely list changing (think 2 quake cannons, Carapace Landing Pad and Close combat Weapon as a blitz guard for Marines :) = broken list).
Scouts - add the LSS for testing at the very least. No price change but possible removal of the Razorback but I'm still undecided on that. This is all still in my "possibly don't bother" basket even though it's a more fluffy option and I like the idea.
I don't see the need for this at all.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Fri Aug 05, 2011 1:02 am
Those lists never contain the warhonud pairs you're looking to make more expensive. They also contain at least two thunderhawks which you've decided not to touch. This change will make no difference to the UK tournament scene anyway.
Bring down the cost of the armour options, and the warhound becomes less attractive with its new nasty critical. A 300 point land raider formation becomes just as attractive.
You need to be more conservative with changes to such an important list. Change the vehicles and then see what impact it has on warhounds.
PostPosted: Fri Aug 05, 2011 1:30 am
I'm probably with the majority here...
I'd say the ONLY problem with Warhounds is people running two of them as separate formations. I support the 0-1 restriction on singletons.
I think Thunderbolts are fine at 150; their individual cost is the same as Hunters and they're often used for the same purpose anyway. Conversely I don't think -25 points will make Warlords more popular at all. I think 800 should be the starting point!
No strong opinions on the other proposed changes. I don't think Vindicators need a stat increase, and I'm happy to see Predator Destructors become good at FF. I won't use the Tactical LR upgrade option but I'm not opposed to it either.
PostPosted: Fri Aug 05, 2011 1:51 am
I would actively like the Land Raider upgrade for Tacticals, think Vindicators probably don't rate 3+ Firefight, Warhound Pairs should remain at 500 (they're expensive enough for a single activation as it is. Pushing to 550 is probably too much.) Thunderbolts at 175 might be worth trying out (SR5 makes them significantly better at CAP, as does the ability to soften targets for Air Assault.
As for single Warhounds, I think one of three things is a necessity:
1) Make Thunderhawks compete for 1/3 Allies,
2) No single Warhounds at all, just pairs,
3) 0-1 single Warhounds, no limit on pairs.
A points increase of only 25 is going to have entirely no effect, except for cutting out elements from the core list. Warhounds are so damned good for Space Marines, that people might still take them if they were 350. It's not like there was a massive drop in Titans when they went from 250 to 275; people just dropped a Chaplain, or some Razorbacks, or something else that is far more fitting in a Marine list. The current critical effect isn't worth a decrease in points, as it is still better than basically every other DC 3 War Engine, which just explode.
Personally, my preference is for #1, but #3 is the next best option.
PostPosted: Fri Aug 05, 2011 1:58 am
Hey, as I mentioned, I'm happy to still try 500 for a pair if 550 is too much for people....
PostPosted: Fri Aug 05, 2011 2:10 am
I am also with the others in wanting to keep Warhound pairs at 500. no price increase is necessary.
FWIW the original argument for 275 for a singlton was in part to cost in the additional activation for the smaller formation - a practice that is reasonably widespread across lists with similar situations eg Artillery company is cheaper than three Artillery batteries.
PostPosted: Fri Aug 05, 2011 2:26 am
I just don't know why you're even considering changing it. Noone has ever complained about warhound pairs to my knowledge.
PostPosted: Fri Aug 05, 2011 3:12 am
And they seem to be the only group that is complaining yet the list won't effect them.
Areas of NetEA Use:
1) UK by the Rebel not EUK Folk
2) BL German Folk
3) USA
4) Australia
1) Seems to complain about the Warhounds cuz there use to the issue in tourny's? And even tho different list the Metagame is about the same.
2) IIRC BL said there wasn't a Warhound issue there. Partly to do with lack of models I believe.
3) Dave said the NE Groups have to issue. I haven't heard much from Chicago area about them and we have no issues with them on West Coast.
4) IIRC Froggy and You says there an issues on your East Coast but Onxy and Matt says there no issues on the West.
So out of 4 Major areas only one really have a Warhound issue at all(At least from that area forum members). If you sub break it down its still 2 to 5 with issues with Warhounds.
So I would say either leave alone and see how they go with the new Critical (That I've doubt have seen much use yet)
OR
Make Single 0-1 that would be in line with the Fluff and also not crazy changes.
I know some people are saying other suggestions but I keep see 0-1 in almost all posts.
PostPosted: Fri Aug 05, 2011 3:16 am
It's not about the complaints about pairs. It's about a compromise to try and sort the issue out.
The idea was based around the numbers you would be allowed to field. 550 means you only get 1 pair from a 1/3 allotment. It stops the over-use syndrome of the 2-3 x singles but still lets you field 2 Warhounds, however, you lose the bonus activation of the singles. You're also still paying the same as 2 singles so you lose no points in effect (other than the "formation= cheaper" design). You'd still get Thunderbolts but at 175 they'd be reduced too.
0-1 doesn't actually solve the issue either way, as you would most likely just see people take 0-1 and a pair if they're that good and you'd still get thunderbolts (even at 175) and Thunderhawks, so the issue of less Marines is still there. 0-1 total means it does not scale at larger levels, whereas 550 a pair means you can take as many pairs as you're allowed at 3000+.
No change at all means we'll see the same old builds and we'll have the same old calls for aeons.
Upping to 300 means no real change to the less Marines, more allies conundrum.
Pairs only at 500 means 2xpairs allowed - again less Marines, more allies.
Look in the end, I see this as a middle ground where no one is particularly happy but is fairer to all sides for that reason and staying truer to a more Marine design.
I can go round and round by choosing what one group of players wants only to cop it in the ear from the other 2/3rds and vice versa etc. There's no simple solution. This is the best outcome I can see.
And hey, ultimately it's not my decision. NetERC can shit-can it and we'll be right back where we started. At least I can say I tried.
